Speaker in driver's-side door/door vibrations
Discussion in 'Gen 3 Prius Technical Discussion' started by MichaelSpeziale, Sep 15, 2014.
  1. MichaelSpeziale
    MichaelSpeziale Junior Member
    85
    New Hartford, Connecticut
    When there is any degree of bass in my sound system (JBL), the driver's side door vibrates or rattles. If I push against the handle with the controls on it very hard, I can dampen the sound to where it's (almost) nonexistent. Anyone have any idea how I can fix this without bringing it to Toyota?
  2. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Is this recent, i.e. due to wear and tear, or has it always been like this? My 2010 is fine.
  3. MichaelSpeziale
    85
    The car is used and has done this since I got it.
  4. Feri
    Feri Active Member
    761
    144
    It could be that the speaker has been over driven, i.e. excessively high volume, however, since pressure on the door reduces the rattle it might pay to take the door apart to look for loose screws, bolts etc.
  5. MichaelSpeziale
    85
    Is there any instruction guide for disassembly of the doors? I doubt there's a Hayes manual lol
  6. Feri
    Feri Active Member
    761
    144
    Actually there might be a Hayes by now, but if you search this site you might find someone's done it before
  7. defrankond
    defrankond Member
    217
    23
    North Dakota
    Mine does the same thing. But then again my floating console also creaks and pops as well. It's almost like plastic vibrating on the metal inside the door though when heavy bass drops
  8. CARspec
    CARspec Junior Member
    53
    Eden Prairie, MN
    2014 Prius Plug-in
