Featured Seems Draining your Lithium Ion Battery is really bad
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by drash, May 5, 2025 at 9:00 AM.
  1. drash
    drash Senior Member
    2,533
    1,284
    Upstate NY
    Scientists make surprising finding that all electric vehicle drivers should hear: 'Has been largely overlooked until now'
    South Korean scientists decided to study the process of charge depletion in batteries. Surprising them were the effects of running your battery down to near depletion and found damage to the cathode. The damage is caused by oxygen combining to lithium, forming lithium oxide, at around 3 volts. This then causes the cell to swell when interacting with the electrolyte. This effect seems to be exacerbated in nickel enriched lithium batteries, like NMC (Nickel Manganese Cobalt) or NCA (Nickel Cobalt Aluminum) more so than others, like LMO (Lithium Manganese Oxide) or LFP (LiFePO4 - Lithium iron phosphate).
    For those who want details, like me or @bwilson4web here’s the original study:
    Don’t use your battery until it runs out! | POSTECH
    How does this affect your EV or PHEV? Good question. Not sure which manufacturer allows this or if they allow this to happen, how much of the battery sees 3 volts or less during discharge. Most manufactures usually have rigidly defined voltage level cutoffs at both high and low ends. For most Lithium batteries, nominal operation is around 3.7 volts. The studies also don’t really take into account of temperature either.
    Take aways? Just charge the darn thing when you can and don’t run it down to 0. Just remember this saying (not sure if it’s old), only bad things happen when you run out of gas or charge. Maybe this is a little like keeping your gas tank half full, maybe an EV should be kept around 50% when not being used. YMMV
  2. hill
    8,585
    Gee .... don't know but it'd seem to have been a whole lot easier to look at the original Tesla roadsters whose software allow them to run to depletion ..... at which point they were bricked - rather than doing a study ..... this study took what - an extra 10 years or more ?
    Just sayin' ..... not so sure this study revealed much of a surprise.
    Tesla And The Bricked Batteries: What's Really Going On? | The Truth About Cars
    Next surprise study - putting hands in fire causes burns
    #2 hill, May 5, 2025 at 9:03 AM
    MAX2, PrimeDan, Zythryn and 1 other person like this.
  3. bwilson4web
    15,939
    I'm replacing my 2019 Tesla Model 3 traction battery later today:
    • 6 years and 150,000 miles
    • failed thermal valve found that probably overheated battery the last two years
    • ~$9,000
    Everyone has learned a lot about EV battery health and best practices since 2019 when I got mine. Today, I can run a battery health check from the software and have access to in-car diagnostics. Furthermore, the Tesla maintenance manuals are online and I've used them as needed. Self driving lets me choose between:
    • Hurry mode and 4 miles/kWh, saves ~6 minutes every hour
    • Chill mode and 5 miles/kWh, adds ~6 minutes every hour
    With new knowledge, tools, and techniques, I expect to get at least similar if not better performance and life from the replacement battery.
    PrimeDan likes this.
  4. hill
    8,585
  5. BiomedO1
    BiomedO1 Senior Member
    2,596
    1,395
    SacTown, Ca
    Most of this is very old news and the data was available way back in the 1980's; if someone cared to look for that information. Most of that research was related to cell phone battery usage.
    Honda had a recall to software reconfigure the charge/discharge cycles on their gen1 civic hybrid and Toyota re-engineeried their original traction pack and control units on their gen1 Prius.
    PrimeDan and hill like this.
  6. mikefocke
    3,865
    1,743
    Sanford, NC
    What kind of warranty do you get with the replacement battery? Is it third party or OEM?
  7. hill
    8,585
    Record number of battery swaps on one Tesla I could find online was 14 batteries. Of course the guy had nearly 1¼ million miles & mostly supercharged .... that meant ~90K miles per. Thus - do L2 charging (under 20kWs) if you can.
    BiomedO1 likes this.
  8. austingreen
    austingreen Senior Member
    13,629
    4,172
    Austin, TX, USA
    I couldn't find that one. Did find this on my search
    14 motors, 3 batteries. So really this guy averaged over 300,000 miles each on the original plus the 3 replacements. The initial model S did have some problems with its motor units. Glad they worked that out before I bought my model 3.
    hill likes this.
  9. hill
    8,585
    Sorry about that. Thanks for the correction. Had it backwards
    https://insideevs.com/news/699413/highest-mileage-tesla-model-s-3-batteries-14-motors/
    austingreen likes this.
