1. Offline
    NineScorpions Economy, Meet Style!!
    Start a Conversation
    Nov 12, 2011
    394
    62
    Your Vehicle Year:
    I swear I saw a thread on here a few weeks back with someone showing the step by step for spring installation, but have been using the search feature with no results so far. Anyone?
  2. Offline
    macmaster05 Senor Member
    Sep 27, 2009
    3,896
    555
    Your Vehicle Year:
    No offense but if you need a step by step guide to install the springs you shouldn't be doing it yourself. Suspension modifications are some of the trickiest around.
  3. Offline
    Dark_matter_doesn't Prius Tinkerer
    Aug 8, 2009
    598
    113
    Seattle, WA
    Your Vehicle Year:
    Here's the instructions I used for my Tanabe NF-210 install - they're pretty good.
    http://priuschat.com/forums/gen-iii...s-modifications/82404-diy-spring-install.html
    The job isn't very difficult for someone with some experience working on cars. The toughest part was working out how the rented spring compressor was supposed to be set up. I had the alignment checked afterward, and the drop didn't affect the alignment.
    1 people like this.
  4. Offline
    SuperchargedMR2 Diehard Rams Fan
    Feb 13, 2011
    714
    127
    Vancouver, WA
    Your Vehicle Year:
    I disagree. Changing out the springs is straight forward if you have the right tools. Just having a step by step guide to follow if changing them out for the first time can just make sure you get everything right.
    +1
    1 people like this.
  5. Offline
    Nov 12, 2011
    394
    62
    Your Vehicle Year:
    Bingo...thank you sir!
  6. Offline
    Nov 12, 2011
    394
    62
    Your Vehicle Year:
    Exactly...a little guidance never hurts!
  7. Offline
    Sep 27, 2009
    3,896
    555
    Your Vehicle Year:
    Hmm I guess it depends on your level of expertise. For some reason I was under the impression that you were a complete novice. But that's just myself, haha.
  8. Offline
    Nov 12, 2011
    394
    62
    Your Vehicle Year:
    Thanks for your write up...it was extremely helpful during my install.
  9. Offline
    lpe350 New Member
    Nov 12, 2011
    60
    17
    Long Island
    Your Vehicle Year:
    I just wanted to thank everyone for the installation guide. I took all of the suggestions and I installed my Tein springs (that I got from Lulzchicken) yesterday on a beautiful late December NY day (52degrees) in just 2 hours without air tools or a spring compressor. This forum is full of great information, thanks for sharing! :)
  10. Offline
    Feb 13, 2011
    714
    127
    Vancouver, WA
    Your Vehicle Year:
    How did you get the front springs off without a spring compressor? I would think it would be very dangerous to just loosen the nut & let all the spring energy explode. :eek:
  11. Offline
    V8Cobrakid Green Handyman
    Jun 6, 2004
    3,775
    132
    Your Vehicle Year:
    the last time i messed around with suspension parts was when i owned my lincoln mark VII. i had the car on jack stands and i used the jack to lower things. i did the same with my 318i bmw before that.
  12. Offline
    lpe350 New Member
    Nov 12, 2011
    60
    17
    Long Island
    Your Vehicle Year:
    I used my 1/2 drive and backed off the nut while it was in the car before I jacked it up. The weight of the car was on it and I just jacked up the car and removed it. The Tein spring is shorter and with a little weight from my left arm leaning on it, I was able to start treading the nut back on a few turns. Then I just used my socket to tighten it up the rest of the way. It was said before that having two people makes the job easier but I didn't have that luxury.
  13. Offline
    Nov 12, 2011
    394
    62
    Your Vehicle Year:
    I have to admit that on my LF...I compressed the spring to relieve the pressure off of the strut bolt. But not enough...so when I got the nut off the bolt, there was a quick jolt from the strut and spring housing. Luckily for me...I had compressed the spring so the actual "jolt" was only about 2-3". I did not make the same mistake on the RF...and compressed the spring much more. Perhaps there are homemade work arounds, but those spring compressors do their job!
  14. Offline
    lpe350 New Member
    Nov 12, 2011
    60
    17
    Long Island
    Your Vehicle Year:
    I agree with you 100%. In no way am I recommending anyone to NOT use them. I am just stating that I didn't use them myself and that's how I did it without the springs exploding and possibly injuring someone. ;)
  15. Offline
    jc562 New Member
    Nov 7, 2011
    16
    Your Vehicle Year:
    me and buddy have done a handful of spring swaps. we normally just shoot the spring into a box lol extremely dangerous and i definitely dont recommend it but were lazy and and sometimes the autozone spring compresser is to thick to fit between the coils of some springs.
  16. Offline
    Feb 13, 2011
    714
    127
    Vancouver, WA
    Your Vehicle Year:
    Very interesting way of doing it. I've always had a spring compressor so I've always done it that way even though it adds some time to the job. I'm usually able to get the lower spring on without using the spring compressor too.
  17. Offline
    Feb 13, 2011
    714
    127
    Vancouver, WA
    Your Vehicle Year:
    I've had that happen before too. I always make sure that the spring has some play in it before removing the strut nut now.
  18. Offline
    Feb 13, 2011
    714
    127
    Vancouver, WA
    Your Vehicle Year:
    Just one time something goes wrong would be bad. Get a proper spring compressor if the one you have doesn't fit. The one I bought many years ago has fit every spring I've worked on & it was not expensive.
    This is something like I use & I've had it for 20+ years.
    http://www.amazon.com/dp/product/B000M61KTC?tag=priuschatcom-20
Share This Page
