1. Offline
    sfv41901 Blizzard Brigade #164
    Start a Conversation
    May 5, 2010
    2,280
    633
    Palmdale, Ca
    Your Vehicle Year:
    Were u lucky yesterday?
  2. Offline
    Manila Ice Hybrid and V8 Lover
    Jun 23, 2012
    42
    Chino Hills
    Your Vehicle Year:
    NO....But I'm Lucky today :D
    sfv41901 likes this.
  3. Offline
    ucsmfu Senior Member
    Sep 21, 2011
    1,408
    301
    canada
    Your Vehicle Year:
    take lots of pics and post it here once you install it :)
  4. Offline
    May 5, 2010
    2,280
    633
    Palmdale, Ca
    Your Vehicle Year:
    Lucky in what way??? :D
  5. Offline
    striker308 Prius owner
    May 11, 2008
    214
    27
    Kenmore, NY (USA)
    Your Vehicle Year:
    Got mine in now, everyone was right..... 6 min to install and I had to find a srewdriver to boot.
    This shifter is great.......................
    One question (I'm not going to try this)
    Can you accidently shift into R while driving in D or B?
  6. Offline
    Steve Type-4 Trading HP for MPG
    May 16, 2012
    139
    56
    Your Vehicle Year:
    If that happens, the transmission will shift into neutral. According to Stage 10:
    I ordered the silver/green combo. Should be getting mine next week :cool:
  7. Offline
    May 11, 2008
    214
    27
    Kenmore, NY (USA)
    Your Vehicle Year:
    I back out of the driveway in R and at the end while still rolling hit D, it doesn't go to N it drives forward.
    maybe that's because of how slow I'm still rolling backwards but since it didn't go to N like what I've read before I ordered it I started thinking "what if"
  8. Offline
    Tracksyde Member
    Sep 21, 2011
    1,064
    512
    So Cal
    Your Vehicle Year:
    From what I remember, the stock shifter behaved the same way (because I'm pretty sure I've done what you described). And from what I read (here), the stock shifter also goes into N if you try to hit P or put it in R while the car is moving (probably at speed like you said).
  9. Offline
    12,335
    1,736
    Your Vehicle Year:
    hold down the power button for 3+ seconds.
  10. Offline
    May 11, 2008
    214
    27
    Kenmore, NY (USA)
    Your Vehicle Year:
    ??????? (n)Huh?
  11. Offline
    12,335
    1,736
    Your Vehicle Year:
    the answer to 'what if'?
  12. Offline
    jabecker driver of Prii since 2005
    Jul 7, 2005
    448
    67
    Portland, Oregon
    Your Vehicle Year:
    Finally found 10 minutes and dropped mine in. Silver and green. I'm loving it!
    One thing I noticed: you can't put the car in any gear - even N - if the parking break is on.
    My standard start-up procedure is: boot up, foot on break, car in D or R, release parking break, foot off break and on gas, go. That worked fine with the little joystick. With the Stage 10 in, when I tried to put the car in any gear I got three short beeps. I actually took the whole thing apart again and checked all of the connections before it occurred to me to release the break. Yeah.
    That's why it took me 10 minutes instead of 6. :rolleyes:
    Steve Type-4 likes this.
  13. Offline
    May 11, 2008
    214
    27
    Kenmore, NY (USA)
    Your Vehicle Year:
    I don't think I have ever used my parking (emergency) brake in either the 2006 or the 2012.
    don't you trust the P?
  14. Offline
    Jun 23, 2012
    42
    Chino Hills
    Your Vehicle Year:
    will do Im just kinda busy.... I got the Silver/GREEN and for those who wants to find out what kind of green is on the shifter....its the same green as the turn signal light arrows on the dash board and the EV/ECO/PWR icon/symbol on the dash also when you press one of these buttons!
  15. Offline
    12,335
    1,736
    Your Vehicle Year:
    not on a decent grade.
  16. Offline
    May 5, 2010
    2,280
    633
    Palmdale, Ca
    Your Vehicle Year:
    I've always used the p brake.......its a habit. Don't want the extra stress on the motor/tyranny mounts on any of My cars.
  17. Offline
    Jul 7, 2005
    448
    67
    Portland, Oregon
    Your Vehicle Year:
    I've always use the parking brake with all of my cars. It's just habit.
    The owner's manual even says to do it in the order I mentioned above.
    Start: foot on brake, turn on, D or R, release p-brake, foot off brake, gas.
    Stop: foot on brake, set p-brake, P, turn off.
    I'm obviously going to have to slightly change my habit. But I think I can get used to it. :)
  18. Offline
    Jul 7, 2005
    448
    67
    Portland, Oregon
    Your Vehicle Year:
    Here's mine. The green is different. It's a greener green, while the other buttons are a yellow green. It shows better in the daytime picture. I don't mind the difference. As someone mentioned, the green in the Stage 10 matches the green on the MFD.
  19. Offline
    May 11, 2008
    214
    27
    Kenmore, NY (USA)
    Your Vehicle Year:
    Looks great!
    I installed the carbon fiber in blue.
    That green does flow nice with the rest of the display, Did you cover the LED "light from above" for this picture?
    After driving around last night I noticed that the higher gloss on the carbon fiber created a bit of a glare with the LED, I'm going to cover it with tape to see if I like that better, if so I'll disconnect the power to the LED.
  20. Offline
    Jul 7, 2005
    448
    67
    Portland, Oregon
    Your Vehicle Year:
    Thanks. Yes, I just stuck my thumb over the LED "light from above" because it created glare at the camera angle. It's fine when I'm driving, though. The lower gloss on the silver keeps the glare to a minimum.
Share This Page
