Smaller sidewall tire size
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Daves09prius, Sep 8, 2011.
  1. SteveLee
    SteveLee Active Member
    645
    179
    North Carolina
    I
    Thanks Dave. The better handling characteristics seems to be a consistent report. I wonder how much of the MPF hit was from the wider stance. Hey, I really like that tire size calculator! That is very helpful. Thanks.
  2. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    The general Altimax tire didn't hurt mpg's very much maybe 1 or 2 miles per gallon, not really enough to make a noticeable difference. The Goodyear eagle GT tires cost me 4 to 8 mpg. I should mention that both are not LRR tires. I bought them because I was trying to keep costs down. I guess you either save money when you buy the tires and pay more over time ... Or pay more upfront and save over time. The next set of tires I'm switching back to the Altimax or getting a LRR set.
  3. SteveLee
    645
    179
    North Carolina
    I
    Yeah, a LRR tires seems to be the better long term play. But I am wondering especially about the effect of the width of the tire on MPG. I have heard some say there is no difference in MPG from the 185 to the 205. But others have indicated there is a difference. But it's hard to measure when the kind of tire changes too I guess.
  4. Britprius
    Britprius Senior Member
    5,194
    1,912
    Herefordshire England
    Steve, I actually got a significant improvement going from 195's to 205', but I believe much of this improvement "not all" was down to the choice of tyres.
    Another thing to consider is how much motorway/freeway driving you do as the improvement may be less the faster you go, "at the speeds that aerodynamics really begin to take effect" at lower speeds you will gain more from the lower rolling resistance of the wider tyres. Another effect of the wider tyre is that you will not slow down as much when taking bends, therefore not loosing as much inertia and again saving fuel. Every little bit adds up.
    John (Britprius).
    Daves09prius likes this.
  5. SteveLee
    645
    179
    North Carolina
    I
    John, so you're saying the 205 tire will get better MPG than the 185, all other things being equal? A wider stance doesn't increase the amount of rubber on the road and therefore resistance? I have heard the argument that the wider tire is not adding rubber to the road as the car weight is the same but carried over a wider stance thus with less rubber on the road from front to rear of the contact area. If the result is very similar amount of rubber on the road, then the question comes to mind, why a savings then? What factors result in any possible increase?
    You mention a couple of other factors. Do wider tires have a lower rolling resistance, all other things being equal? And why would wider tires not slow as much in a turn, maybe they don't roll toward the sidewall as much, that would increase resistance? It all sounds very minimal in the effects. Or is there more than I am considering? Likely so.
    But thanks for the great info.
  6. Britprius
    5,194
    1,912
    Steve in the UK the rolling resistance of tyres now by law has to be measured against a standard rating along with wet grip and noise, and published at the point of sale so that true comparisons can be achieved .
    I do not profess to fully understand how the width of a tyre affects the rolling resistance but would imagine the amount of deflection of the rubber and casing of a given size tyre carrying the same weight reduces as the width increases causing less squirming of the tread on the road surface and saving energy and ware.
    The speed at which you can take a turn is purely down to the fact that the car feels much more stable at a given speed and is able to take bends faster without that feeling of being on the edge of grip so that you do not slow as much for a given bend.
    If you wish to thank someone for a post or information click on the "like" on the right a the bottom of that post. This is the best way of saying thankyou.
    John (Britprius)
    SteveLee likes this.
  7. SteveLee
    645
    179
    North Carolina
    I
    It is an interesting subject. Thanks for your input John. I forget to click on Like so thanks for the reminder.
