1. Offline
    SageBrush Senior Member
    Start a Conversation
    Jun 4, 2008
    7,217
    1,158
    New Mexico
    Your Vehicle Year:
    ^^ Yes, I meant 'stand out to me.'
  2. Offline
    twittel New Member
    Jul 7, 2010
    1,604
    142
    West End, NC
    Your Vehicle Year:
  3. Offline
    spwolf Senior Member
    Sep 16, 2005
    2,759
    253
    Eastern Europe
    i dont think start button is that much of expense anymore, in Toyota Europe, almost every model gets it at some level of equipment.
    they probably want to give sophisticated look to the hybrids.
    p.s. while this looks a lot like Yaris HSD, it seems wider than new Yaris... It seems Prius level of width. Quite possibly it might be literally shortened Prius, which would be cool.
  4. Offline
    Oct 26, 2009
    769
    224
    Maryland
    Your Vehicle Year:
    The only way to get 60 mpg or over on a Gen2 Prius-
    is to hypermile or add a li-ion plug-in battery.
    On Cleanmpg.com's mileage logs there are some
    Gen2 Prius hypermilers who are reporting over 75 mpg!
    While the more aggressive Gen3 Prius computers makes
    getting slightly over 50 mpg on a Gen3 easy - that same
    programming which is more complex and aggressive
    than a Gen2 also makes its more difficult for hypermilers
    to coax the Gen3 Prius to get over 65 mpg. Most
    people don't hypermile though --so having a more
    aggressive computer programming on the Gen3 Prius
    to *lifts* the fuel efficiency of the larger non-hypermiling
    population will have a greater impact (than catering
    to the much smaller hypermiling community).
    The only hope hypermilers might have is to have
    a driving "mode" and gauge display which makes it
    easier to hypermile (if such a thing exist).
    that being said...
    The prototype of the Prius C has a slightly smaller
    frontal area but probably a slightly higher drag coefficient
    than the 2010 Prius. The front engine compartment
    looks smaller so my guess is that it has a slightly
    smaller engine too. A smaller engine means that
    the Prius C will likely have less mass than
    the current regular/standard Prius. A shorter length
    also means that the Prius C will be easier to park
    and will be easier to manuever in tight spots.
    Rear wheel covers (like the 1st gen Insights)
    might help lower the Prius C drag coefficient
    but the main source of drag from the air
    turbulence which is caused by the notchback design
    remains. However, this drag only becomes
    a signficant energy drain when the car goes
    over 45 mph.
    While I already have a 2010 Prius III,
    For the record I think the Prius C prototype is rather cute. :)
    It sort of reminds me of the 1990's honda civic
    hatchback designs albeit the Prius C
    prototype seems to have smoother edges and curves.
    Walter Lee
    2010 Toyota Prius III oem floormats
    Yokohama Avid S33 (48/44 psi)
    ScangaugeII (AVG, Fwt, SoC, GPH)
    no grill blocking
    odeo +12750 miles/ 59 mpg overall
    best tank 66 mpg worst tank 52 mpg.
    Dc/MD/VA area
  5. Offline
    • Moderator
    27,654
    1,299
    Your Vehicle Year:
    Have you driven the Gen 3 with rear 10" discs?
    That's what Toyota Canada did with the 2011 HiHy. They took SKS out and made it optional.
  6. Offline
    7,985
    894
    South OC So Cal & the Flathead Valley, MT
    Your Vehicle Year:
    carbon fiber ... I'm guessing the body only ways 50lbs.
    :rolleyes:
  7. Offline
    ystasino Active Member
    Apr 17, 2007
    775
    44
    Baltimore, MD
    Your Vehicle Year:
    Short city commutes aside, what you call hypermiling I call normal Gen II operation and regular high speed drives.
  8. Offline
    The Electric Me Go Speed Go!
    May 22, 2009
    3,439
    876
    Undisclosed Location
    Your Vehicle Year:
    Toyota themselves have already stated that they project the Prius c will get the highest MPG of any available standard hybrid.
    So I don't see why there has to be a conflict between "regular" Prius owners and supporters and "future" Prius c owners. If you can exceed the 50 mpg EPA of the 3rd Generation Prius? Good for you. And I've heard that often. Whatever the EPA of the Prius c turns out to be...I'd expect you'll have a great number of people claiming to routinely surpass that number as well.
  9. Online
    drash Member
    Jan 5, 2005
    448
    37
    Upstate NY
    Your Vehicle Year:
    I'd agree with that. The Prius c is obviously designed to be marketed to "new" and less affluent Prius drivers. There are one heck of a lot Gen 2 Prius drivers (hundreds of thousands) so if you are thinking it would a purchase path for those drivers, probably not what Toyota intended. But by the time they get the 1st Prius c out the door, Gen 2 owners, like me, will have a lot of choices when it comes time to upgrade.
