1. Offline
    nemrut New Member
    Jul 22, 2009
    Message Count:
    57
    san francisco
    Your Vehicle Year:
    Anyone notice a squeaking sound coming from somewhere in the tires when driving the car for the first time of the day?
  2. Offline
    tumbleweed New Member
    Oct 3, 2005
    Message Count:
    3,797
    551
    Eastern Oregon
    Your Vehicle Year:
    Could it be the brake pads rubbing on the rotors? I've had that happen on other cars and it goes away when you use the brakes once and clean the rotors off.
    I don't think tires should squeak when they are going down the road in a straight line.
  3. Offline
    georgew New Member
    Aug 13, 2009
    Message Count:
    129
    Your Vehicle Year:
    Yes, and I find it very annoying. Please let me know if you find out the solution. I plan on bringing it up when I bring my car in for an oil change, which will not be for a month or two..
  4. Offline
    EGS47 Eric in CA
    Aug 8, 2009
    Message Count:
    Petaluma, CA
    Your Vehicle Year:
    Yes! Same thing on ours too. My wife drives our Prius IV much more than I do and she started noticing the squeaking noise about the second week after we got it (purchased Aug. 1). She kept telling me about, and I'd go out and take it for test drives and wouldn't hear anything. Finally a few days ago I heard it too - always happens at very low speed, and goes away after a few minutes. The strange part about this noise is that it's not rhythmic, like an out-of-round rotor or something. It sounded to me like maybe a squeak in the shocks or something. But sure enough, after a few moments the noise disappears.
    Tumbleweed's comment re: brake pads rubbing on rotors might be the story here, if they're dirty. We have a horse boarded at a small farm near us, with a long dusty gravel road leading to the property. My wife almost always hears the squeak when she gets back in the car to leave; once she's out on the highway and back into town, the noise is gone. Sometimes she also hears it when she leaves the house - again, always at low speed. So it makes sense that a few presses of the brake pedal might be cleaning something.
    Very bizarre noise, very intermittent (always LOVE trying to explain these types of noises to a mechanic!). She thinks it's getting worse; I'm not so sure about that. But I think maybe a trip to the dealer is in order to find out for sure. We've got another two-plus months before our oil change service and I don't know if we should wait that long if something more serious is going on.
    If anyone finds out the source of this noise, please post. Those hard-to-explain, "now and then" noises are the worst!
    Thanks,
    Eric
  5. Offline
    SlowTurd I LIKE PRIUS'S
    Aug 22, 2009
    Message Count:
    1,067
    274
    nj
    Your Vehicle Year:
    try taking off your hubcaps and see if it goes away??
  6. Offline
    sleewa New Member
    Jun 21, 2009
    Message Count:
    23
    Bellevue, WA
    Your Vehicle Year:
    I hear the same type of sound - only when starting up cold, as when driving it the first thing in the morning - although to me it does sound rhythmic - sounds as if a piece of sheet metal is rubbing once per revolution...
  7. Offline
    georgew New Member
    Aug 13, 2009
    Message Count:
    129
    Your Vehicle Year:
    agreed.
  8. Offline
    georgew New Member
    Aug 13, 2009
    Message Count:
    129
    Your Vehicle Year:
    Listened to this a bit more today. Seems to be coming from somewhere from the front, on the passenger side.
  9. Offline
    tiztim New Member
    Jul 6, 2009
    Message Count:
    47
    Chicago
    Your Vehicle Year:
    Yes and I'm certain it's the pads against the rotors. Irritates me no end as I brag about how silent it is in EV until the only things youhear is skeeek! - skeeek!
    I'll let my dealer know at oil-change
  10. Offline
    sferris New Member
    Jan 31, 2009
    Message Count:
    27
    Your Vehicle Year:
    wow! im not the only one!
    So i have the same issue as everyone who has responded to this post. squeeks coming out of a cold start at low speeds.
    SO i took it to my dealership for my 5k oil change and told them about it, and OF COURSE they could not repeat the problem during the 2 hrs they had it. They suggested leaving it with them all day when i have time.
    SO ANNOYING!
