1. Offline
    StonePony9/1 New Member
    Aug 8, 2009
    Message Count:
    Your Vehicle Year:
    Any reason why they put the shifter the way they did? I mean you shift up towards the front of the car to go in reverse and you shift down or towards the rear of the car to go forward. I am very happy for the beep when backing up. It has saved me more than once usually when I want to go in reverse and realize there is no beeping.
  2. Offline
    claridiva New Member
    May 24, 2009
    Message Count:
    109
    Dallas, TX
    Your Vehicle Year:
    You will get used to it very quickly, and then you will get in a standard automatic car and think how strange it is! It took me a day or two to adjust and yes, the beep saved me too! But now it is so quick and easy to shift, I love the way it is designed.
  3. Offline
    LRKingII New Member
    May 31, 2009
    Message Count:
    680
    130
    Idaho
    Your Vehicle Year:
    When you are in a car with a auto tranny and the shifter is on the floor which way do you move the shifter to get into reverse from nuetral or drive? which way do you move it to get to drive from reverse or neutral?
  4. Offline
    wfolta New Member
    Jun 13, 2009
    Message Count:
    290
    51
    Washington DC
    Your Vehicle Year:
    Seemed backwards to me at first, but the settings are in the standard order that I've seen on all the automatics I've used: P R N D 2 1. It's different because P is a button and because it snaps back to the default position.
  5. Offline
    radiocycle New Member
    May 10, 2007
    Message Count:
    473
    63
    Morro Bay, CA
    Your Vehicle Year:
    Well, what about the standard 'H' pattern? On a 'three speed' reverse is forward and low and high are back, on a stick shift.
    1 people like this.
  6. Online
    fuzzy1 New Member
    Message Count:
    4,363
    716
    Your Vehicle Year:
    This is the one I remember best, but is not the only stick shift pattern I used where 'R' is forward.
    Having always had stick shifts in the collection of home and farm vehicles that I drive, and only stick shifts for the past quarter century, the Prius shift pattern seems natural, even though it doesn't match any of my recent cars.
  7. Offline
    jay_man2 jay_man_also
    Jun 11, 2009
    Message Count:
    1,246
    138
    Manassas, VA
    Your Vehicle Year:
    Seems natural to me, and similar to the stick patterns I'm used to (except you don't have to push down first to go into reverse).
  8. Offline
    wfolta New Member
    Jun 13, 2009
    Message Count:
    290
    51
    Washington DC
    Your Vehicle Year:
    DELETED. (I misread the quote.)
  9. Offline
    jim256 New Member
    Jun 18, 2009
    Message Count:
    307
    67
    Eastern NC
    Your Vehicle Year:
    I think this also comes into play, NHTSA Standard 102:
    Standard No. 102: Transmission Shift
    Lever Sequence, Starter Interlock, and
    Transmission Braking Effect
    Scope and Purpose:
    This standard specifies the requirements for
    the transmission shift sequence, a starter interlock,
    and a braking effect of automatic transmissions,
    to reduce the likelihood of shifting
    errors and starter engagement with vehicle in
    drive position, and to provide supplemental
    braking at speeds below 40 km/h (25 mph)"
  10. Offline
    DaleR New Member
    Jun 11, 2009
    Message Count:
    Suwanne, GA
    Your Vehicle Year:
    I agree. The shifter should be push forward to go forward and pull back to go back.
  11. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    I dunno about you but I shift back (to D) to go forward and then up (to R) to go backwards on a regular automatic.
    1 people like this.
  12. Offline
    LoraJ New Member
    Jul 4, 2009
    Message Count:
    482
    55
    Your Vehicle Year:
    It will be an adjustment for me. With my stick shift 1st is up, reverse is down. Must focus. :)
  13. Offline
    Jul 12, 2007
    Message Count:
    10,558
    430
    Adelaide South Australia
    Your Vehicle Year:
    It IS an automatic isn't it? Why compare it to a manual? Lots of mnuals have reverse to the right aand forward or to the left and forward. Nissan even had a 5 speed manual where first was to the left and back!
