Screen brightness goes up & down, have to turn it off at night
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PriOliver, Sep 11, 2014.
  1. PriOliver
    PriOliver New Member
    Portland, OR
    I'm having to turn off the screen when I drive at night to avoid the distraction of it weirdly and endlessly jumping up and down in brightness. It happens when I turn down the brightness of the dashboard instrument cluster to an intermediate level. With the instruments at max, the screen brightness is constant. With the instruments turned off completely, then too the screen is fine. But neither of those settings is safe at night. I don't want to drive without a speedometer, and I don't want to drive with the instruments brightly reflecting in the windshield. Any of you know what's the cause and/or fix of this thing with the screen? I'd love to know! I suppose I'll be having to pay the dealer or somebody to fix it, but I'd rather not go in clueless--and I suppose being clueless, it could be something simple I'm just overlooking. Thanks for any thoughts. BTW, this is re: our 2008 Prius, options package 4
  2. JC91006
    16,470
    8,383
    There is an extended warranty out on the combination meter, when it goes out intermittently . If you feel it has gone out before, they'll replace it free of charge....just by you telling them that.
  3. PriOliver
    Portland, OR
    Interesting about that warranty. Superficially it seems to be about something different, but my car's problem clearly has _something_ to do with combo meter, and although I didn't mention it, the combo meter might be weird in another way too: when I turn the knob to adjust the brightness, it doesn't happen gradually, because mostly as I turn it nothing happens, until at a certain point it jumps over just a few hairs of a turn, so it's impossible to adjust it exactly to an in-between brightness. Anyway, I guess I should find a mechanic to tell me if it's related to the warranty issue.
    Does anybody else have a theory?
    48,946
    sounds like a bad potentiometer, which probably isn't covered.
    PriOliver likes this.
  5. PriOliver
    Portland, OR
    Are you talking about the screen brightness, instrument brightness control or both? I'm thinking most of this stuff is integrated circuits. Are there pots in there as individual elements?
  6. bisco
    48,946
    i'm thinking instrument brightness, it's a thumbwheel?
  7. PriOliver
    Portland, OR
    Yes, a thumbwheel...according to the manual. We just bought the car and my wife is driving it. I don't think I've played with it myself yet.
  8. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
  9. xliderider
    7,848
    3,102
    Honolulu, HI
  10. JC91006
    16,470
    8,383
  11. PriOliver
    Portland, OR
    Thanks so much! I wonder if fixing the pot/rheostat is likely to stop the slow periodic oscillation of the display screen bias. I suppose it might. How confident are you that a broken one of these is the cause of my thumbwheel weirdness? I'm guessing it's something you've seen before...?
  12. bisco
    48,946
    i didn't think anything affected the mfd brightness except headlites?
  13. xliderider
    7,848
    3,102
    Honolulu, HI
    I'm almost 100% certain that replacing the illumination rheostat (thumb wheel) switch will fix your problem.
    The symptoms you describe are from the contacts in the faulty switch making intermittent/poor contact, especially in the midrange of the thumb wheel setting. That's why it works at the extreme settings, full bright, or off.
    SCH-I535
  14. PriOliver
    Portland, OR
    You mean in mfds normally, or do you mean you thought that's what I was describing about my own mfd? I don't know if the headlights have anything to do with it. What I observe is that I dim the speedometer and as long as it's dim the mfd will jump back and forth in brightness--every 10-30 seconds or so (I haven't checked the interval or if it's strictly periodic). It's dark out when I've done this, so I suppose the headlights are on.
  15. PriOliver
    Portland, OR
    Awesome, xliderider! Thanks again!
  16. PriOliver
    Portland, OR
    I've never bought a part off eBay or done much in the way of repairs. I wonder if I could get that rheostat a lot cheaper at a Pick-n-Pull type (DIY salvage) place. Then I could get a little practice accessing the thing on a junker before taking a hammer to our new car.
  17. xliderider
    7,848
    3,102
    Honolulu, HI
    Accessing the switch is really easy. Take a look at the directions for the oem foglight installation here:
    2010 Prius OEM-quality Fog Light Kit Now Available! | PriusChat
    Just look at the installation directions in the first post in the thread. Specifically, the part about installing the foglight switch in the dashboard, which is right next to the rheostat dimmer switch.
    SCH-I535
  18. PriOliver
    Portland, OR
