1. Offline
    Apr 13, 2004
    Message Count:
    14,718
    519
    South Puget Sound, WA
    Your Vehicle Year:
    the stats are impressive. anyone heard of these guys? what are they doing with this thing?
    should we tell GM? looks to be a great option for the Volt...
    http://www.electricmotorsco.com/main/media/?pg=media
    40 mpg in a retrofit on a Ford F-150... that would be impressive
  2. Offline
    donee New Member
    Aug 15, 2005
    Message Count:
    2,958
    183
    Chicagoland
    Your Vehicle Year:
    Hi Dave...,
    This is a very simple system. The only issue would be the durability of the dry-clutches. Otherwise, should work well. Its neat, that they can run both motors as drive motors, then reconfigure the clutches after accelleration so that the motor closest the engine is used as a generator to recharge the battery at a different shaft speed than the drive shaft. This does not have to happen, but it allows the engine to run at an efficient speed while the vehicle is at low speeds. The clutch closest to the drive shaft then has to handle the most torque, and would be most prone to failure. The design issue is if they are going to be able to realize this in the common transmission diameters without any gearing. I gues that is what the e-compounding is about, but I am under the impression that motors are allot more expensive than gears.
  3. Offline
    Apr 13, 2004
    Message Count:
    14,718
    519
    Your Vehicle Year:
  4. Offline
    Feb 25, 2004
    Message Count:
    14,314
    1,331
    Spokane, WA
    Your Vehicle Year:
    They're talking about a series hybrid. Good idea if you don't mind being 100% dependent on gasoline. Make it a PHEV and you can get a little of your energy from the grid. But I'm extremely skeptical that a vehicle of that size, weight, and power would get 40 mpg. Note that it was a representative of the company that said that they hope or expect to get 40 mpg. They did not say they had any test results.
  5. Offline
    Rokeby Member
    Jan 21, 2008
    Message Count:
    2,890
    591
    Ballamer, Merlin
    Your Vehicle Year:
  6. Offline
    Apr 13, 2004
    Message Count:
    14,718
    519
    Your Vehicle Year:
    series hybrid, yes expandable PLUS 2 way electron flow is a completely different ball game. besides being able to charge an on board charge storage (EESU of course!!) it can also provide 100 amps of electricity.
  7. Offline
    Feb 25, 2004
    Message Count:
    14,314
    1,331
    Spokane, WA
    Your Vehicle Year:
    But it's still burning gas! Portable generators, of course, have their uses. But they become obsolete when you can no longer afford to buy the gas.
  8. Offline
    Apr 13, 2004
    Message Count:
    14,718
    519
    Your Vehicle Year:
    very true, but we also have to be realistic. even if EESU's hit the market tomorrow morning, it will still take years to convert from gas to electric. more likely decades.
    the key here is efficiency. the Prius is a great step towards where we need to be, not a solution in any way, just progress and that is what this engine appears to be, progress, nothing more. simply much better than what is available. if it takes inefficient Fords off the street and doubles their performance, i am all for that
    current engines are woefully inefficient. gas a ton of energy, but we only manage to take advantage of a few hundred pounds of it.
  9. Offline
    Feb 25, 2004
    Message Count:
    14,314
    1,331
    Spokane, WA
    Your Vehicle Year:
    I have mixed feelings. I will drive the most sustainable car I can. But I think we need a clean break. I know a lot of folks feel that slight improvements are moving in the right direction, but I see this in the same light as I see the economist who is happy when unemployment increases at a slower rate than in the previous interval. You've still got more people, not fewer, out of work.
    With the number of cars on the road increasing, as the population grows, we're burning more gas every year even as the most efficient cars are getting more efficient.
    We need a clean break.
    I agree with you that "realistically" this is not going to happen. But as long as we burn more fossil fuel each year than we did the year before (ignoring occasional dips during recessions) then we are moving in the wrong direction, not the right direction, and I do not see a handful of slightly-more-efficient cars as an improvement.
    So, to the question of whether Toyota should build a slightly-more-efficient monster pickup truck, I say: No. Toyota (and others) should build wind turbines, solar cells, and electric cars.
  10. Offline
    Apr 13, 2004
    Message Count:
    14,718
    519
    Your Vehicle Year:
    daniel, i agree 100% and if it were up to me, i would tax gas so fricking high that mass transit would no have to be subsidized from all the fares they would be collecting.
    i would make a $25,000 solar upgrade look like a bargain compared to a monthly bill from Exxon
  11. Offline
    Feb 25, 2004
    Message Count:
    14,314
    1,331
    Spokane, WA
    Your Vehicle Year:
    Yep. We're on the same page!
Share This Page
