Speculative : New PEV Prius only using half available LiIon capacity.
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by uart, Apr 23, 2010.
  1. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Considering the 14 mile stated range of the new plugin-prius I was little surprised by the total weight of the battery pack (330 lb). Did this strike anyone else as perhaps a little more than they expected for just 14 miles?
    Heres some rough calculations, admittedly I don't have all the data so it's speculative. Say they only use two of the three packs for EV mode (I think thats what I've read), and also say that only 2/3 of each packs weight is actual battery (the remainder being housing etc). Well thats still 147 lb (67 kg) of LiIon battery. Now given that the energy density of modern LiIon batteries is supposedly 0.1 to 0.16 kW-hr/kg*, then taking even the lowest figure (0.1) that would still equate to about 6.7 kW-hr of EV mode.
    Also, its been estimated that in EV mode the Prius needs about 0.15 kW-hr per km, which translates to about 4.2 miles per kW-h, and I think this is a reasonably accurate figure, maybe even a little conservative. So that would mean 6.7 kW-h should give a range of about 6.7 times 4.2 equals 28 miles, double the quoted value!
    So the conclusion would be that either
    1. I've got no idea what I'm talking about (which is always possible).
    OR
    2. Toyota have somewhat over Engineered the LiIon EV system, probably going for about 70% to 75% maximum charge and about 25% to 30% minimum charge, so as to give a long service life.
    Do these numbers seem in the right ballpark?
    * Lithium-ion battery - Wikipedia, the free encyclopedia
  2. fuzzy1
    10,045
  3. austingreen
    austingreen Senior Member
    13,533
    4,063
    Austin, TX, USA
    Toyota's battery pack is really heavy per kwh compared to the leaf and volt. I would expect that they can really trim it down or increase the range.
  4. Rybold
    Rybold globally warmed member
    2,760
    320
    Southern California
    My iPhone battery goes below 10% before it auto-shuts down. I've had it for two years now. It still holds a full charge like when it was new. I don't understand why the Prius should be any different. Sure, I realize the RATE of change/discharge is different, but does that affect capacity?
  5. Ads_green
    Ads_green New Member
    23
    Oxford, uk
    You are assuming Toyota are going to use the highest density battery it can find. Aside from much higher cost, there is a real problem with heat management. These HD packs get very hot to the point it can catch fire. The tesla has a dedicated cooling system for the battery that use a similar amount of power to a domestic fridge.
  6. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    This isn't the final configuration that we'll see in the production version, from what I understand. Remember, Toyota has always preferred battery longevity over performance and I doubt that will change any time soon!
  7. uart
    uart Senior Member
    4,215
    1,200
    Australia
    What you're talking about there is more related to volumetric density and pack/module construction density rather than mass density. Given the obvious importance of weight to the vehicles overall performance I don't see any reason why they wouldn't be using at least somewhere near current "state of the art" for the mass energy density. Also, I didn't assume anywhere near the highest. The quoted range was 0.1 to 0.16 KW-h/kg and I only chose 0.1, which is about 62% of the maximum.
  8. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Yeah but that's probably still well under 1000 total cycles right. A 14 mile PEV under heavy use could go 1000 cycles in under three years, and if that was enough to wear out the battery then (in the context of the sort of reliability people would expect from modern car) that would be pretty bad.
    I don't think any of us know for certain just how good are the very latest LiIon batteries that the large PEV players are currently developing/testing, but there's lots of sources that suggest that with currently available LiIon technology that you could easily wear out a pack in under 1000 cycles if you mostly use the full capacity with deep discharge/charge cycles.
  9. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Yeah one reason might be the Prius's much smaller pack sizes, so there's relatively more of the weight taken up by the enclosure etc, compared with the Volts much larger pack.
    But I also think that Toyota is probably being really conservative on the longevity side too. I'd say they are aiming for more than 10 years out of those packs under typical usage.
  10. drees
    drees Senior Member
    1,782
    247
    You are assuming that 0% really means 0% and 100% really means 100%... It very likely does not.
  11. austingreen
    13,533
    4,063
    Austin, TX, USA
    Sure but 400lbs for 8kwh usage (16kwh capacity) versus 330lbs for less than 4kwh usage (5.2kwh capacity).
    IMHO panasonic ev may be behind in lithium batteries today. Since toyota is the majority owner they are going to use them. This is one of the troubles in vertical integration. Note that panasonic ev is the leader in nimh batteries so this relationship helped toyota on its current hybrids.
  12. Prius Team
    Prius Team Toyota Marketing USA
    681
    1,817
    CA
    Why speculate when the information is available for all to see?
    Plug-In Demo Program details (slide 32 may be of interest:p)
    -for the record, yes, our priority is longevity, not performance
    More can be found at:
    Sustainable Mobility Seminar
    Enjoy,
    Doug Coleman
    Prius Product Manager
    Toyota Motor Sales, USA
  13. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    I thought the Volt had liquid battery cooling?
  14. fuzzy1
    10,045
    Please run that iPhone for its full cycle nearly every daily, and report back to us when it is 8 years old (42 states) or 10 years old (8 CARB states). Will the original battery still be good enough then?
    I'll bet money to the contrary.
  15. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    About 50% is usable for gen1 Lithium pack. The capacity is rated at 5.2 kWh. I wonder if it is usable capacity or the total capacity.
  16. aforkosh
    aforkosh Active Member
    403
    253
    Oakland, CA
    2023 Prius
    For the 2nd generation, we were told that the battery would not discharge below 40% of capacity nor charge to greater than 90% of its capacity. So, we were actually using only 50% of the actual capacity (90-40). Assuming that Toyota is using same boundaries for the plug-in, I think that the OP has it right.
  17. Erikon
    819
    105
    Rochester, NY
    Yeh, replacing a $10,000 battery pack every few years would get annoying! I'll sacrifice a few miles of range any day!:D