  10. bisco
    50,833
    how many manufacturers disclose what voltage the cells are at when the car shuts down?
  11. PriusCamper
    PriusCamper Senior Member
    11,877
    4,819
    Pacific Northwest, USA
    Another reason why Lithium-Ion is no longer the best chemistry for batteries... Too hot Lithium Ion fails, too Cold Lithium Ion fails, too little charge Lithium Ion fails, too much charge Lithium Ion fails.
    No wonder why Chinese car manufacturers like BYD and battery manufactures like CATL are already 3 years into cars running Sodium-Ion, which you can discharge down to 0.0volts for safe shipping and it causes no damage. It's more tolerant of heat and cold, as well as overcharging too.
  12. austingreen
    13,629
    4,172
    Austin, TX, USA
    sodium ion today is much bulkier and heavier than lithium ion including Lithium iron phosphate. These have great potential to replace the 12V lead acid battery, but need a lot more progress to work as the main battery in an ev. Right now Lithium Iron Phosphate is the main chemistry byd and catl are using, with smaller lighter batteries using the more expensive lion chemistries. Glad they are doing research but sodium ion like solid state is still years away from massive commercialization in plug-in vehicles.
    Trollbait and hill like this.
  13. PriusCamper
    11,877
    4,819
    Classic Texan response to Chinese technological advancements... Pretend that the rapidly declining 11% of the world's population as white people is magically superior than 2/3rds of humans who live in Asia and SE asia... Then when they introduce Sodium-Ion EVs in China 3 years ago act like it never happened and lithium is still superior. Then when they refine a way in a Chinese lab to have a higher density sodium-Ion chemistry than even Lithium-Ion can provide act like you never heard about that... Then when BYD starts rolling super affordable Sodium-Ion EVs off their assembly line that customers pay less than $15K for a brand new EV make sure to ban sales of BYD in the USA and tell everyone its "still years away from massive commercialization in plug-in vehicles" even though they've been doing it for three years already.
    I look forward to all the people who are investing way too much money in planet harming Lithium mines going broke as fast as Elon is.
    #13 PriusCamper, May 5, 2025 at 4:09 PM
  14. austingreen
    13,629
    4,172
    Austin, TX, USA
    What kind of Anti american bs is that. I've set up factories in china. I know the terrain and problems. I also follow chinese as well as world wide technology. So big china expert what percentage of chinese vehicles use sodium ion instead of lithium ion? Since the chinese poured research dollars in lithium iron phosphate do you think those batteries are going away? If so why?
    Well that is just ignorant and anti social. When they commercialize sodium ion then it will take off if the energy density and price make sense. That may not be until solid state. Right now lithium can be mined in environmentally correct ways. The bigger problem is cobalt and nickle, which is why lithium iron phosphate is taking off. This is slightly less energy dense but doesn't rely on problem metals. If byd produces a great ev in china, I'll problem drive it over there. Unfortunately with the trade war I don't know if american's will still be welcomed to sell our goods and services over there.
    Sodium-ion solid-state could solve range and cost issues | Automotive World.
    hill, MAX2, bisco and 1 other person like this.
  15. bwilson4web
    15,939
    There is one and I’ll share once I get the car back.
    hill and austingreen like this.
  16. ChapmanF
    16,997
    So if I boil down a lot of words in #11, #12 and #13, part of it seems to come down to PriusCamper saying this:
    and austingreen saying this:
    That looks like a pretty good setup for a "who's right?" question.
    Or are both right in some wonky way, like "yeah, they've been working on x for three years but most of their production is still y"?
    mudder likes this.
  17. hill
    8,585
    LOL. BROKE ..... LOL
    2019 through 2024 we bought ~40k in Tesla stock. It paid so well in our ROTH - that even covering the depreciation of the X & S - we still had enough to buy another vehicle with 7,500 of tax credits. Three car's EV credits makes a total of $22,500 which would have otherwise just been a tax liability.
    If someone truly believes in something, they do what's called "putting your money where your mouth is". Or how 'bout, put up or shutup", etc. It can be assumed that anyone whose hair is on fire over Elon Musk, is shorting stock, right? Not just a social justice warrior, tap tapping away on their keyboard ..... or is recklessly shooting up tesla stores, & setting chargers on fire (that every EV owner now uses) & spray paint vandalizing cars owners (who WERE likely aligned w/ liberal ideology until such morons do such things) ....
