Slow charge on my iPhone 5
Discussion in 'Gen 3 Prius Audio and Electronics' started by WolfpackBill, Aug 16, 2014.
  1. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    I have a 2010 IV with JBL navigation system and I have a 50-minute drive home from work everyday and when I leave work, my phone usually shows 25% battery life remaining. When I get to my car, I plug it into the USB port so I can use it as my iPod and charge it up. By the time I get home 50 minutes or so later, I'm only up to 35% sometimes 40%. I don't every use my phone as I drive because I always place my phone in the center console and almost no data being transmitted. There're times where I used a charger that plugs into the power port beside the USB port and charge my phone instead and just listen to XM.
    Anyone has that problem or is it just the equipment with a low amperage port?
  2. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    I could be wrong, but my understanding is that most USB ports (laptops, tablets, etc.) don't put out enough power to do the "quick" charge you get using the AC adapter at home or the power port charger. My phone came with a slow charge adapter and I paid a little extra to get the quick charge adapter. YMMV
    xpcman likes this.
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Yes, the USB port is slow to charge. I have the same results when recharging my iPad.
    From your avatar I assume the Wolfpack is a reference to NC State? If so, hello to a fellow NC and Wolfpack member.
    WolfpackBill likes this.
  4. qdllc
    qdllc Senior Member
    1,358
    396
    This.
    I've co-opted my iPad charger for my iPhone because it takes less time. When I had my iPad at work, I left it plugged into the USB of the PC overnight to charge.
    The good thing is that if you do plug up your iPhone while driving, it will charge while turned on. That's better than nothing. An iPad only charges on a USB's output if you click the power button to put it into sleep mode.
  5. Bullet Salvador
    109
    44
    Los Angeles
    It's simple, USB charging units are rather 1.1 amp (usually charges phones) or 2.1 amp (usually charges tablets).
    If you want it to charge faster try getting a 2.1 amp charger versus using the USB. =)
  6. jdcollins5
    5,131
    1,338
    Wilmington, NC
    We are talking about the USB port in the car.
