Replacing the cover in front of the 12V battery
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Entecha, Sep 6, 2013.
  1. Entecha
    Entecha New Member
    I wanted to check the 12V battery so I snapped off the two fasteners and pulled off the small panel under the back seat. All went well until I wanted to replace the panel. The panel popped back in just fine but I've having quite a time putting the two fasteners back on. I don't want to use too much force because they look quite fragile. I can't get them to pop back in. Does anyone have any experience with this?
  2. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Pull the center pin out as far as it will go. This then allows the body of the fastener to enter the hole. Once it's in place push the center pin back in to secure it.
    Removal is the reverse - push the center pin in as far as it will go, then pull the fastener out by its body. If you broke any parts when removing the fasteners you'll have to replace them.
  3. krneidigh
    krneidigh Junior Member
    70
    17
    Pensacola
    Yeah, the fasteners suck, snapped them.
  4. Gcoop
    Gcoop Member
    156
    79
    niagara region ontario canada
    I snapped one of them aswell.
    check with your dealer.
    I had to get a similar part for my old acura, ad it was like $2 for 5 or something
  5. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    You have a new car. Why on earth would you want to or need to check the 12V battery?
    Just curious.
  6. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Some people like to know all the simple things on a new car before a problem occurs. All of the various fasteners on all the Toyota cars are different and confusing and not always easy to figure out. WHY?
    minkus likes this.