  14. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    Message Count:
    17,752
    2,804
    Northern Michigan
    Your Vehicle Year:
    Shifters follow this pattern for historical reasons. In early transmissions, it was easier to build the gearing this way. The pattern is now used because of familiarity. It's the same reason we use QWERTY keyboards: they don't make sense anymore, but it's what we are all used to.
    Tom
  15. Offline
    Politburo New Member
    Feb 15, 2009
    Message Count:
    966
    206
    Your Vehicle Year:
    FMVSS 102 only specifies the direction of shifting for column-mounted automatic shifters (neutral->drive must be clockwise). It's otherwise silent on shift patterns, except to require that the shift pattern be in the view of the driver (except for standard "H" manual transmissions).
  16. Offline
    lesturner Taming the Dragon - Tennessee
    May 17, 2007
    Message Count:
    63
    Bremen, IN, USA
    Your Vehicle Year:
    All I ask is to not change it now.... I have finally gotten used to it....
  17. Offline
    Jun 11, 2009
    Message Count:
    1,246
    138
    Manassas, VA
    Your Vehicle Year:
    Reading this thread has screwed with my head. Yesterday I threw it into reverse by mistake. :p
  18. Offline
    May 10, 2007
    Message Count:
    473
    63
    Morro Bay, CA
    Your Vehicle Year:
    Good thing you had the constant BEEPING going on huh??;)
  19. Offline
    DeanFL 2010 owner - 1st Prius
    Apr 13, 2009
    Message Count:
    986
    321
    Leesburg Florida USA
    Your Vehicle Year:
    Me too - and looking around for the clutch with my left foot....
    Folks - the bottom line here. Standard practice for all automatic transmission floor-mounted shifter autos is P-R-N-D-L. From front to back.
    Not logical as noted before, but so be it. We're stuck with it. Same with the Prius.
    Imagine if Toyota decided to go against the grain and make the Prius 'logical' and reverse the order to D-N-R. Product liability lawyers would make a fortune. And body shops.
    1 people like this.
  20. Offline
    bruceha_2000 New Member
    Jan 2, 2004
    Message Count:
    2,648
    37
    South Burlington, VT
    Your Vehicle Year:
    Except:
    When you get in your 'normal' auto "stick on the floor" car, you pull it backward to hit ANY gear since Park is all the way forward. You pull it backward to reverse out of the driveway, then pull it backward AGAIN (twice) to go forward. ONLY when you want to back into a parking space do you push it forward to go in reverse.
    The BEAUTY of the Prius shifter is that you do not EVER think about what 'gear' the transmission is in - EVER. In other cars you HAVE to think "I'm in Drive, I have to pull it 1 back for 2nd, 2 back for 1st. Push it 1 stop forward for Neutral, 2 stops to get to Reverse, 3 stops for Park." Some automatics also force some right/left gating in the shifter. Yeah it becomes automatic, but your brain has to evaluate the whole process EVERY time you move the shifter. With the current Prius shifter pattern your brain HAS to think, "I want to go in reverse so I have to push it forward". "backward is backward" would require no analysis.
    People already have to 'get used' to the joystick shifter, same as they would have to get used to the gating in any 'normal' car. Any NEW driver is not going to think: "How does this relate to my old car".
    Since there IS no Park on the shifter, I say make it LOGICAL. Just like a boat throttle - Forward to go forward and backward to go backward. N and B are used rarely, *I* would make it (H is Home):
    F B
    H-N
    R
    Reminds me of the newlywed husband asking the wife:
    "Why did you cut the end off the roast before putting it in the pan?"
    W: "My mother always does"
    W: "Mom, why do you cut the end off the roast before putting it in the pan?"
    M: "My mother always does"
    W: "Grandma, why do you cut the end off the roast before putting it in the pan?"
    G: "Because my pan is too small for the roast."
    REALLY, there ARE reasons to NOT do it the 'same way it was always done before' !!!!
Share This Page
