Sound deadening and noise reduction project
Discussion in 'Gen 3 Prius Audio and Electronics' started by inseek, Apr 1, 2012.
  1. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    i have a Prius C. i want to reduce the outside noise as much as possible. what would be the best for this job? the peel and stick ensolite?
  2. Okinawa
    Okinawa Senior Member
    1,333
    317
    You are a perfectionist. Great job. You are good at it.
  3. da_crusher
    da_crusher Junior Member
    Salem, OR
    2003 Prius
    I
    Hey davep3913, did you end up using the felt? What is that product called? I am searching on the Perfect Fit website but can't find the product. I live in Salem, OR, and will probably go this route, instead of using the Dynamat. Thanks!
