Replacing Front Side Running/Turning Lights
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Whenthenighthascome, Feb 24, 2014.
  1. Whenthenighthascome
    Whenthenighthascome New Member
    I
    [​IMG]I'm thinking of buying a 2010 Prius I and it comes with the standard running lights shown. I've seen these around with the plastic cover over the bottom half but I want to know if you can take them out and replace them with full LED lamps. Thanks!
  2. Tande
    Tande Active Member
    497
    299
    Mich.
  3. xliderider
    xliderider Senior Member
    7,842
    3,099
    Honolulu, HI
    That's not LED. ;)
    SCH-I535
  4. MKART
    MKART Junior Member
    61
    Cincinnati, Ohio
    The LED running lights are only on the 2012+ models. I believe they come standard.
    The lights you have boxed in red are not day time running lights (DRL). Those are the turn signals and the plastic part covers are where the fog lights would be if you had the highest 2010/11 trim model, the v or five (not to be confused with the larger PriusV). Yes, you can take out the plastic covers on a 2010/11 and install fog lights.