    So - how short on tesla?
    figures .......
    oh - it's never disappointing to hear off topics of a hate-filled rant - regardless of subject matter
    #17 hill, May 5, 2025 at 4:44 PM
  18. PriusCamper
    11,877
    4,819
    Yeah, "unproven at commercial scales" even though BYD's Seagull EV was designed for Sodium-ion and is quickly transitioning into it and ramping up production. Of course commercial sales don't count in China or in the rest of the world, only in the US, right? Meanwhile the whole world is turning its back on the US as a trading partner to outright incompetence of its leadership and a whole new global economy is currently being negotiated without the US being involved anymore because the fix is in.
    Here in America we just pretend that it isn't happening and dismiss and deny that JMEV's first Sodium Ion rolled off the assembly line in 2023, then Yiwei started doing the same, the BYD's Seagull. And granted there's a transition going on that takes time, but you're acting like the transition hasn't even gotten started and it has:
    "The first mass-produced vehicles with sodium-ion batteries have started rolling off the production line in China. The new electric hatchback is from the Yiwei brand, part of Anhui Jianghuai Automobile (JAC) which Volkswagen owns 75 per cent of. The German giant also owns 50 per cent of JAC's parent company, JAG." VW-backed brand starts building sodium-ion-powered electric cars | CarExpert
    "### **Current Production (2024–Early 2025)**
    1. **Initial Commercial Models**:
    - Two sodium-ion battery EVs are confirmed in production:
    - **JMEV EV3** (by Jiangling Motors, using Farasis Energy batteries): Range of 251 km, energy density of 140–160 Wh/kg .
    - **Yiwei 3** (by JAC Group, using Hina Battery cells): Range of 252 km, with deliveries starting in January 2024 .
    - These are compact, low-cost models targeting urban commuting, with production likely in the thousands per month initially (exact numbers undisclosed) .
    2. **Capacity Indicators**:
    - Farasis Energy and Hina Battery are ramping up production, but their output is still in early stages compared to lithium-ion batteries .
    - BYD and CATL are investing heavily in sodium-ion technology, with BYD’s 30 GWh plant (joint venture with Huaihai Group) slated for future production, but not yet at full scale .
    ### **Forecast for Mid-2025–2026**
    1. **Expansion Plans**:
    - **CATL** aims to mass-produce its **Naxtra** sodium-ion batteries by late 2025, targeting 175 Wh/kg energy density and 500 km range for passenger EVs. This could significantly boost monthly output if adopted by automakers like Chery .
    - Farasis Energy plans to release a second-generation battery (160–180 Wh/kg) in 2024 and a third-gen (180–200 Wh/kg) by 2026, potentially enabling broader EV adoption .
    2. **Market Growth**:
    - Analysts project sodium-ion batteries could capture **5–12% of the energy storage market by 2030**, with EVs being a key segment .
    - If current pilot projects (e.g., JAC, JMEV) succeed, monthly production could scale to **tens of thousands** by mid-2025, especially for micro-EVs and two-wheelers .
    ### **Key Constraints**
    - **Energy Density**: Sodium-ion batteries still lag behind lithium-ion (e.g., 140–175 Wh/kg vs. 250+ Wh/kg), limiting use to shorter-range vehicles .
    - **Supply Chain**: While sodium is abundant, manufacturing infrastructure is nascent compared to lithium-ion .
    ### **Conclusion**
    Exact monthly figures remain undisclosed, but production is expected to grow **exponentially** from 2025 onward, driven by CATL, BYD, and startups. By mid-2026, China could be producing **10,000+ sodium-ion EVs monthly**, contingent on technology improvements and market demand .
    For real-time updates, tracking announcements from CATL, Farasis, and JAC Group would be advisable.
  19. austingreen
    13,629
    4,172
    Austin, TX, USA
    how many seagul evs with sodium ion is byd going to produce? The current seaguls are LFP.
  20. PriusCamper
    11,877
    4,819
    Yeah, you and Austin are so delusional you don't even understand the overleveraged financing that Tesla was built on and the fact that no car company has endured such a rapid decline in popularity which only just started half way through Q1-2025... The sustained numbers of their demise in Q2-2025 are going to be way worse and the type of financing scheme that's paid for their factories are way more vulnerable to insolvency then any car maker has ever done before. But just like Elon, your only reaction is a childish belief that global protests against the company are the people who are wrong and they're probably all being paid to protest because who's ever motivated by anything but money, right?
