Reuters and Nikkei reporting Toyota will launch 94mpg compact hybrid in January
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Rybold, Sep 28, 2011.
  1. Rybold
    Rybold globally warmed member
    2,760
    320
    Southern California
    REUTERS: UPDATE 1-Toyota to launch compact hybrid in January -Nikkei | Reuters
  2. zenMachine
    zenMachine Just another Onionhead
    3,354
    292
    That's more like it! Thanks for the heads up.
  3. johalareewi
    johalareewi Member
    393
    uk
    Wonder where that will sit in the prodcut line alongside the hybrid yaris?
    Toyota
  4. andyprius
    andyprius Senior Member
    2,212
    164
    Sacramento, California.
    Maybe my math is way off, but there are 3.9 liters to the American gallon. 3.9 X 40 Km X .625 = 97.5 mpg. Now, what can a hyper miler do with that? I stand corrected: 3.785lgal. = 94.6
  5. andyprius
    2,212
    164
    Double Post
  6. cwerdna
    cwerdna Senior Member
    12,483
    2,024
    SF Bay Area, CA
    inflated Japanese test cycle
    They're probably using an inflated Japanese test cycle.
    Per Google (a great unit converter):
    40 (km per litre) = 94.0858333 miles per US gallon
    32 (km per litre) = 75.2686667 miles per US gallon
    (Try Googling for these as examples:
    40 km per litre in miles per us gallon
    50 mpg in teaspoons per mile
    From Japanese ratings call Prius world's most efficient car, 89.4 mpg (US)! (for the 2010 Prius), they mention
    38 (km per litre) = 89.3815417 miles per US gallon
    32.6 (km per litre) = 76.6799542 miles per US gallon
  7. JimboPalmer
    JimboPalmer Friend to those who want no friends
    9,191
    3,032
    Greenwood MS USA
    50 MPG * 40/32 = 62.5 Approximate EPA MPG
  8. cyclopathic
    cyclopathic Senior Member
    3,259
    512
    2014 Prius c
    gallon is 3.78L
  9. David Beale
    David Beale Senior Member
    5,089
    1,014
    Edmonton Alberta
    OK, -I- think they're talking about the Prius C, aka hybrid Yaris. I -suspect- calling it a hybrid Yaris is wrong, but I have no facts. ;) I DO like the looks of the "prototype" shown on the Toyota US site! And a friend here is looking to buy one and was told by the dealer it will be here in the Spring in small quantities.
    So, taking the Japanese rating vs the US rating for the current Prius gives me a conversion factor of 50/76.7 = 0.65. Multiply that by the quoted figure for the new car you get 89.4*0.65 = 58.3 MPG US EPA estimate. A MUCH more believable figure! But be warned, I'm not so sure you can factor like this.
    In these cases "caveat emptor" doesn't apply, rather "figures lie and lairs figure" fits better. ;)
  10. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,917
    Fort Lee, NJ
    20% higher efficiency (40km vs. 32km per liter of gas) so it should get 60 MPG. It'll give Volt with 60 MPGe for a run for the money without having to plug it in. :D
  11. spwolf
    spwolf Senior Member
    3,136
    427
    Eastern Europe
    thats 25% higher actually... and unlikely if they are going to keep the same powertrain.
    So something is off here, most likely it is different powertrain.
  12. spwolf
    3,136
    427
    Eastern Europe
    from spy shots, not, they wont be same cars... in Europe, both will be sold. Just like Auris Hybrid and Prius and CT200h.
  13. austingreen
    austingreen Senior Member
    11,753
    2,724
    Austin, TX, USA
    I think it is fair to assume the japanese car will be at least slightly different than the prius C. Your math does seem correct, but looking at the shape of the C from the prius website, we may assume that cd may not give as big of an improvement on the US test. Does anyone have a good estimate of CdA of the C verus the gen III prius liftback.
  14. DeadPhish
    DeadPhish Senior Member
    2,010
    352
    Outer Banks of NC.. Retired to play golf and poker
    Disregarding any conversion factors and just using a comparitive ratio to guess the US fuel usage numbers...
    Gen 3
    32 km/l Japanese standard = 50 mpg in the US under EPA standards
    2012 'baby Prius'
    40 km/l Japanese standard ( 25% improvement ) should equal about 62-64 mpg in the US ... also a 25% improvement.
    I'll bet a dozen donuts on this being very close to the number that's given to the new baby Prius.
  15. spwolf
    3,136
    427
    Eastern Europe
    i wonder if journalists made mistake of comparing different Japanese standards :).
    Because under old Japanese standards (10-15), Prius gets 38km/l. And if they actually used same drivetrain, 5% better mpg makes sense as thats what you get from losing some weight. But this will not be drastically smaller car (more like Auris than Yaris).
    25% better means completely new technology.
  16. Rybold
    2,760
    320
    Southern California
    Numbers and math aside, I find it interesting that they mention this vehicle will have the same HSD as the Prius. If this is in fact the Prius c, it means the Prius c will have the same HSD as the regular Prius (provided the journalist has a solid source for that qualitative bit of info).
    However, Toyota has said numerous times that the Prius c will not be ready until late Spring or Summer. Could this be something else? Could the Japanese Prius c launch be six months ahead of the U.S. launch?
  17. spwolf
    3,136
    427
    Eastern Europe
    I am sure this is Prius c... and that it is sized more like CT200h than Yaris (we all saw the spy shots and they are two very different cars /Prius c vs Yaris Hybrid spy shots).
    As to the launch date - just remember Prius v. They want to stagger the launches to build up inventory. Prius+ is launching in Europe a year later than Prius Alpha in Japan.
  18. EVdriver
    EVdriver Junior Member
    39
    2 people like this.
  19. spwolf
    3,136
    427
    Eastern Europe
  20. David Beale
    5,089
    1,014
    Edmonton Alberta
    Well, I remember hearing they were going to use the GII powertrain, updated, of course. So 1.5 l.
    Or perhaps I just dreamt it.
