1. Offline
    rmccarra New Member
    Aug 15, 2009
    Message Count:
    Frederick
    Your Vehicle Year:
    Ok so I had my new car for 4 weeks and someone backed into it breaking a tail light (no note left). Any tips/suggestions on where I can get instructions on how to replace it? Got a new one on order ($400 later).
  2. Offline
    Rokeby Member
    Jan 21, 2008
    Message Count:
    2,890
    591
    Ballamer, Merlin
    Your Vehicle Year:
    rmccarra,
    :welcome: to PRIUSchat. :cheer2:
    OUCH!
    Here is a thread with pictures on how to remove/replace the Gen II
    tail light assemblies:
    http://priuschat.com/forums/gen-ii-...423-2007-tail-light-removal-instructions.html
    With luck it is nearly the same for your Gen III.
    Also, the Search Tool is your friend. Using "tail light replacement" as
    the search term will generate a long list of threads on this topic on
    Gen IIs for further reading.
    Hope this helps.
  3. Offline
    jsharpe New Member
    Aug 6, 2007
    Message Count:
    109
    27
    Your Vehicle Year:
    My teenage son had a similar experience on his Gen II and the swap was simple enough he did it himself. It basically amounted to two nuts accessed from inside the trunk area and they popped right out. A few minutes and a couple hundred dollars later (Gen II's must be cheaper) he was back to new.
  4. Offline
    rmccarra New Member
    Aug 15, 2009
    Message Count:
    Frederick
    Your Vehicle Year:
    Thanks
    New part comes Tuesday, hope its just as easy !
  5. Offline
    nineinchnail1024 New Member
    May 4, 2009
    Message Count:
    280
    34
    New Orleans
    Your Vehicle Year:
    Damn it. I walked outside tonight and someone did the same damn thing to me. In my driveway! I was hoping they weren't too expensive. Oh, well. The hole in my taillight looks about the right height for a bicycle handlebar, and there is black rubber around the broken glass. Punks.
  6. Offline
    rmccarra New Member
    Aug 15, 2009
    Message Count:
    Frederick
    Your Vehicle Year:
    I changed it out last night. Took 45 minutes and was a little more involved that the 2009 model info I got. You need to remove a screw in the tail gate door jam, two of the cargo hook brackets, remove the spare tire tray and their is an additional bolt accessable after you lift the tail gate to lossen the bumper.
    This last one is important as the tailight has a bracket at the bottom that hooks behind the bumper. If you do not remove the bumper bolt you will not be able to remove the old taillight and or install the new one.
    Its also a pretty tight fit so removing it and installing the new one takes some finess.
    Good luck !
Share This Page
