1. Offline
    oldnoah Member
    Start a Conversation
    Aug 21, 2010
    133
    34
    New York
    Your Vehicle Year:
    2001 Prius
    My A/C light starts flashing after about 30 minutes of use. The A/C is still cold while it's running, but it warms up when the light starts blinking.
    At this point I'm planning on replacing the clutch assembly. Does anyone have any experience with this? Do I need any special tools? How far apart do I need to take the car so I can reach the clutch? Is there something else I can test to see if the compressor is on its last legs, before I put money into the clutch?
    I'd appreciate any help from someone with experience.
    Thanks.
  2. Offline
    sbiddle Junior Member
    Sep 30, 2011
    27
    Alton, NH
    Your Vehicle Year:
    I had the same problem and I ended up replacing the compressor (with clutch) with a rebuilt unit. I replaced the drier and recharged the system. It's been running fine ever since. I was unable to find a clutch by itself.
  3. Offline
    usnavystgc Die Hard DIYer
    Jul 29, 2011
    1,360
    375
    Bowling Green, KY
    Your Vehicle Year:
    I'm not positive but, I'm pretty sure a flashing light indicates a low freon level. I would charge the system before replacing anything. The fact that it gets cold to begin with shows the clutch and compressor are working. When the compressor runs out of freon, it no longer cools and you get the flashing light. Low freon "usually" indicates a leak in the system (but not always). Recharge it first (<$40). If it works for a couple of weeks after recharge and the symptoms return, you have a leak. If you want to jump the gun, you can buy the freon w/ dye (ie: leak detector) in it.
  4. Offline
    ChapmanF Active Member
    784
    170
    Your Vehicle Year:
    2001 Prius
    The clutch assembly looks to be about $195 new at the Toyota dealers that sell online. I don't know how that compares to the rebuilt whole compressor price, but if you don't have easy access to evacuation/reclamation equipment, the clutch-only approach might be less hassle.
    -Chap
  5. Offline
    Sep 30, 2011
    27
    Alton, NH
    Your Vehicle Year:
    The blinking light indicates a difference in the speed of the motor and the speed of the a/c compressor. It will blink if the belt is slipping or if the clutch is slipping.
    1 people like this.
  6. Offline
    oldnoah Member
    Aug 21, 2010
    133
    34
    New York
    Your Vehicle Year:
    2001 Prius
    I had read elsewhere in the forum that the blinking light meant that the clutch or belt was slipping. I replaced the belt, but it didn't solve the problem, so I'm heading toward the clutch. I just wanted to know if anyone had done it, in case there were any hang ups I should watch out for.
  7. Offline
    alfhild@grics.net New Member
    Feb 9, 2008
    galesburg,ill
    Your Vehicle Year:
    2001 Prius
    My 2001 prius after 190,000 miles started the blinking light problem--1st, I tried to add freon--luckily the compressor had an over-charge valve--The problem was that the clutch face was slipping--remove shroud, remove the clutch plate and grind down one of the spacer washers approximately 2 thousands--put back and that will probably solve the problem
    joedirte likes this.
  8. Offline
    Station2Station New Member
    Jul 17, 2012
    Shreveport, Louisiana
    Your Vehicle Year:
    2002 Prius
    I
Share This Page
