RV with a Prius
Discussion in 'Newbie Forum' started by mwool, Aug 1, 2008.
  1. Offline
    mwool New Member
    Aug 1, 2008
    Message Count:
    McKinney Texas
    Your Vehicle Year:
    Does anyone pull a Prius and if yes, is there a way to do 4 down?
  2. Offline
    mingoglia New Member
    Oct 25, 2007
    Message Count:
    841
    Gilbert, AZ
    Your Vehicle Year:
    Unfortunately, no, there's no way to flat tow a Prius....
  3. Offline
    mwool New Member
    Aug 1, 2008
    Message Count:
    McKinney Texas
    Your Vehicle Year:
    Being new, I do not know which wheels have the generators but can it be towed on a two wheel trailer?
  4. Offline
    Tchou New Member
    Sep 3, 2007
    Message Count:
    161
    generators are not on the wheels, but on transmission, so you have to lift front wheels to tow.
  5. Offline
    tochatihu New Member
    Apr 10, 2004
    Message Count:
    3,164
    346
    Kunming Yunnan China
    Your Vehicle Year:
    2001 Prius
    It is highly expermental, and not necessarily safe, to let the front wheels rotate. Consult With Bob Wilson for details. You can find him out on 'the edge of the envelope'
  6. Offline
    mwool New Member
    Aug 1, 2008
    Message Count:
    McKinney Texas
    Your Vehicle Year:
    Thanks to everyone, This does make a lot of sense. :)
  7. Offline
    pdhenry It's HEEERE!
    May 26, 2008
    Message Count:
    398
    PA
    Your Vehicle Year:
    You can't "dingy tow" a Prius for the same reason that you can't Glide with the engine off above 42 miles per hour - the engine needs to be running or else Motor-Generator #1 (the one not connected to the drive wheels) overspeeds.
  8. Offline
    Apr 9, 2007
    Message Count:
    1,531
    69
    Virginia
    Your Vehicle Year:
    Not entirely true... at least for the current prius model. it CAN overspeed... especially at highway speeds of 60+. I frequently coast down hills in neutral with the engine off in speeds up to 55mph. Nowhere near the 10,000 rpm limit of mg2... which by the way, is at 65mph.
    The other reasons are:
    1) lack of oil to the transmission. The oil pump is driven by the engine.
    2) the battery could be overcharged if towed.
  9. Offline
    May 26, 2008
    Message Count:
    398
    PA
    Your Vehicle Year:
    OK, I misunderstood something I'd read.
    Where does Neutral do anything? I'm only familiar with the HSD but there's no clutch or variable gears there. I had thought neutral was another electronic mode (such as reverse is). Doesn't it just disengage power to both MGs?
  10. Offline
    a64pilot New Member
    Aug 3, 2008
    Message Count:
    771
    56
    Albany Ga.
    Your Vehicle Year:
    Are the MG's actually generators? That is do they have permanant magnets? I would think they would have electromagnets and as such wouldn't generate anything unless they were energized. I would also be surprised if the battery could be charged without the system booted up.
    Surely the manual addresses towing and I would be surprised if you could tow with the front wheels on the ground. I don't have thecar or I would look in the manual.
  11. Offline
    Tchou New Member
    Sep 3, 2007
    Message Count:
    161
    MG actually stands for Motor Generator, so yes they are Generators, with permanent magnets.
Share This Page
