1. Offline
    Woelfl New Member
    Start a Conversation
    Jul 1, 2012
    Vandenberg Air Force Base, California
    Your Vehicle Year:
    Somehow I keep acquiring new scratches on my temperature control display (the glass part that reads outside/inside temp and air flow level). I tried to cut out a ipad screen protector but it looks terribly sloppy! I would buy one if I could find one that fit the Prius specifically..... any ideas?
  2. Offline
    • Moderator
    Sep 22, 2005
    6,973
    1,739
    N.Y.
    Your Vehicle Year:
  3. Offline
    schmuly Junior Member
    May 5, 2012
    82
    BC
    Your Vehicle Year:
    Or try a motorcycle shop, they have great products for cleaning faceshields and plastic windshields on bikes.
  4. Offline
    Woelfl New Member
    Jul 1, 2012
    Your Vehicle Year:
    Thanks guys. I kind of wanted to prevent the scratches instead of fixing them once they inevitably build up. Maybe your both right, I could just get it cleaned up once it gets to be too much. It would be nice if someone made a screen protector for it though... I'm sure i'm not the only one that doesn't want to scratch the glass. I think there was some kind of protector on it when I drove it off the lot but I can't say for sure.
  5. Offline
    Andrewlcox Junior Member
    Oct 25, 2011
    51
    Decatur, Illinois
    Your Vehicle Year:
    I can't believe they use such soft plastic for this area of the dash. I have only used a light touch with a microfiber cloth and mine is scratched too.
  6. Offline
    spiderman wretched
    Jul 5, 2009
    6,749
    1,171
    Alaska
    Your Vehicle Year:
    I wonder if there is some kind of clear, spray coating that would protect the surface?
  7. Offline
    tanasit Member
    Mar 26, 2012
    289
    42
    Philadelphia
    Your Vehicle Year:
    4"x12" 3M Scotchgard 8 Mil Paint Protection Film Bra - Clear | eBay
    Perhaps this will do but you need to make the template of the display first.
    I will do that just by pressing a piece of paper over the display, then use your finger nail to score along the edge of the display and cut off with scissors. Double check the fitting and trace it over to the 3M clear bra, cut and test fit again before the wet application.
  8. Offline
    dialing_wand Junior Member
    Mar 12, 2012
    Montreal, QC
    Your Vehicle Year:
    Same here. Top-shelf microfiber cloths, soft-touch from myself and still scratchy-scratchy.
  9. Offline
    GerryL Master Model Railroader
    Jul 12, 2012
    142
    Minneapolis, MN
    Your Vehicle Year:
    Here's a tip: clear packing tape. Trust me, it really works. I've got a piece on my two watches, on the LCD display of my still camera, and on the LCD display of my video camera. It's as clear as water (as long as you don't get an air bubble under it) and if it does get scratched or scuffed, you just peel it off and replace it. My watch faces would've been hacked up long ago if it wasn't for this tip!
  10. Offline
    spiderman wretched
    Jul 5, 2009
    6,749
    1,171
    Alaska
    Your Vehicle Year:
    Tell us who it works on your displays.
  11. Offline
    Jul 12, 2012
    142
    Minneapolis, MN
    Your Vehicle Year:
    Well, I finally got the time to put the packing tape on my display tonight -- it works and looks great.
    I used 3M clear packing tape (the stuff you use to seal up boxes). I laid an oversized piece down over the control panel, then used a brand new X-acto knife to slice around the top and sides, using the seam of the plastic as a guide for the blade. I then carefully cut a semi-circle around the fan knob, and finished up using the bottom seams to guide the X-acto blade again.
    Once it was on, I carefully squeezed out all the air bubbles, and slightly pricked the ones that couldn't be squeezed out.
    It's crystal clear and will stay that way (just as it has on my watch and camera screens). But if if it gets scratched, it's simple enough to pull the tape up and replace it.
    spiderman likes this.
  12. Offline
    spiderman wretched
    Jul 5, 2009
    6,749
    1,171
    Alaska
    Your Vehicle Year:
    thanks for responding to my poorly worded request. post a pic if you can.
  13. Offline
    Jul 12, 2012
    142
    Minneapolis, MN
    Your Vehicle Year:
    I'll try posting a pic tonight, but there's really nothing to see -- it looks like the control panel. You can't see the tape on it at all.
Share This Page
