1. Offline
    JoeCos New Member
    Aug 25, 2009
    Message Count:
    Nor Cal
    Your Vehicle Year:
    Assuming the existing antenna of the Prius (Gen 3) is compatible for either Sirius or XM – does anyone know or has installed a plug and play (ie: Starmate) unit and utilized the existing Prius antenna?
    I prefer using the existing antenna and not to have to deal with the magnetic type and running the wires through.
    If anyone knows where to locate the lead point of the antenna wire, and if there’s a need for special adapters, from the OEM wire to the plug and play source unit.
    I have a Sirius subscription and have the Prius II (Gen 3).
    Thanks in Advance.
  2. Offline
    ALL_600D New Member
    Jun 27, 2009
    Message Count:
    70
    San Diego
    Your Vehicle Year:
    I'm looking for the same thing. I pulled a sirius kit off my old 2007 Scion TC and it plugs right into my 2010 prius radio.
    The only thing is I could not locate the end of the "existing" satellite antenna and had to use the magnetic roof top mount one instead. Please let me know also if anyone has info this.
  3. Offline
    urlyadoptr New Member
    Aug 9, 2009
    Message Count:
    69
    Plymouth, MA
    Your Vehicle Year:
    I *believe* that the XM and Sirius antennae are not interchangable; different satellite technology. On my P-III, I think the XM receiver is located under the driver's seat; you might look there to see if you can locate the antenna lead on your P-II.
  4. Offline
    Ridgerunner New Member
    Oct 11, 2009
    Message Count:
    Indiana
    Your Vehicle Year:
    The connector is under the center console / armrest. It is a five minute job to access it. Unfortunately, it is a special square connector that does not match the usual round connector on a Sirius radio. I bought a Shark Fin Adapter cable For Lexus GS from MyRadioStore which works perfectly. Square connector on one end and the usual round one on the other. But it costs $60. There may be a cheaper alternative but I couldn't find one. My Sirius radio works fine using this cable and the OEM antenna.
  5. Offline
    scott4l New Member
    May 11, 2010
    Message Count:
    Cary, NC
    Your Vehicle Year:
    How do you remove the center console? I found 4 bolts in the carpartment and removed them. Then I pulled on the back of the console and plastic tabs started to come out of there slots on the front sides of the console. However, the top middle (in between the cup holders) seemed to still be connected so I stopped pulling. Is there another connection I failed to release?
  6. Offline
    rrolff Prius Surgeon
    Aug 19, 2009
    Message Count:
    1,602
    219
    So Cal
    Your Vehicle Year:
    I know the NAV antenna (GPS) is placed in the dash (Toyota). As XM/Sirrius are also satellite based, and looking at other XM antennas (I just installed a Pioneer XM) - you will have a flat type antenna to mount.
    I have found the front tweeter area to be a great location for reception. This thread shows my previous install.http://priuschat.com/forums/gen-iii...ust-installed-new-nav-dvd-head-unit-pics.html - post #1 shows the sat antenna placed in the front speaker area (it's blurry). This one shows how to pull the stuff off to get at that location. http://priuschat.com/forums/gen-iii...onics/68491-front-dash-tweeter-removal-4.html - post #32. Once you get to the location, running the wire back into unit is easy (through the dash).
    Depending on your XM module, there is LOTs of room behind the stereo in the dash. I placed my (fairly large - maybe 9" x 5" x 1") Pioneer XM behind the radio. I also placed a MSN DIrect module (5" x 3" x 1"), a PAC steering interface module (3" x 1.5" x 1.5"), a PAC wireless remote module (same size), along with gobs of wire... I still have room for other stuff - just can't think of anything else to throw back there :cool:
  7. Offline
    midlife New Member
    Feb 28, 2011
    Message Count:
    Orange County, California
    Your Vehicle Year:
    Looking for help with this and may be over-posting.............. sorry.
    My dealer accessories guy just told me that the XM antenna lead is under the console ONLY on cars that have factory-installed XM integrated units. Otherwise he said you have to pull the radio head unit or somehow get behind it to access the antenna lead. What I don't get is how to connect into that lead if it's even accessible. In another post I found reference to something called a 'direct connect' module but I don't know where to find such a thing AND am also confused because the same post also described installing the external antenna that came with the receiver. Why both????
    TIA for any help.
Share This Page
