1. Offline
    josel777 New Member
    May 5, 2009
    Message Count:
    PDX
    Your Vehicle Year:
    Hi,
    I am new to the forums. I just got my new silver 2010 Prius II tonight. When I picked up the car there was a yellow card explaining the smart key functions. According the card one should be able to lock or unlock the car by touching the handle sensor(s) (refer to attachment). Is this standard on all cars or is this an option?
    [IMG]
  2. Offline
    usbseawolf2000 HSD PhD
    Sep 22, 2004
    Message Count:
    9,659
    1,270
    Queens, NY
    Your Vehicle Year:
    Standard feature for driver's door. Passenger and rear hatch is available only for Prius IV I believe.
  3. Offline
    Jul 12, 2007
    Message Count:
    10,558
    430
    Adelaide South Australia
    Your Vehicle Year:
  4. Offline
    royrose New Member
    Mar 21, 2009
    Message Count:
    347
    38
    Manitou Springs, CO
    Your Vehicle Year:
    I can't see the picture. Which dealer did you buy form and how was your experience?
  5. Offline
    josel777 New Member
    May 5, 2009
    Message Count:
    PDX
    Your Vehicle Year:
    Interesting. For some reason it is not working for me. When I try to lock the car touching the driver's door handle I hear a high pitch sound for a few seconds and nothing happens. When I try to unlock it via the sensor on the back of the handle nothing happens either.
  6. Offline
    josel777 New Member
    May 5, 2009
    Message Count:
    PDX
    Your Vehicle Year:
    I got the car from Wilsonville Toyota. Very easy process.
  7. Offline
    stream New Member
    May 12, 2008
    Message Count:
    2,526
    394
    Long Island, NY
    Your Vehicle Year:
    Could be a bad battery in the fob--have you tried the other fob?
  8. Offline
    Bob_Stan New Member
    Mar 31, 2009
    Message Count:
    70
    Central New York
    Your Vehicle Year:
    I don't have a Gen3, but isn't that backwards? I think touching the sensor area on the handle locks it, and touching anywhere else on the handle unlocks it. Of course it will not lock if the car is not off or a key is in the vehicle.
  9. Offline
    HTMLSpinnr Gen III Forums Moderator
    Dec 8, 2003
    Message Count:
    4,975
    717
    Surprise, AZ (Phoenix)
    Your Vehicle Year:
    The door must be closed. The high pitched sound indicates at least one door has been left open.
  10. Offline
    dtjoint Custom art furniture
    May 23, 2009
    Message Count:
    Southern Oregon
    Your Vehicle Year:
    Check to make sure you do not have the other fob in the car. If a fob is in the car then you cannot lock using the sensor in the door handle. As another poster added, also check to make sure all the doors and the hatch are closed. If the fob is in the car or a door is open the car emits a high pitched noise to warn you when you touch the outside sensor.
    Jerry
  11. Offline
    LaMesaGuy New Member
    May 29, 2009
    Message Count:
    91
    La Mesa, CA
    Your Vehicle Year:
    I have it on my 2010 Prius V w/ATP for the Driver's door, the Passenger door and the rear hatch.
  12. Offline
    Sep 22, 2004
    Message Count:
    9,659
    1,270
    Queens, NY
    Your Vehicle Year:
    Right.... I meant to save Prius IV or above since Prius V contains all the features of IV.
  13. Offline
    DaveSheremata New Member
    Apr 4, 2004
    Message Count:
    251
    Arlington, Virginia
    Your Vehicle Year:
    You mean "say", not "save", right? ;)
    Dave
  14. Offline
    Sep 22, 2004
    Message Count:
    9,659
    1,270
    Queens, NY
    Your Vehicle Year:
    Rgiht. ;)
  15. Offline
    eglmainz New Member
    Jan 21, 2009
    Message Count:
    887
    137
    Chicagoland, IL
    Your Vehicle Year:
    The high pitched sound is indicating that a SK is left in the vehicle, or that the car is in "Ready" mode. Both seem to do this for me, unless key is out of car, and the car is "Off".
    I have a Prius V with the 3 door SKS. I love the SKS system!
  16. Offline
    josel777 New Member
    May 5, 2009
    Message Count:
    PDX
    Your Vehicle Year:
    Thanks Jerry! That was the problem. I forgot to remove the other fob from the car.
    Thank you everyone for the input.
  17. Offline
    yardman 49 New Member
    Mar 26, 2009
    Message Count:
    606
    68
    Northern Kentucky
    Your Vehicle Year:
    I had meant to mention this same issue with regards to rental Priuses, also.
    A couple of weeks ago I rented an '09 Prius. I noticed that it had the SKS, and checked to be certain that it was activated. Everything worked well except that I could not use the SKS to lock the car (getting the one "long" beep indicating something was not right).
    So I began hunting around. I found the extra fob in the lower glove box, in the bottom of the rear "documentation" section. Once I took it out of the car, then the SKS worked normally.
  18. Offline
    Dec 8, 2003
    Message Count:
    4,975
    717
    Your Vehicle Year:
    Those are also valid scenarios. The number of beeps often helps to indicate what the fault is.
  19. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    Message Count:
    17,752
    2,804
    Northern Michigan
    Your Vehicle Year:
    When I first got my 2006 Prius, I found myself frequently saying "Now whet the hell is wrong with this car?" as it beeped at me, only to find out that it was smarter than I am. Welcome to the club.
    Tom
  20. Offline
    greylar New Member
    May 15, 2008
    Message Count:
    283
    37
    Montana
    Your Vehicle Year:
    I noticed on my Gen II that if I have the FOB in the hand that is pressing the button I will get that long beep as well. I guess the car thinks the FOB is actually inside the car.
    G
Share This Page