  11. Online
    qbee42 My other car is a boat
    Mar 2, 2006
    Message Count:
    17,752
    2,804
    Northern Michigan
    Your Vehicle Year:
    Brakes do that. Most cars are noisy enough that you don't hear them. Prius brakes are worse than most since they don't get much use. You can clean the brakes by forcing the car to use friction braking. Find an open stretch of road, get up to 40 mph or so, shift into N and apply the brakes to slow down. Repeat a few times and it will wear off the rust.
    Tom
  12. Offline
    Bambam650 New Member
    Jul 31, 2009
    Message Count:
    28
    Cincinnati, OH
    Your Vehicle Year:
    Yep, I have it too. Be interested in hearing what a dealer has to say about it.
  13. Offline
    Karalyn78 New Member
    Aug 28, 2009
    Message Count:
    Hermosa Beach, California
    Your Vehicle Year:
    I have the same problem with my Prius. I took it to the Toyota dealership today and said it was the plastic hubcaps over the tires. They drove two other 2010 Prius's while I was there and they had the same problem. The guy told me "You aren't going to be the only one with this problem, we can usually lube he tire and the sound goes away, but this different." He said its a cosmetic problem, not a mechanical one, but agreed, it made the car sound cheap and was annoying. He'll be calling me in a few days with what the factory has told him that we can do.
    2 people like this.
  14. Offline
    georgew New Member
    Aug 13, 2009
    Message Count:
    129
    Your Vehicle Year:
    Thanks Karalyn.
  15. Offline
    ahn22 New Member
    Sep 11, 2009
    Message Count:
    Los Angeles
    Your Vehicle Year:
    Brake Noise
    I purchased 2010 Prius 3weeks ago. I noticed a noise(squeak) Whenever I apply the brake at that time when I picked up my new car from dealership. So the next day I went to the Toyota service center and heard "Every Prius break system makes that noise and it is Normal".
    Is it true?? The dealer said it comes from the hybrid system.... After three weeks driving I've come to doubt that every Prius owner can stand the squeak noise and Feeling. Is it really normal? Does everyone hear it?
  16. Offline
    anniea New Member
    Jul 5, 2009
    Message Count:
    59
    Atlanta
    Your Vehicle Year:
    Re: Brake Noise
    I have never heard a squeak. When braking there is a noise that sounds something like a subway train braking (others have noted that too), but that's not an unpleasant sound, and I wouldn't describe it as a squeak or squeal.
    1 people like this.
  17. Online
    Mar 2, 2006
    Message Count:
    17,752
    2,804
    Northern Michigan
    Your Vehicle Year:
    Re: Brake Noise
    The regenerative braking system makes a whine, similar to the motors on a subway. It isn't terribly loud or annoying, but it is obvious. There is also inverter switching noise, which is at a higher pitch, but still a whine.
    If your squeal sounds like normal brake squeal, then your brakes may need to be cleaned. Forcing the Prius to do mechanical braking will clean off rust and dirt. Find an empty stretch of road, go up to 40 mph or so, shift into N and brake to slow down. Repeat a few times and your brakes will be shiny and clean.
    Tom
    1 people like this.
  18. Offline
    eglmainz New Member
    Jan 21, 2009
    Message Count:
    887
    137
    Chicagoland, IL
    Your Vehicle Year:
    Re: Brake Noise
    The sound that I hear sounds like a low (meaning not very loud) metallic (tin-like?) noise, I mainly hear when only using regen brakes. If I really stop, or 'glide' without any regen, I do not hear anything. Even when I do hear it, it is usually only with the windows open.
    From all I have seen read, and heard, this is normal for a Prius.
    1 people like this.
  19. Offline
    georgew New Member
    Aug 13, 2009
    Message Count:
    129
    Your Vehicle Year:
  20. Offline
    hansgrason1 New Member
    Jul 3, 2009
    Message Count:
    104
    Washington D. C.
    Your Vehicle Year:
    Same thing here. Squeaking started hppening about 2 weeks after purchase. Took it back to dealer and, of course, the noise didn't occur--so the mechanic found nothing, even after looking at the brakes. For me the squeaking seems to happen when it's very humid outside -- not always in the morning like others have mentioned.
Share This Page
