Reset Maintenance Light On Dash
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Harper, Jun 13, 2007.
  1. Harper
    Harper New Member
    60
    Fountain Valley, Ca.
    So how can I reset the "Maintenance Req." light on the dashboard? I've just had an oil change and the light still flashes when I start my car. Thanks!!!
  2. jimnjo
    jimnjo New Member
    I didn't double check this link, but found it in a thread on this topic.
    Another option, if at the Toyota dealer, is to ask them to reset it (my dealer no longer needs to be prompted, but they did at first).
    Go to:
    http://john1701a.com/prius/prius-userguide.htm
    Download the pdf, which has a lot of great info and go to page 25 for instructions on how to reset the maintenance light.
    Good luck!
  3. FBear
    FBear Senior Member
    348
    Maplewood, NJ
    You could also try reading the fm. All the information you need to reset the maintenance light is in there.
    Try doing this:
    Press start button until car turns the ignition on
    Make sure the odometer displays "ODO" NOT TRIP
    Press and hold the ODO trip reset button in
    press start button until car turns off
    press start button until car turns back to ON
    Hold the ODO button in until all the flashing lines on the odometer go away and the mileage returns and the maint reset light stops flashing
    Your'e done.
    Surnp, BigFatGuy, krg03 and 1 other person like this.
  4. Harper
    Harper New Member
    60
    <div class='quotetop'>QUOTE(FBear @ Jun 13 2007, 12:58 PM) [snapback]460988[/snapback]</div>
    Thanks guys.....
  5. kenoarto
    kenoarto Active Member
    105
    Chicago, IL
    Snooty answers don't help. I just spent 15 minutes in a very cold garage, searching through the manuals for a simple answer.
    bobdonotreply likes this.
  6. CharlesJ
    CharlesJ Member
    463
    26
    38
    Monterey
    Especially when it is a short and sweet answer.
  7. bang4abuckprius
    bang4abuckprius Junior Member
    Rocky Face, Georgia 30740
    FBear, Thanks your instructions to reset maintenance light after oil change worked first time!!!!!
  8. Ichiro
    Ichiro Member
    329
    SF
    domo arigato bear-san!
  9. theshark
    theshark Member
    164
    Martinsburg, WV
    I couldn't agree more.
  10. jumpsuit
    jumpsuit Junior Member
    I have a 2004 Prius and this procedure worked fine for me. Many thanks
  11. jqmello
    jqmello Junior Member
    70
    DC
    On my 2004 I hold the ODO button while pressing the power button twice. Keep holding ODO button until the dashes in the mileage display disappear.
    That's worked the last 3 oil changes.
  12. BenQ
    BenQ New Member
    Lancaster Pa
    I just followed jqmello's post and it worked on my 2006. Did it with the foot off the brake.
    Very slick. Thanks for the info.
    BenQ
