Seller told me his Prius takes 95 Octane. Can I switch to 87?
Discussion in 'Newbie Forum' started by 7Lowe, Sep 6, 2013.
  1. 7Lowe
    7Lowe Junior Member
    28
    Riga, Latvia
    I just bought a used Prius and the seller said (after the deal) that "it takes 95 octane." Now it never came up before because I had read up fairly extensively online and the manual I saw online said 87.
    Is it ok to drop back to 87? I ask because I used to work at a gas station and the owners would put the premium grades on sale for a weekend at the same price as the regular. They said that the cars "got used" to the higher grades and then wouldn't run as well if you went back down. So, it was worth the very slight loss during the sale since it would get more Premium buyers in the long run (which was much more profitable.)
    Is there any truth to that or am I ok to switch to 87?
    48,862
    never heard of such a thing, but what do i know?:confused: i think your fine on 87 like the rest of us.
  3. SteveLee
    SteveLee Active Member
    645
    179
    North Carolina
    I
    87 makes my trusty steed happy happy happy, and me too.
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Are you still in Portugal? Does you county measure Octane via RON? If so, 91 RON Octane is what you want.
    If you have moved to the US, then Octane is measured via AKI and 87 AKI Octane is what you want.
    Octane rating - Wikipedia, the free encyclopedia
    Gaƫtan Lafrance likes this.
  5. 7Lowe
    7Lowe Junior Member
    28
    Riga, Latvia
    I am still in Portugal. Thanks a lot for the info!
    I had no idea there were different octane measurements.
    JMD likes this.
  6. Mendel Leisk
    38,106
    Total nonsense. There's actually VERY few cars that need higher octane, it's purely due to high compression ratio of the engine, and it would be specified in the owners manual.
    The oil companies don't mind though, they've got to sell the higher octane gas to someone...
  7. 7Lowe
    7Lowe Junior Member
    28
    Riga, Latvia
    Just got back from the gas station. 95 was the lowest that they had, so that's what I got. Looking at the wikipedia article above I think that may be the lowest sold here.
    Tank was pretty low (1 pip on display) when I filled up. I think I got about 40L @ 1.64EUR/L for a total of 65.6EUR. Or, in US terms, 10.6Gal @ $8.17/Gal for a total of about $86.60!
  8. Faine
    Faine New Member
    I've always been curious as to if the octane rating in the owners manual was the actual required octane rating for optimal running or the rating on the pump that should be used. I have a friend who is a regional manager for a gas station in the area I live in and he says to take the middle grade in a car that wants 87 octane because the octane rating is what it was measured at when the fuel left the distribution facility and that the fuel you get from the pump is generally 3 to 7 octane lower (depending on how old the fuel is) than the number on the pump. Of course I've never researched that myself, I always thought he knew what he was talking about.
  9. Mendel Leisk
    38,106
    All higher octane gas gives you is greater resistance to pre-ignition. It's harder to ignite.
    With an engine in the regular compression range, with no pre-ignition problems, buying the higher octanes is pointless.
    That said, with computerized ignition systems, the car might be detecting pre-ignition and retarding timing to avoid it. But I think that's a long shot.
    Also, if the manufacturers say regular octane is ok, I can't see them saying "well, that's if you get it fresh from the factory".
  10. bisco
    48,862
    i don't know anything about octane, but my 3 pri have all run fine on 87. knocking was the only thing i ever heard about growing up.
  11. wjtracy
    wjtracy Senior Member
    11,309
    3,586
    Northern VA (NoVA)
    OK I was going to say 10.6 gal sounds high for USA 2005 but we have flexible fuel tank, I think you probably have a fixed volume gasoline tank which is nice you can get a little more in there than we can re: cruising range.
  12. 7Lowe
    7Lowe Junior Member
    28
    Riga, Latvia
    All those numbers are estimates from memory. I know my friend looked at the receipt and said 40 something liters, so I just went with 40. I remember the price on the pump was 1.6x, and he thought it was 1.64. Half the receipt tore off in the machine so we didn't see any price there. At any rate it's fairly accurate.
    Also, you are right that tank is fixed volume.
  13. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    I live at 4000 elevation and 85 octane is just fine at this level. 87 octane should be fine.
  14. Jeffrey Jessup
    78
    29
    Reno, NV
    Sure makes our $3.70/gal. sound like a bargain!
  15. telmo744
    telmo744 HSD fanatic
    2,168
    764
    Portugal
    Welcome to Priuschat.
    There are some european chatters here.
    Portuguese mode selected:
    Eu sou um deles. Chateio muitas vezes
    :p
    Bem vindo!
  16. 7Lowe
    7Lowe Junior Member
    28
    Riga, Latvia
    Obrigado (that's most of the Portuguese I've learned so far), I'm glad to be here on the forum and especially glad to be here in your country. So far I've found it to be incredibly beautiful and am somewhat in awe of the age and history of the place.
  17. telmo744
    2,168
    764
    Portugal
  18. massparanoia
    massparanoia Active Member
    697
    467
    Virginia
    US AKI is RON*0.95. So 95 RON would be 90.25 AKI. So with 91 US octane you're all set.
  19. ToyotaPrius2005
    ToyotaPrius2005 Junior Member
    36
    San Jose, CA
    I have been using 87 octane for the last 189,000 miles and have seen no problems
    would be interesting to see if there is any gas mileage difference when using the different octane
