RPM slow to return to idle
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by BeakerTX, Aug 16, 2014.
  1. BeakerTX
    BeakerTX Junior Member
    23
    San Antonio, TX
    Anyone have input or experience with the following problem? When decelerating from high rpm (taking my foot off the gas pedal), the engine is slow to return to idle rpm. Normally, when taking the foot off the gas pedal, the rpms lower immediately. I have notice lately and more often that the rpms can take up to 5 seconds to lower to idle rpms. My first thought is the throttle is sticking, but the car does not continue to accelerate even though the rpms remain high. The closest analogy I can think of is holding the gas pedal down and clutch in if it were a manual car. Seems to happen in hotter weather and when the car is warmed up.
    It doesn't happen all the time, and might take a while for a shop to diagnose. Trying to get them a starting point before bringing it in. I have 2k miles left on my extended warranty (75k).
    Finally, my apologies if the solution is buried in another post. Searched for an hour and nothing came up.
    Thanks!
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    It could be very normal. You say it happens most when the car is warmed up and in hot weather. What setting do you have the a/c on? Do you have it on LO and run at a high level on Recirc by any chance?
    Is the vent on the rear seat blocked when rev issue occurs?
  3. BeakerTX
    23
    San Antonio, TX
    Thanks for the reply.
    The reason I shy away from it being normal is this is just now creeping up after owning the car for 5 years. Bought new in fall 2009. Been in the same south Texas climate the entire time. Nothing unique thermally about this summer. I think the heat exacerbates the problem, but no the cause.
    The AC is always running (set to 74), and almost always recirc. The rear vents are not blocked.
    48,985
    how's your 12 volt battery?
  5. BeakerTX
    23
    San Antonio, TX
    Was ok at the last checkup about a month ago. Replaced only once in 72500 mi.
    Ignorant (on my end) question: how is the battery linked to the rpm issue?
    iPhone ?
  6. bisco
    48,985
    the battery is linked to almost everything. i would test it just in case. do it in the morning before driving. get a digital voltmeter and check at the battery posts.
  7. BeakerTX
    23
    San Antonio, TX
    12.64 V. Hasn't been driven all day. No load tester at home. Load test last month was normal, and the problem started before that, though less often.
    iPhone ?
  8. bisco
    48,985
    okay, any relevance to hybrid battery level when it happens?
  9. BeakerTX
    23
    San Antonio, TX
    Nope. No trend there. Been searching for something predictable indicator, and heat is as close as I have gotten.
    iPad ? HD
  10. bisco
    48,985
    air filter?
  11. BeakerTX
    23
    San Antonio, TX
    Changed per normal scheduled maintenance.
    iPad ? HD
  12. bisco
    48,985
    i don't think i've heard of this issue before. i wonder if there might be any codes stored?
  13. BeakerTX
    23
    San Antonio, TX
    I've got a CarMD reader but haven't checked it since the check engine light has not lit up. Worth a shot. May try it tomorrow.
    iPad ? HD
  14. A617
    A617 Member
    213
    95
    OKC, OK
    I have that come onces in a while but usually occurs when after a brisk acceleration when the traction battery is around 2-3 bars or when ice is in the process of charging the traction battery.
    And it feels like the engine is disengaged from the drive (free spinning) and the rpm leisurely comes down.
    #14 A617, Aug 17, 2014
  15. bisco
    48,985
    that's what i was thinking.
  16. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    I find this happens when the battery is very hot, or is at a "full" charge. Normally, the generator slows the engine quickly and converts the momentum into electricity into the battery, however if the battery ECU is protecting the battery from accepting a charge (in a high-temperature state), the engine is allowed to spin down more freely.
  17. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    I'm thinking about an overheating HV battery too. The OP says they keep the a/c on always (at 74f/23c) in the Texas heat and that the setting is at RECIRC all the time.
    Now I'm sure I've read that by not allowing air to flow through the car it doesn't flow through the HV battery. If the battery is working overtime to cool the car in hot Texas heat and the cold air inside isn't flowing through the battery, then it'll just get hotter and hotter and eventually the car switches to the engine more to protect the cooking battery.
    If the Op always does this (as they say they do) then the poor old HV battery is getting hit hard, both sitting in the heat when parked and then working overtime when it isn't.
    I wonder if the Op should select Auto and let the car adjust between Recirc and flowing air as it sees fit, though I do wonder if the damage is now done.
  18. Tande
    Tande Active Member
    498
    301
    Mich.
    It's my understanding......the H/V batt. has it's own cooling fan which "Pulls" air from the passenger cab interior......& even when in the "Recirc." mode, some outside air is still allowed to enter the cab interior.......with air/cond. operating, this scenario should supply "Cool" air to the H/V batt.......am I wrong?.......:confused:
  19. bisco
    48,985
    patrick wong keeps his on recirq all the time in arizona.
    GrumpyCabbie likes this.
  20. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    I think some say that setting it to Recirc pulls air from the inside and this minimizes the amount of air that finds its way to the rear seat vent whereas setting it to pull outside air in and pass it through forces more air to seek out the vent to escape. Some also say the AC has to work harder to cool the outside air vs cooling the already cooled air that's being recirculated. My thought is to use Recirc as long as needed to cool the car down and then use pass-through. If you set Auto to say, 74 degrees, then once the cabin is cooled, the air going to the vent should be 74 whether it's recirculated or outside air. However, since the AC is electrical, I don't know how much the "extra" work hurts.
