ScanGauge II - What gauges do you use?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Scott Lunt, Aug 13, 2014.
  1. Scott Lunt
    Scott Lunt Junior Member
    34
    Washington DC
    Just getting comfortable in my new-to-me 2006 Prius. Thanks to everyone for the help so far. One of the items I bought is a ScanGauge II, which works fine. I'm wondering what others use their ScanGauge for - what data do you show? What would be most useful for average around-the-town type of usage?
    some things I want to know:
    - temperature INSIDE the car (this must be available somewhere since the "auto A/C" must be measuring against something)
    - safety issues regarding the motor: coolant temperature; other ?
    - efficiency/performance items: miles remaining in tank;
    - tire pressure (??)
    I know that a couple of these are available, but not sure about things like temp and tire pressure.
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I use
    RPMs
    Voltage
    Primary water temp F
    Underhood air temp F. (I find it escalates when it is over 95 F outside)
    Although I do not drive in town mostly 49 to 61
  3. Sabby
    Sabby Active Member
    295
    127
    SoCal
    Right now I am using RPM, Amps, Load and Ignition. Once it starts to cool off, in the fall, I will replace Ignition with coolant temp. I find in the summer the car warms up so fast there is no need to track the startup coolant temp. In the winter I like to keep track of the warmup cycle.
    You can't track tire pressure. I wish we could track oil temp but that is also not available.
  4. Mendel Leisk
    38,247
    Normally I'm using: accumulating mpg, Instant mpg, rpm and coolant temp.
    Just in the past few days I've sub'd the XGauges: hybrid battery sensor #2 and hybrid battery speed (for rpm and coolant temp).
  5. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    RPM, Amps, Coolant temp, and current trip average fuel consumption. I would like to get Ignition timing also.
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    During hot weather I am monitoring the HV Battery temps and Cooling Fan:
    - Middle battery temp sensor - BT2
    - Cooling Fan % speed - CF0
    - Cooling Fan air flow temp - BtT
    - Cabin Temp - RmF
  7. kenoarto
    kenoarto Senior Member
    395
    Chicago, IL
    what goals/ranges do you try to achieve?
  8. Robert Holt
    Robert Holt Senior Member
    1,313
    888
    My four choices for mt Scangauge are currently:
    Engine coolant temperature --Fahrenheit
    Batter Temperture 2 : Celsius
    Battery Fan Motor
    Gallons Per Hour fuel consumption
    I might substitute in Inverter Coolant temperature for Gallons per hour, but there is an upper and lower cooling loop, apparently, and I am not sure which is more diagnostic of long-term inverter health.
  9. WilDavis
    WilDavis Senior Member
    2,489
    2,153
    49
    SG II (upper) RPM (ICE) btV (sec) BTV (traction) MPG
    SG II (lower) Soc (traction) ICE (°F) plus 2 more, (will check and report later, or take a look at the photos...)
    Later:
    (upper) RPM(ICE) VLT(sec)
    btV(Trac) AVG
    (lower) Soc(Trac) MPG
    Bta(+/-)(Trac) ICE (°F)
    #9 WilDavis, Aug 14, 2014
