Seatbelt mod
Discussion in 'Gen 2 Prius Audio and Electronics' started by YYR123, Sep 6, 2012.
  1. YYR123
    YYR123 Junior Member
    23
    Has anybody Jumpered out the switch on your driver side seat belt
    That way it doesn't chime when you don't have it latched?
    Friend of mine did this with his 2010 Toyota truck so it seems doable but I just wondered if anybody had tried it with their Prius yet
  2. Britprius
    Britprius Senior Member
    5,149
    1,654
    Herefordshire England
    The only chime I find annoying is the one for reverse as it seems to perform no useful function except to annoy. The seat belt chime lets you know if you or your passenger has not buckled up "an offence in UK/EU".
  3. YYR123
    23
    Yeah I find reverse alarm very annoying as well that's number one my seatbelt alarm number two
    Yes still a ticketable offense for Texas not to have one also
    But it's not an offense to remove the offensive chime
  4. Sarge
    Sarge Active Member
    732
    84
    Milton, Ontario, Canada
    2014 Prius Plug-in
    Technology
    Do you guys realize that it actually explains how to disable the reverse beep in the owner's manual? Too lazy to go look it up, so I Googled it... here you go:
    How to Disable Reverse Beep in a Toyota Prius: 11 steps - wikiHow
    Enjoy the blissful silence. (y)
    EDIT: I just re-read the instructions and realize that it says this only works on North American cars, so BritPrius may be out of luck. :unsure: I'd give it a try anyway in case whoever wrote this is wrong...?
  5. Britprius
    5,149
    1,654
    Already tried and it does not work in the UK.
  6. YYR123
    23
    Wow nice I will try it later thanks
  7. Ericw
    Ericw New Member
    La Crosse, WI
    I was able to use these steps to turn off the reverse beep, was very annoying. If it could actually be heard outside the vehicle I could see it's usefulness. As it was, I think Toyota was just trying to see how much beeping I could take before smashing stuff to stop it. You saved my dash Sarge, appreciate ya!
  8. YYR123
    23
    Yeah me as well as works very easy - but would have never figured it out by myself but it has stopped !!
  9. Sarge
    Sarge Active Member
    732
    84
    2014 Prius Plug-in
    Technology
    You're most welcome, always happy to help a fellow Prius driver. (y)
  10. bedrock8x
    bedrock8x Senior Member
    1,479
    129
    Go to eBay and search for seat belt buckle.
  11. Gun owning Prius driver
    397
    73
    Downey, California (Los Angeles Area)
