Speedometer and Instrument Panel Dead/Not Working?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BurntWaffle69, Dec 24, 2013.
  1. BurntWaffle69
    BurntWaffle69 Junior Member
    22
    Stuart, Florida
    Hi guys,
    I have a 2006 Prius with 285,000 miles on it, and I have NEVER had any problems with it, and I was VERY satisfied. Today when I woke up, I went to turn on my Prius to warm it up before we left for Christmas, and I noticed that the Speedometer, Gas Gauge, and Instrument panel did not light up. The Blinkers work, MFD works, and the Check engine light pops on and then off after I start the car. Even when my lights are on, the green light in the panel doesn't illuminate.
    I have never had problems with my Prius before. Also, the Hybrid battery reads at 12.3 volts when I tested it, so it shouldn't be the problem. Also, the Hybrid battery was above half way charged when I started it.
    I live in Northern Michigan, and it was -10 or -15 degrees below 0 Fahrenheit, and I read this may be the cause? Yet I am not sure. I have NEVER had this happen before, and I am afraid I'm in for a $2500 repair?
    Any feedback is VERY VERY VERY Appreciated. MERRY CHRISTMAS!
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,605
    4,464
    Texas Hill Country
  3. vskid3
    vskid3 Active Member
    773
    228
    48,990
    i hope you're satisfied.;)
  5. BurntWaffle69
    22
    Stuart, Florida
    Now does this apply to my car? It says it applies to prius with less than 36,000 miles and I have 285,000 miles. Or does this apply no matter the mileage and date you take it in?
  6. bisco
    48,990
    that's the beauty od an EXTENDED warranty.
  7. rjparker
    7,605
    4,464
    Texas Hill Country
    It says 9 years from start of service so yours is good at the dealer through 2015. Or you can look a gift horse in the mouth and pay for it by having your local garage guy it do. Your choice.
  8. BurntWaffle69
    22
    Stuart, Florida
    Thank you so much you guys. You are life savers. I appreciate it SO MUCH! Have a MERRY CHRISTMAS!!! I will be contacting my Toyota dealership in Traverse City soon.
  9. rjparker
    7,605
    4,464
    Texas Hill Country
    Went to Boardman Elementary and lived on Washington St in the 50's.
  10. Reseda Prius
    Reseda Prius New Member
    Reseda, Ca
    I have a Prius 2, from 2006, and the Instrument panel has been working only intermittently. Now it's really gotten bad, and does it every day. The panel goes dark, and the car won't turn off. I have to hold the button down for 4 seconds, but even then there's still some power in the Prius, because I can't lock it, and the radio and windows all still function.
    Please assist!
    The extended warranty was over in 2015, but my Prius only started acting up in 2018. It's been great, so far.....but now they're wanting MAJOR dollars .
    Is there a way to get Toyota to honor the extended warranty, even though it's expired? Toyota obviously KNEW this was a problem.
    thanks for any ideas....
  11. Bobby B
    Bobby B New Member
    SoCal
    Did you ever get any resolution on this? I have a similar problem that just started with my 2006 Prius, 147,000 miles
  12. bisco
    48,990
    bad combo meter
