Shift the rear-view mirror up
Discussion in 'Prius c Accessories and Modifications' started by jondoig, Nov 9, 2014.
  1. jondoig
    jondoig Junior Member
    We've had our Prius C for a few weeks and we're generally happy, but a couple of issues irk me. One is the restricted rear vision due to the small rear window and large rear pillars.
    Another is the rear-vision mirror itself, which is set so low in the windscreen it frequently obstructs my view of the road. Lowering the driver's seat helps a bit but my wife and I are trying to avoid having to adjust this twice a day.
    I'm wondering if I can shift the mirror up higher. Has anyone done this, or have advice? I've never modified a car at all before.
  2. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
  3. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    I have our mirrors turned upside down and use clip on wider mirrors (flat, non distorting vs convex wide angle). It works quite well.
    SCH-I535
  4. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    If there are two swivels, one at each end of the mounting rod, then you should be able to swivel it up a couple of inches higher.
    Just be careful not to put TOO much pressure on the mounting point on the windshield; you can break it free there and getting a good re-attachment can be problematic.
  5. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    The PC mirrors are adjustable to a slight degree as Easy Rider 2 mentions.
  6. akaryanreynolds
    akaryanreynolds Junior Member
    los angeles
  7. xliderider
    7,848
    3,102
    Honolulu, HI
    Where do you get the lift bracket?
    OP, I'd recommend a flat, non distorting mirror:
    #7 xliderider, Nov 27, 2014
  8. akaryanreynolds
    los angeles
    xliderider likes this.
  9. Ashley7
    Ashley7 Active Member
    545
    222
    Oregon
    2019 Prius
    The attached page from the manual (2012) shows that the mirror can indeed be adjusted up. I found that I no longer had an obstructed view when I adjusted the mirror all the way up. If you are taller, then perhaps you will need to pursue the other mods outlined above. (Of course I just noticed that this post is nearly three weeks old, so hopefully you've already found a solution).
    Bigboi likes this.
  10. jondoig
    Read the manual? *Adjust* the mirror? D'oh!!!
    Thanks everyone for all the great suggestions. (And I've learnt I need to star my post after I send it, if I want to be notified of replies.)
    ztanos likes this.
