Speedometer
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Jcone, Sep 1, 2014.
  1. Jcone
    Jcone New Member
    2014 Prius Plug-in
    Just curious whether all PiP speedometers have a +2-3 mph bias. For me it's 2 out of 2 (both 2014 model).
  2. rxlawdude
    rxlawdude Active Member
    701
    219
    So Calif
    2015 Tesla Model S
    Yep. And it's a bit squirrely that in my '04 and '11, if I set the cruise control to 70mph, the speedo would almost always match that setting. On the '14 PiP, the car gets up to 72mph on the display pretty routinely. It's irritating but not significant.
    48,988
    ditto. been there, done that.:)
  4. Barbara R
    Barbara R Junior Member
    44
    2014 Prius Plug-in
    What does +2-3 mean?
  5. bisco
    48,988
    off by 2 or 3 mph.
  6. Potorap
    Potorap Active Member
    345
    148
    Pahrump, Nv
    Yes it is 2 mph for me. However on 2011 prius changed tires and almost matched up.
  7. GregP507
    GregP507 Senior Member
    3,002
    480
    Judging by the fact that everyone seems to be reporting the same speedometer error, it looks like Toyota has either planned this, or they have made the same mistake consistently. I'm seeing 2-3% more speed indicated than actual speed, therefore it's possible that this would translate to what appears to be 2-3% more miles per gallon of gasoline. Not a bad thing for advertising purposes.
  8. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Its planned, but not for the purposes you may think:
    Speedometer - Wikipedia, the free encyclopedia (takes you directly to the "international agreements" section)
  9. GregP507
    3,002
    480
    I still think it's for purposes I described. An accurate speedometer should be the easiest thing to achieve in a car like the Prius.
  10. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    But if every auto manufacturer abides by the "agreement", then that would make MPG relative amongst all vehicles.. which would defeat the purpose of doing it for MPG reasons. And while we're at it, why not just go for the maximum allowable. In the given example, at 80kmh, you can be off by as much as 15%. That would be quite a healthy bump in MPG.
    And as I mentioned in a previous thread where this topic came up, you also have tires issues to contend with. I agree that an accurate speedo should be do-able with today's technology. But how would you account for all the differences in tire rolling diameter amongst different manufacturers, not to mention regular tire wear.
  11. bisco
    48,988
    or maybe it keeps the car from under reporting speed in case of wear or tyre change, and getting a ticket for going 33 in a 30 when your speedo says 30.
  12. GregP507
    3,002
    480
    I'm going to go out on a limb and say that the speedometer could be self-calibrated from the nav-unit, if they wanted it to be accurate.
  13. RRxing
    RRxing Senior Member
    2,518
    1,790
    NEPA
    As mentioned in this and other threads about speedometer bias, in addition to the international agreement, no automaker is going to subject themselves to a lawsuit for under-reporting actual speed. I just realize that my speedometer reads 2-3 mph high, no big deal.
  14. Chazz8
    Chazz8 Gadget Lover
    744
    234
    61
    Central New York
    It is so easy for the Toyota to report a true (let's just say within %1 of Garmin gps) that they did. It is available via the dongle under the steering wheel with ScanGuage II or torque setup.
    I like that you reported +2 to 3 percent higher MPH rather than +2 to 3 MPH higher Greg, as I see the difference between the speedometer and the CAN BUS dongle based reading increase as speed increases.
  15. fuzzy1
    10,045
    That probably won't happen until Nav units become universal, rather than optional or trim-specific.
  16. ggcc
    ggcc Member
    132
    Bay Area, CA
    2014 Prius Plug-in
    I have a Scangauge, my 2007 Prius is matching MPH with Scangauge MPH. My 2014 PiP is 3 miles OFF (3 Miles Higher than the Scangauge).
    - The 2014 PiP 70 MPH Scangauge 67 MPH
    - The 2014 PiP 55 MPH Scangauge 52 MPH
    I saw the ICE is kicked in when PiP speed o meter at 61 0r 62, Scangauge RPM is change from 0 to xxxx around 58 MPH.
  17. Chazz8
    Chazz8 Gadget Lover
    744
    234
    61
    Central New York
    How much is the PiP off at 20MPH?
  18. retired4999
    2,652
    625
    Eau Claire, Wi.
    Mine at 30 mph is about right on. At 65 mph it is about 2 mph slow. Just my best Est.
  19. rxlawdude
    701
    219
    So Calif
    2015 Tesla Model S
    Except the ODOmeter is the only relevant device for MPG calculations. Instant speed indicated on the speedometer is not relevant whatsoever to fuel consumption.
    Although it seems counterintutive, the fact the SPEEDometer is off by +2-3% does not mean the ODOmeter is off by that same proportion. In fact, if it were, there would be lots of class action lawsuits for fraudulent early termination of warranty coverage.
  20. fuzzy1
    10,045
    Yup. Both Honda and Subaru were hit with such suits while I owned those cars, and both settled for warranty extensions.
    BTW, neither of those cars of mine had significant odometer errors.