    If a Gen 2 driver's budget was in the low $30K, they would have the option of getting something a little roomier in a nicely equipped Prius v Three, the Prius Five with the tech package, the Prius Four with the Solar Roof package, a base Prius Plug-In, and the smaller, sportier Lexus CT200h. If your budget is in the upper $20K, then you will looking at a Prius v Two, Prius Three with Solar Roof package or a Prius Four. But there's nothing in the rules that says you can't pick a Prius c if you are coming from a Gen 2. And an up optioned Prius c might suit you just fine as will a Prius Two if you are not willing to spend more than mid $20k.
  10. Offline
    Apr 17, 2007
    775
    44
    Baltimore, MD
    Your Vehicle Year:
    I'm glad you can see it from my point of view. I think my decision would be about accepting the chance of out of warranty repairs on a '07 Gen II vs getting a new Prius. In terms of price, I was lucky to buy in April '07 when they were sitting in the lot. A year later they were selling for more than I bought it.
  11. Offline
    Aug 14, 2006
    18,113
    3,432
    Sacramento, CA.
    Your Vehicle Year:
    I don't think this is budget oriented. if the Prius c is sporty and nets more MPG than the other models then it doesn't matter if someone's budget is less than $20k or $50k. If it suits their needs and desires then they will buy it. When I go to purchase a new car in the next few years I will be able to afford a Prius v but that is not what i want. I'd ratehr have the Prius c if it gets 60+mpg.
    If you are all about keeping up with the Jones then buying at the top of your budget is the thing to do but that is not how everyone operates. Especially those who are good at saving money. :)
  12. Online
    drash Member
    Jan 5, 2005
    448
    37
    Upstate NY
    Your Vehicle Year:
    So does everybody think they'll be offering a Prius c Two, Three, Four, and Five? Seems their marketing department is trying to reinforce this numbering scheme by offering it with the Prius and Prius v to get away from the confusion with the 2010 Prius V.
  13. Offline
    Hdarji23 New Member
    Jun 13, 2011
    New Jersey
    Your Vehicle Year:
    Prius' are the coolest cars ever manufactured.
  14. Online
    drash Member
    Jan 5, 2005
    448
    37
    Upstate NY
    Your Vehicle Year:
    Looks like that might be target mpg if Toyota says this will be the highest mileage Prius and the estimated mpg of the Plug-in Prius is suppose to be 55 mpg after the EV battery has been depleted.
    2012 Toyota Prius PHEV (Plug-In): Features, Pricing and Release Date - GreenHybrid.com - The Interactive Hybrid Car Resource
  15. Offline
    krelborne New Member
    Feb 2, 2011
    295
    53
    Alabama
    Your Vehicle Year:
    The mileage is supposed to be the best of any "cordless":
    Unless they've recently removed that qualification, I assume that comparisons to the Plug-in Prius, charged or depleted, are invalid.
  16. Online
    drash Member
    Jan 5, 2005
    448
    37
    Upstate NY
    Your Vehicle Year:
    Hmm I was also thinking if you are going to buy a second car and your primary now is a truck or big SUV and you have a beater on its second engine, this would make the perfect second car for those 2 car families. The Prius c price point, if kept low enough, would be irresistible with the mileage savings. Now to overcome the numb thinking that bigger is safer, that's a whole other matter.
    :rolleyes:
  17. Offline
    Aug 14, 2006
    18,113
    3,432
    Sacramento, CA.
    Your Vehicle Year:
    Good luck! lol people are so stuck on that idea.
  18. Offline
    billnchristy New Member
    Jul 18, 2009
    888
    93
    GA
    Your Vehicle Year:
    IF this car was available we probably would have got one instead of the Fiesta. I am hoping when the lease is up to get into a c or possibly a Focus EV, it really depends on how things are looking. It is nice already driving a subcompact so this car won't feel small if we end up in one.
  19. Offline
    adric22 Ev and Hybrid Enthusiast
    Apr 6, 2009
    634
    127
    Fort Worth, TX
    Your Vehicle Year:
    I guess I'll have to reserve judgement until I see it without the ugly camouflage. I liked the concept car they had. As others have said, this looks almost exactly like a regular Prius.
  20. Offline
    Sep 16, 2005
    2,759
    253
    Eastern Europe
    [IMG]
    [IMG]
    [IMG]
    2012 US Yaris seems considerably smaller to me than that Prius C photo.
Share This Page
