Should I do it?
Discussion in 'Newbie Forum' started by kidA, Jul 20, 2009.
  1. Offline
    kidA New Member
    Jul 20, 2009
    Message Count:
    Top Secret Testing Facility
    Your Vehicle Year:
    I currently drive a 2007 Audi RS4 and go roughly 15,xxx miles a year. I average around 14mpg which isn't too bad in my opinion. However, I am looking into getting a Prius so when I go on long trips I don't have to stop as often/worry about my fuel.
    My concern is that after coming from a car that handles so well in all weather I will find myself getting stuck often with the Prius, especially in snow. Does it handle well in snow/rain/etc or should I stick with my RS4? :confused:
    ps: I understand that this is a Prius forum lol so please try to keep it honest :)
  2. Online
    • Moderator
    May 11, 2004
    Message Count:
    13,921
    1,217
    Far-North Chicagoland
    Your Vehicle Year:
    I know that here in Chicagoland I haven't had a problem with snow/ice/rain/etc.
    There are members here from Canada. Some from Alaska. I've seen a picture of our resident postal carrier driving his Prius through the snow and there's someone who doesn't want to get stuck. John's driven a Prius since, what?, 2001 in Minneapolis and says he's had no problems.
    I'll let them speak for themselves.
    1 people like this.
  3. Offline
    Bica2go New Member
    May 21, 2009
    Message Count:
    321
    Boston, MA
    Your Vehicle Year:
    You can do some searches on the site for winter driving. There are many Prius owners in the US and Canada in the snow zones. The only significant issue I recall is when the snow gets over 6" on the road because of the low ground clearance. This winter will be my first experience with the Prius, but in the past I haven't had problems with FWD cars in the snow. I do like AWD in the rain so getting used to the Prius may take a bit.
    My other car: Audi A4 3.0 quattro <g>
  4. Offline
    smartalec89 The Official Alaskan
    Nov 16, 2008
    Message Count:
    133
    anchorage, alaska
    Your Vehicle Year:
    Well I guess I am your man to answer this. I currently live in Alaska and I have been here my entire life. I drive a lot in the winter and decided to switch from a dodge caravan to a prius. You, like most people assume the prius can't handle it... trust me it can! I drove through a 14" snow dump we got one night. Never had a problem with traction. I just bought the vehicle in November 2008 though. I drove it without studs all winter too. Then to add to this... My sister drives a RS4 and I like the prius handling better than it. I have spent plenty of time driving both to give you an honest answer. I personally would get a prius IMHO.
  5. Offline
    kidA New Member
    Jul 20, 2009
    Message Count:
    Your Vehicle Year:
    You like the prius handling more than the RS4's!!???
    Does she have a manual or automatic?
    I've driven a prius and liked it, but I get scared thinking about it trying to get uphill in snow.
  6. Offline
    djasonw New Member
    Jul 13, 2004
    Message Count:
    812
    Belle Harbor, NY
    Your Vehicle Year:
    I've had an Audi A4 and that car with Blizzaks was virtually unstoppable in snow. Only thing that hindered it was very, very deep snow. As long as the road is plowed and you have good snow tires on the Prius then you'll be fine. I would NOT drive will all seasons in the winter in the snowbelt because you're just asking to get stuck. The issue isn't with the Prius but with its over protective traction control system. If you are going uphill and have marginal tires, you're not going to make it. If you have snows, then more than likely you'll have no problem. The stability control (if so equipped) will also be a plus too. If I'm not mistaken aren't the new 2010's all contented with stability? I may be wrong.
  7. Offline
    Spartane New Member
    Jun 4, 2009
    Message Count:
    149
    39
    Mississauga, Canada
    Your Vehicle Year:
    I own a 2010 Prius, so it will be interesting to see how it does this year when the snow comes.
    While I've not yet driven a Prius in snow, I rented a previous model Prius (likely a 2008) when I was on vacation in San Diego last summer, and I felt the traction control kick in and shut down power to the car for about a second or two when I hit a wet piece of road while turning a corner. I can imagine what it would do if this happened in snow; I suspect that it would instantly get stuck.
    That said, I haven't noticed this kind of behavior at all yet in the 2010. In fact, I squeaked the tires yesterday while accelerating and there was no loss of power at all -- the car just went.
    So I'm hoping that I won't experience any unusual problems this winter with the all-season tires ( although that remains to be seen). I figure if worst comes to worst, then I'll just add a pair of snow tires and then all will be well.
    I've never driven an Audi RS4, so I can't compare it to a 2010 Prius. But driving a Prius in stop and go city traffic is like driving no other car. It's peaceful and relaxing because the gasoline engine is off. There's no automatic transmission cycling up and down repeatedly as you inch forward. Also, you don't have the clatter of the air conditioning and the engine cooling fans cycling on and off with their vibration and load passed back to an idling engine.
    I now view all other cars as antiques; I look at them the same way I look at a 33 RPM vinyl record -- good in its day, but that day has passed.
  8. Offline
    Feb 26, 2007
    Message Count:
    7,431
    983
    Carmichael, CA
    Your Vehicle Year:
    14 mpg is pretty bad. I have a Ford Explorer with Auto 4wd and I probably get 15 mpg overall with it. I average about 48 mpg with the Prius.
