Struggling with 10,000 mile oil change intervals, but want to!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bnaccs, Sep 11, 2012.
  1. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    Ramps are very convenient, particularly the plastic ones that don't weigh much. Ramps don't lift a Gen III Prius quite high enough that the oil-change "hatch" on the lower engine cover can swing forward without bending it a little to clear the ground. It's not a big deal, just a potential surprise. And if you do your own oil changes, go get the right cap wrench for the oil filter cover, either from a Toyota dealer or from an on-line source (Assenmacher 64mm 14 flute wrench).
    Epic Gen III oil change thread: Oil Change 2010 Prius - do it yourself | PriusChat
  2. wanaset
    wanaset Junior Member
    86
    16
    Toyota recommends oil changes at 10k miles yet the complimentary maintenance plan requires them at 5k. After 25k miles I am planning on changing my oil every 10k miles.
  3. roamerr
    roamerr Member
    135
    42
    Winston-Salem, NC
    I'd say more engines have been ruined with improper oil changes than extended changes. I'm a user of Mobil 1 EP and am fine with anything under 15k miles. I really don't care if the car lasts more than 500,000 miles anyway. Lol
  4. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    On my 2010, the 10,000 mile oil level is still within 1/4 inch of where it was when they filled it.
  5. Mendel Leisk
    38,205
    In Canada the interval is still 5000 miles (8000 km). I wouldn't doubt your Colorado winters are worse than lower mainland British Columbia, Canada. I'd stick with what you were doing, just for peace of mind.
    FWIW, Our previous Honda Civic Hybrid had Maintenance Minder, that seemed a bit more than just a mileage/time counter, (maybe monitoring engine rev's, coolant temp, number of starts, and similar?): the oil change interval typically came up around 8500~9000 km's (a bit over 5000 miles).
  6. markabele
    5,084
    1,782
    Nebraska
    Not sure where you're getting that from. At 5k they are pretty much only suppose to rotate the tires.
  7. wanaset
    86
    16
    I was under the impression that they also did an oil change at 5k. Not certain how I came to that conclusion. Nevertheless, my apologies.
  8. markabele
    5,084
    1,782
    Nebraska
    Not worries.
  9. camry25
    camry25 Junior Member
    46
    l.a.
    Correct me, but if gasengine is shutoff half the time, it runs less and and go longer. Also diference 5k and 10k (recommended) is just the cleanliness of the engine. Manufacturer recommendations usually are based on testing.
  10. rpg51
    rpg51 Member
    200
    Vermont
    My old camry years ago was on a 50,000 mile oil change interval with top offs occasionally when the oil light came on. It ran perfectly for 190,000 miles. I think we tend to get a little obsessed with this sort of thing.
    Bawb Hoss and markabele like this.
  11. Britprius
    Britprius Senior Member
    5,194
    1,912
    Herefordshire England
    That may be true but does it explain why in UK/Europe the oil change interval on the Prius from day one has always been 10,000 miles Gen1/2/3.
    Silver Pine Mica likes this.
  12. Dark_matter_doesn't
    691
    151
    Seattle, WA
    Apparently, motor oil quality standards have been higher in Europe, so 10K there has been OK. There's also the matter of Toyota being successfully sued recently about oil sludge build-up in their engines, so Toyota has been reluctant to extend oil changes to 10k here.
    Another good question: why are the oil change intervals still 5K in Canada?
  13. enigma88
    enigma88 Junior Member
    34
    Alberta, Canada
    According to the routine maintenance checklist that my dealership gave me along with my owner's manual, I should only change the oil every 8,000km (6 months) for the first 3 oil changes...then every 16,000km (or 12 months) after that. I have a 2011 Prius (and live in Canada).
    Is this because newer cars require less frequent oil changes?
  14. Dark_matter_doesn't
    691
    151
    Seattle, WA
    That's fascinating. First three oil changes every 4800 miles, perhaps intended to flush out the engine fabrication materials, then every 10,800 miles thereafter. Look at your Canadian Prius maintenance manual and let us know what it says. I thought the Canadian models had a 5000 mile (8330 km) change interval.
  15. enigma88
    34
    Alberta, Canada
    According to this Owner's Manual Supplement (warranty, maintenance & roadside assistance information), the oil changes are every 8,000 km (6 months) for the first 3, then every 16,000km after that. However, I did notice that in between each official oil change is a maintenance service which takes place 8,000km after each official oil change. Would this maintenance service also include an oil change? Then you indeed would be correct! =)
    The supplementary manual is generic so it applies to all 2011 models not just the Prius.
    Edit: So I checked the Toyota website, and the maintenance service does include "replace engine oil and filter". Xtime Menu Manager
  16. Yannick
    Yannick Junior Member
    16
    I'm rather surprised that a Prii in, say, Alaska, can go twice as long between oil changes as my Toyota Prius in Toronto. But all the Canadian paperwork on a 2012 Prius points to 8000 km / 6 month oil changes forever, and that's what my dealer sticks to. Does it put your warranty at risk if you follow the American interval?
