1. Offline
    fmvs New Member
    Start a Conversation
    Feb 3, 2008
    western NC
    When driving my right knee is literally an inch below the shift knob. I have this fear of knocking it into reverse if I alter my position while driving.
    To me the positions of "R" and "D" seem counterintuitive. I've only had my Prius for a week and a half but I invariable put it in reverse when I want to go forward. If "D" were up I wouldn't be as concerned over bumping the knob into reverse position. Does the Prius transmission protect itself from a dangerous shift (ie reverse while at highway speed) like some vehicles or would it alow itself to be destroyed?
  2. Offline
    JimboK One owner, low mileage
    May 1, 2006
    2,817
    170
    Chesterfield, VA
    Your Vehicle Year:
    Yes, it's well protected. You won't be able to shift into R at speed. You could, however, shift into N.
    It might at first seem counterintuitive to you, but it's similar to any automatic transmission shifter. You move the lever down for D, up a notch for N, and up another notch for R.
  3. Offline
    effwitt Paparazzi Magnet
    Jul 28, 2007
    225
    Eagan, MN
    Your Vehicle Year:
    Shifting with the Prius is done via the computer instead of a mechanical linkage, so it's a "request to shift" that can be denied if it would cause damage. If you're driving at freeway speeds and attempt to select reverse, you'll hear a beep and nothing else will happen.
  4. Offline
    ForTheGlory New Member
    Feb 14, 2008
    296
    Maryland
    Your Vehicle Year:
    I was just about to post the same thing about standard automatic shifters.
    On one of the first days I had my car, I hit the Park button while still moving a few mph when I was pulling into a parking space. I have no idea what I was thinking. The car slowed to stop quickly, but didn't lurch or anything. I haven't noticed any problems since doing that, so my fingers are crossed.
    Perhaps pressing Park at low speeds first sends a command to the brakes?
  5. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    Are you quite tall? I was just wondering why your knee is so close to the shifter.
    Tom
  6. Offline
    Jun 27, 2007
    1,682
    97
    Out there, somewhere
    Your Vehicle Year:
    I'd be more worried about the fate of my knee in a crash than the shifter.
  7. Offline
    edthefox5 Senior Member
    Jul 25, 2007
    2,456
    398
    Clearwater, Florida
    Your Vehicle Year:
    I first thought so too but then remembered I once had a Dodge van back in the early 70's that had a shifter on the dash. It was the same way. Park all the way up and D down so maybe Toy did some research and saw how early American dash shifters were set up. I got a feeling Toy research's everything. I bet its your first dash shifter eh? Anyway like most weirdness in this car you will quickly adapt and like it. Good luck!
  8. Offline
    joerdie New Member
    Jan 23, 2008
    61
    Cincinnati Ohio
    Your Vehicle Year:
    Thats odd, I am 6'1" and have not had issues with getting my knee close to the shifter. I know that many people do complain that the seats dont slide back far enough though. Are you very tall?
    The shifter is upside down in my opinion as well though. You will get used to it. It took me about two weeks before it was second nature.
  9. Offline
    judymcfarland Queen of Moral Indignation
    Nov 27, 2006
    578
    Glendale, WI
    Your Vehicle Year:
    I had the same counterintuitive thought when I first got my Prius - in fact I'm glad she beeps in reverse because then I KNOW that's the gear I'm in. Now I'm so used to it that I don't think too much about it. I agree the "up to reverse" is similar to the floor automatic shift in my Cavalier - Park (all the way forward) thru R N D L L2 (all the way back) - but the "push (up) to go forward" impulse does seem reasonable, too.
  10. Offline
    okiebutnotfrommuskogee Senior Member
    Mar 2, 2007
    1,813
    Tulsa, OK
    Your Vehicle Year:
    Some of you guys are too young. Maybe you never drove an old standard shift car with a column shifter. (three on the tree)
    It was pull then up for reverse and pull and down for first gear. Exactly the same motion for the Prius, except instead of first gear it's drive. The first time I ever drove a Prius the shift knob felt completely natural. The movement is so short and so easy that it think it is one of the car's best features.
    I suggest that those of you who have trouble with it don't disable the reverse beep. By the way, mine is disabled.
    Also, all the 1955 Chrysler products with automatic transmissions, except maybe trucks, had a little gear selector lever on the dash. Reverse was at the top. The next year they went to push-buttons.
  11. Offline
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    The shift knob seemed backward to me too, but in fact that shifting pattern is a defacto standard that has been used for years. I suspect it was based on the needs of a mechanical gear box.
    Tom
  12. Offline
    joerdie New Member
    Jan 23, 2008
    61
    Cincinnati Ohio
    Your Vehicle Year:
    Well, i didn't start driving until the 1990's. Every manual that I owned had the "non tree" stick.
  13. Offline
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    Three-on-the-tree and the standard three-speed floor shifter both used what was called the "standard shift pattern", which is the same one that the Prius uses.
    Tom
  14. Offline
    Mar 2, 2007
    1,813
    Tulsa, OK
    Your Vehicle Year:
    I guess that I am a bunch older.....The first car that I drove was a 1949 Dodge Pickup and it was almost new at the time. Makes me kind of sad, because there are so many neat vehicles just over the horizon and one of these days I am going to be too old to drive them.
  15. Offline
    jayman Senior Member
    Oct 21, 2004
    13,448
    587
    Winnipeg Manitoba
    Your Vehicle Year:
    Geez, don't tell me you also learned to drive a "three on the tree?" I am now feeling seriously old, and I doubt even heavy drinking will cure that
    Although I'm willing to try
    gluk-gluk-gluk-gluk-gluk-gluk-gluk-gluk <clink>
  16. Offline
    • Moderator
    efusco Troll Slayer
    Nov 26, 2003
    19,828
    1,032
    Nixa, MO
    Your Vehicle Year:
    So did I...some POS Chevy P/U of my dad's and the clutch barely worked. Super sensitive to stalling and my dad had little patience with my learning curve. But once I got that down I could drive anything with a clutch.
  17. Offline
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    When I was a park ranger, I drove an old Chevy pickup truck with a three-on-the-tree. The shifter linkage was completely worn out, so there were no indents for gears. All of the shifting was by feel and using just the right wrist action to snap it into gear. I didn't have to worry about locking it.
    Tom
  18. Offline
    Oct 21, 2004
    13,448
    587
    Winnipeg Manitoba
    Your Vehicle Year:
    Geez, this is now getting seriously creepy.
    Same POS rusted out used up Chevy pickup, except it belonged to my uncle, my dad's brother. An inline 6, and for some reason those things were geared so high you *had* to slip clutch or it would poop out
    My dad had a '68 with a 327 and a 4 speed. He wanted me to learn on a junker before trusting me with his pride and joy. Dad's truck was a special order, nothing fancy. The 327 and Muncie was a breeze to drive.
    I think that is the reason why I want to find a 67-68 Chevy and rebuild it. Many fond memories
  19. Offline
    Oct 21, 2004
    13,448
    587
    Winnipeg Manitoba
    Your Vehicle Year:
    I bet the synchros were completely trashed as well. No need to even use the clutch, just grind by feel
  20. Offline
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    "Errrnt, errrnt, EErrrrnt, clunk...there it is; got it."
    Tom
Share This Page