  9. Offline
    kidA New Member
    Jul 20, 2009
    Message Count:
    Your Vehicle Year:
    A high revving V8 redlining at 8300rpms while having 420hp and rear-biased AWD is definitely worth 14mpg at times :p...barring when I do hit that 8300 I get about 5mpg but it all evens out when I cruise in 6th gear.
    I'll miss the RS4 if I trade it for a prius but I'm getting sick of stopping every 200 miles when I'm making good time :D
  10. Offline
    Nov 16, 2008
    Message Count:
    133
    anchorage, alaska
    Your Vehicle Year:
    Yes! I like the prius handling more! She has an automatic. Get some good Hakka 5's if you have hills to go up. Other than that it won't slide easily and if you take it easy the Traction Control won't do much. Most of the people on here probably just expect it will accelerate the same it does when the pavement is dry as when its icy/wet and it doesn't.
  11. Offline
    The Electric Me Go Speed Go!
    May 22, 2009
    Message Count:
    2,987
    578
    Undisclosed Location
    Your Vehicle Year:
    You want honesty? Okay. I'm going to say don't buy a Prius. Why? Because if your happy with 14 mpg, then you aren't really buying a Prius because you want the primary benefit which is great gas mileage and low emissions. At less than 16000 miles a year, if your primary reason is just so on those rare occasions you do go on a long trip you might not have to stop as much or worry about fuel? That's not reason enough. If you haven't even purchased yet and you are already worrying about snow and rain handling vs. what you have now, which you proclaim handles well in all weather, again I'd say keep what you have. Also a 2007 with less than 16000 miles per year? That's almost new.
    From what I have read and hear, with good tires and proper handling The Prius can do alright in troublesome weather, but a 4 wheel drive it is not. That's not a primary strength of the Prius.
    If that is an expectation, then the first time you slip out, or lose traction in The Prius you are going to be thinking you made a mistake.
    From the tone and presentation of your original post, I'm going to recommend passing. I think you need more reason to want a Prius than just the fact that it might be less troublesome as far as fueling up for long trips.
  12. Offline
    jestoy7 New Member
    Jul 8, 2009
    Message Count:
    238
    25
    Jacksonville, FL
    Your Vehicle Year:
    How can you afford to take the depreciation hit on a 2007 RS4? Audis depreciate like crazy (sucks because I think they are great cars) and going from the top of the line a4 to a Prius is a quite a change. Sure the Prius comes with a lot of ammenities and its an awesome value (I just bought a 2010) but they are very different cars. Such as: AWD vs FWD, 400+hp vs 134hp, sport suspension vs stock suspension, 6 speed transmission versus CVT.
    My first impression from reading your posts is that you will get bored with the Prius. If your only reason is to save gas, think of the financial hit you'll take on selling your Audi as gas money. As well as drive the car easier and save on gas that way too. If you do get a Prius, I would recommend getting the most bells and whistles to keep you entertained because the newness will wear out like its wearing off on your RS4.
  13. Offline
    kidA New Member
    Jul 20, 2009
    Message Count:
    Your Vehicle Year:
    The RS4 actually holds it's value pretty well because it is rather rare and Audi enthusiasts love them. I believe there is only something like 2000 of them in the US.
    I actually have a 911 GT3 that I track regularly so I can always use that when I want to fulfill my need for speed :rockon:
    I think I'll end up having a blast getting 50+mpg with the Prius!!! :D
    Thanks for the help and honesty!
    Anyone else have opinions/suggestions?
  14. Offline
    a_gray_prius Rare Under-30 Priuschat Member
    Jun 13, 2008
    Message Count:
    2,193
    323
    Chicago, IL
    Your Vehicle Year:
    I agree, keep the RS4 since you barely drive it. Especially if you really feel you need AWD/4WD for rain/snow (I'm happy with FF). My Prius handles fine in rain and snow, but then I know not to over-drive it (this is coming from someone with an Evo+Motons). At 16k a year, it's just not worth it for you and you'll just end up with a different set of complaints.
  15. Offline
    kidA New Member
    Jul 20, 2009
    Message Count:
    Your Vehicle Year:
    Got one!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :rockon:
  16. Offline
    Nov 16, 2008
    Message Count:
    133
    anchorage, alaska
    Your Vehicle Year:
    Welcome to Prius.... Congrats
  17. Offline
    usbseawolf2000 HSD PhD
    Sep 22, 2004
    Message Count:
    9,659
    1,270
    Queens, NY
    Your Vehicle Year:
    The fun in driving does not wear off, not at least for me after 3+ years.
    I become part of the car and feel connected to HSD.
  18. Offline
    Spartane New Member
    Jun 4, 2009
    Message Count:
    149
    39
    Mississauga, Canada
    Your Vehicle Year:
    Welcome to a whole new world of driving!
  19. Online
    KK6PD _ . _ . / _ _ . _
    Mar 24, 2008
    Message Count:
    3,083
    455
    Los Angeles
    Your Vehicle Year:
    DITTO!!!! Well except I have a 4Runner........
  20. Offline
    Muhahahahaz New Member
    Jul 15, 2009
    Message Count:
    129
    CA
    Your Vehicle Year:
    16k miles a year is "barely" driving a car? I use my car almost every day... and I drive well below 10k per year. Probably 6k-7k?
    That must mean I produce even less emissions than the rest of you. :p
Share This Page
