1. Offline
    Fibb222 New Member
    Start a Conversation
    Apr 25, 2006
    1,499
    98
    Your Vehicle Year:
    Lately, my 2004 prius seems to be acting somewhat differently - when I decelerate (lightly braking) from say 40 mph to 20 mph, it sometimes gently surges/thumps a wee bit. i.e. the drivetrain pulses or like the braking motor hiccuped. There is no check engine light or anything. I seem to be getting normal mileage and everything else appears normal but I thought I might spend $80 at the dealer to have the car checked over. I have about 7 months/11000 kms left of drivetrain warranty on the vehicle.
    Anybody ever notice anything like this? It's hard to describe. It's a subtle thing, but I haven't noticed it before two weeks ago. I am pretty in tune with the way the car normally behaves. Thanks
  2. Offline
    Apr 9, 2007
    1,531
    70
    Virginia
    Your Vehicle Year:
    Is the road bumpy?
  3. Offline
    abq sfr New Member
    Mar 28, 2007
    690
    Albuquerque, NM
    Your Vehicle Year:
    Funny, I just posted a similar thread here. If you hit rough road or a pothole, it almost feels like the brakes quit braking for a second, and I think they do. Its normal, and disturbing if it happens as your are closing the distance on the car in front of you :eek: I think iit might be caused by a sudden transition from motor regen to friction brakes caused by the rough road/pothole.
  4. Offline
    Fibb222 New Member
    Apr 25, 2006
    1,499
    98
    Your Vehicle Year:
    Hmmm... Funny I never noticed it before after a year and a half of driving it. Also, I think it has stopped... I'll post more info if things change again.
  5. Offline
    Cessna157 New Member
    Oct 22, 2006
    Cincinnati, Ohio (CVG)
    It is just the anti-skid system acting normally. If you are braking and slip into a pot-hole or similiar road hazard, the tire will slip just a bit. It seems the anti-skid on the prius is very sensitive, and activates at the slightest change in tire speed. Mine does this occasionally, and sometimes the light will flash once or twice.
  6. Offline
    Mar 27, 2004
    7,634
    838
    United States
    Your Vehicle Year:
    Grit, gravel, sand, oil, squished bugs, moguls, washboarding, or water on the road, anything that makes the tires lose their grip momentarily can cause this.
  7. Offline
    tripp Which it's a 'ybrid, ain't it?
    Oct 23, 2005
    4,719
    78
    Denver, CO
    Your Vehicle Year:
    On my way home from work I have to decent a VERY steep hill on a dirt /gravel road. I get this a lot and it's annoying and a bit disconcerting, esp when there's snow/ice. It is probably the one thing I wish that they would have implemented better.
  8. Offline
    fed123 Junior Member
    Oct 24, 2007
    88
    New Jersey
    Your Vehicle Year:
    I find that I can prevent this if I see a bump coming by taking my foot off the break.
  9. Offline
    Oct 23, 2005
    4,719
    78
    Denver, CO
    Your Vehicle Year:
    it's tough though when you're on a steep inline because the car will actually accelerate, even in 'B' mode. If it's snowy it's even more dodgy to do that. You really just have to creep along and try to not build up too much momentum.
  10. Offline
    Fibb222 New Member
    Apr 25, 2006
    1,499
    98
    Your Vehicle Year:
    After driving more around town today, I've determined it is not traction control or anti-skid. The engine or motor surges slightly for moment usually as I'm slowly braking/decelerating from 65 km/h to 35. It's a new thing and I don't know what is causing it but I don't think it has anything to do with traction. Puzzling...
  11. Offline
    Sheepdog C'Mere Sheepie!
    Mar 12, 2008
    1,104
    Sanford FLorida
    Your Vehicle Year:
    Tripp, Do you go to B mode when coursing down that big hill? seems it would help but may not help the braking lapse. I havent seen it yet here but I live in Florida and the hiway exit is the steepest thing I see.
  12. Offline
    SSimon New Member
    Feb 27, 2006
    1,397
    N/W of Chicago
    Your Vehicle Year:
    Fibb,
    I've had this happen to me and it's very sporadic. My happenings had nothing at all to do with terrain conditions. Seems to happen mostly when I'm in electric mode. It's a very definitive cycle pulse. It hasn't occurred in quite some time now.
  13. Offline
    hyo silver Away
    Mar 2, 2005
    14,882
    1,190
    Sunset
    Your Vehicle Year:
    I've noticed this, too, though it's not a new thing on my 2004. The brakes seem to stop working for a split second, even under ideal conditions. It's different than the abs or traction control, which I've also felt when the roads are slippery. Could it be the transition between electric and mechanical brakes? Wouldn't it be better for those two systems to overlap, instead of having a gap?
  14. Offline
    Fibb222 New Member
    Apr 25, 2006
    1,499
    98
    Your Vehicle Year:
    I think the transition between electric and the friction brakes on a gradual deceleration is supposed to happen at 8 miles/hr or something. But it does feel like that.
Share This Page
