Speedometer after tire change
Discussion in 'Gen 3 Prius Accessories and Modifications' started by silica, Mar 23, 2011.
  1. silica
    silica Junior Member
    44
    Phoenix
    I'm interested in changing the wheel size from 15" to the 17" size offered by Toyota as an option (I think only on the V). My question is this...if you change the wheels and tires from 15" to 17" does the speedometer have to be recalibrated? If yes, does anyone know the procedure? Something the dealer must perform?
    Thanks
  2. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    420
    Whereabouts Unknown
    I think the outside diameter of the tires, that has contact with the road, is nearly the same for the 15" and 17" wheels. The owners manual says to use the tire calibration button for the navigation system after getting new tires, but I have never had a clear understanding of what it does.
  3. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Not if you keep the same diameter of tire. Go on tire rack and check things out! Hal
  4. silica
    44
    Phoenix
    Thanks for the fast replies. I will check out a tire calculator.
  5. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Some navigation systems use the odometer data and accelerometers to continue tracking your route when you lose GPS signal. Such as in tunnels, parking garages,etc.
  6. silica
    44
    Phoenix
    Just a follow up after checking the tire calculator as recommended:
    The stock tire size is 195/65 - 15
    Going to a 17 in wheel, the following tire sizes offer the diameter of the wheel/tire closest to the stock combination:
    205/50 - 17
    225/45 -17
    The calculated difference in the speedometer reading with these sizes is 0.1 - 0.25 MPH.
  7. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    .25MPH at what speed?
  8. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Your speedometer is off by 1-2mph (fast) from the factory so if you size your tires correctly I wouldn't worry about it. :D
  9. ct89
    ct89 Active Member
    323
    266
    New England
    A nice calculator for evaluating this question can be found at:
    Tire Size Calculator
    225 45/17, diameter diff: -0.03% , speed will read faster
    205 50/17, diameter diff: +0.36% , speed will read slower
    I went with 16" rims and a 205/55 tire...I like the look.
    There is a picture posted here.
    205 55/16, diameter diff: -0.41% , speed will read faster
    I find that compared to my GPS, both the stock tires and these show about 1-2MPH faster on the speedometer vs. the GPS at highway speeds. That's about a 2% safety margin built into the speedometer.
  10. RodJo
    RodJo Member
    423
    56
    Boston
    The numbers from the calculators are based on perfect tire dimensions to calculate a tire's circumference, which are not real-world numbers. The same sized tire can vary quite a bit from brand to brand. For example, your particular brand 195/65 -15 tire might really be a 197/66 - 15. Fortunately, you can find the actual circumference for each tire on the manufacturer's website, typically expressed as revolutions per mile.
    So if you want to be accurate, you would use the calculator as a guide and then lookup the revolutions per mile for each particular tire you are considering. If you want to maintain the same speedometer accuracy, then first lookup the revolutions per mile for your stock 15" tire and then find the 17" tire that's the closest.
