RPM Dependent Rattling Noise from outside of car
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by HeinzCatSoup, Jan 29, 2014.
  1. HeinzCatSoup
    HeinzCatSoup Junior Member
    Southern California
    Hey guys,
    I recently noticed that there is a small rattling noise from outside of my 2010 that only happens during an acceleration when the engine is on.
    ECO MODE
    _________________
    _________^
    In my beautiful drawing above, it would be around the spot above during an uphill climb. The weird part is that its only at this exact RPM position, anything lower I cant hear it, any tick higher than this (when i accelerate), it goes away.
    Anyone have any suggestions? I tried to do a quick search and I see some complaint about inside the dashboard, but I know mine is somewhere outside because I cant hear it unless i turn the radio off and roll the windows down.
  2. hwy1north
    hwy1north Junior Member
    I too have this noise on a 2014. It only comes on when the eco bar is about 3/4 power or 1/4" from the red power which is where it likes to sit for my freeway commute. The sound seems to be coming from inside the dash behind the radio and the ticking sounds like a cross between an empty spray paint can rattle and a cricket. If I let off the gas or accelerate, the noise stops. Is it something to do with the recharge cycle? At first I thought it was engine ping as it only comes on with a slight load on the gas engine, and maybe it is?
    HeinzCatSoup likes this.
  3. xliderider
    xliderider Senior Member
    7,842
    3,099
    Honolulu, HI
    Engine knocking? Valve noise?
  4. HeinzCatSoup
    Southern California
    YES, it sounds like a paint can rattling very loudly. I still have yet to figure out what it is. It does not sound like an engine knocking sound though.
    hwy1north if you have a 2014, you should just take it to the dealer and whatever the problem is should be covered under warranty? then maybe you can let me know what it is too.
    Its starting to slowly drive me crazy. I have to take my car in for the ECU recall, so maybe I'll just pony up some $$ and have the dealer figure out what the sound is.
  5. Former Member 68813
    3,524
    981
    US
    The description sounds like pinging (preignition). Find recordings of the engine pinging and compare to yours.
  6. HeinzCatSoup
    Southern California
    I looked up the engine ping, and no it doesn't sound like it. I should also say it doesn't sound like it's coming from the engine, but more from the bottom, if that makes sense. I'll try to record it this weekend when I have time
  7. phoenixgreg
    phoenixgreg Senior member
    1,157
    288
    66
    Phoenix
  8. HeinzCatSoup
    Southern California
    no. that is not the sound. its not coming from the dash. Its from the bottom outside. let me see if i can post a video soon
