steering gear jitters
Discussion in 'Generation 1 Prius Discussion' started by ChapmanF, Jul 24, 2008.
  1. bwilson4web
    15,387
    Changing resistance is the same signature of failed accelerator encoders and is 'cured' by using the 'wall-wart' trick to burn out potential, tin whiskers.
    THANKS!
  2. ChapmanF
    15,060
    I'm not sure I understand the tin-whisker phenomenon well enough to connect it to a resistance that decreases while on an ohmmeter. Back in 2008 I was imagining more an oxidized contact surface (which is why I spent time on those ideas about wetting current). On the other hand, my 'before' trace showing VT2 apparently glitching toward zero does seem easier to explain with a VT2-GND whisker than with any kind of wiper surface deterioration. In any case, I can imagine a wall-wart trick might be helpful with either condition, or both.
    The warranty extension letter I received said the condition is covered by Toyota through 31 December 2013 (15 months from now) with no limitation on mileage. The wall-wart approach will be good to have in our bag of tricks for any problems appearing thereafter.
    -Chap
  3. SteveWlf
    SteveWlf Old-on-Hold
    262
    33
    Montesano, WA
    Hmmm! All of this is very interesting and I wonder what one has to do to demonstrate to Toyota that this has happened. In my case, only once and I haven't to force it into a total failure. Not a situation I would want to happen at highway speeds.
    The problem is definately there, as I have experienced it.
    I'm going to contact my local dealer now and ask a few questions and my concerns.
    Thanks
    Steve
  4. SteveWlf
    262
    33
    Montesano, WA
    Wonders never cease, nor does the internet and these forums.
    I just called the local, small town Toyota dealer and the service manager seemed a bit sceptical about my steering Jitter problem but was willing to look up my VIN number for a recall. While he was inputing the VIN, I mentioned this info I had wasn't a recall but rather a Warranty Extension which was the second page of theh letter concerning the "Pinion-Nut". "Ohhh! Yah! That One!!. He continued to run my VIN and determined that my car still need the replacement rack. His parts department is checking the availablity and will schedule an appointment anytime it is on hand.
    What relief. And I must say, in this case Toyota was ready to stand behind their Prius, all-be-it 11 years old with 277,000 miles.
    Thanks to the contributers to this thread and this forum.
    Steve
  5. ChapmanF
    15,060
    Glad it's getting fixed!
    For anyone else worried about that, remember that the steering ECU is already designed to have the highest amplification at low speeds, like parking, when steering takes the most effort, tapering off to almost nothing at highway speeds. Although a bad torque sensor will be sending noisy signal all the time, the effect is pretty much imperceptible except at very low speeds, getting in and out of parking spaces, etc.
    The one thing that does eventually happen is that the ECU's threshold for noisy signals gets exceeded and the ECU logs a code and quits, giving you a manual-steering Prius. It will reset on the next IG-ON. So depending on how bad your torque sensor is, this will only happen on long drives. The first time it happened to me was on a 14-hour trip back from my sister's (and just within a few miles of my driveway). By a year later it was happening on any drive exceeding two hours. Again, because the assist gain is tapered off at speed, if the ECU happens to quit at highway speed you won't even really notice until you slow down or try to turn from a stop. Then it is harder to steer, but you can IG-cycle if you want your assist back. To be honest, at driving speeds I kind of liked the slightly tighter steering feel with the assist off. :)
    At least that was my experience, with the particular way my torque sensor failed. It was an annoyance but I never felt unsafe driving the car while I documented the problem before taking it in.
    -Chap
  6. SteveWlf
    262
    33
    Montesano, WA
    That info about "reset" is something I will "file away" incase it happens between now and when I take it in for replacement. Or, who knows! Maybe the new rack will suffer similar problems.. Let's hope not.
    Thanks Chap
  7. ChapmanF
    15,060
    At 2½ years after replacement:
    VT1-VT2 VT1-GND VT2-GND VT1-VCC VT2-VCC VCC-GND
    1 1231 1425 1427 615 617 810
    Still solid steady readings, not moving around on the meter as my old bad one did. I'm thinking about this again because Behrens may have found that whisker zapping as proposed by Bob might not be as effective as we all hoped, so now that the warranty extension is past, steering jitters may one day await us all....
    Interesting that over 2½ years nothing seems to have changed at all except the resistance to ⏚ gaining a few ohms. Not what I'd have expected exactly.
    I've always kind of wanted to solve this system to quantitatively draw the parallel-potentiometer picture I think is down there, only setting up the system with the measurements above makes my head hurt. So this time I also took this set:
    VT1 to (Vcc ⏚) VT2 to (Vcc ⏚) Vcc to (VT1 VT2) ⏚ to (VT1 VT2) (⏚ VT1) to (Vcc VT2) (⏚ VT2) to (Vcc VT1)
    1 615 617 308 1118 350 350
    Weirder measurements to take, but at least they lead to a system where each equation involves just two unknown resistances. Now to see if I can make any sense of it.
    -Chap
  8. ChapmanF
    15,060
    The alert reader has probably already noticed what bugs me about this: this does not look like a voltage divider that would give you 2.5 V at VT1 and VT2 when fed with 5 ... but plug it into the ECU and that's exactly what you get.
    Either there is something more down there than the pictures in the manuals suggest ... or maybe the ECU's VT1 and VT2 inputs have much lower impedance than I would have guessed, and pull the signals down. Maybe they even did that on purpose to draw a constant wetting current, as I was speculating about in #25 ... which would as a side effect make the voltage to torque relationship nonlinear. I've still never built any jig to make voltage to torque graphs....
    Or am I missing something really simple?
    -Chap
  9. ChapmanF
    15,060
    Update: the secret is to pry the wedge out.
    -Chap
    tochatihu likes this.
  10. tochatihu
    tochatihu Senior Member
    8,995
    3,507
    Kunming Yunnan China
    2001 Prius
    Steve Wlf stated concerns that power assist steering will go oflline at highway speeds. For reader's general interest, I would suggest exactly the opposite.
    Prius with 'manual' steering is very easy to operate on the highway. Pull the fuse and you might not even notice the different feeling.
    However if you are parallel parking or swerving to avoid a low-speed pedestrian 'contact', you most certainly will notice.
  11. ChapmanF
    15,060
    Exactly ... before Toyota replaced mine, I had it cut out on me a couple of times. Apparently the ECU has a threshold number of glitches it will tolerate (within one IG-ON session) and then it gives up, so it never happened to me except on long-enough trips (> 10 hours the first time) on the highway. Generally I never noticed the exact moment it cut out (on the highway, at highway speeds) ... I noticed when finally arriving at my exit and trying to turn a corner. :)
    -Chap
