1. Offline
    firepa63 Former Prius Owner
    Jul 23, 2005
    Message Count:
    1,751
    186
    SE Pennsylvania
    Your Vehicle Year:
    [FONT=Arial, Helvetica, sans-serif]A new study by Carnegie Mellon University says that plug-in hybrids with 40 miles of all-electric range are less cost-effective than hybrids with smaller battery packs.
    “Forty miles might be a sweet spot for making sure a lot of people get to work without using gasoline, but you’re doing it at a cost that will never be repaid in fuel savings,†said Jeremy Michalek, an engineering professor who led the study, in an interview with Bloomberg. The Carnegie Mellon study is an attempt to test how prices and driving habits may affect consumer choices between current hybrids and future plug-in hybrids that run on a combination of gasoline and household electricity.
    [/FONT]
    [FONT=Arial, Helvetica, sans-serif]The study is only the latest in a series of recent reports questioning the real-world mileage and benefits of plug-in hybrids. In its February issue, Consumer Reports road-tested a plug-in version of the Toyota Prius and concluded the cost was "more than you could ever expect to recoup in gas savings." Last week, the Seattle Times reported that the City of Seattle’s fleet of plug-in hybrids—designed to run for 30 miles exclusively on electricity—is averaging 51 miles per gallon. Google has nine plug-in Prius hybrids used by its employees, and they are achieving an average of 54.9 mpg. These relatively low mileage numbers are partly attributed to the fact that Seattle’s and Google’s models were converted to plug-ins from conventional Priuses. Purpose-built plug-in hybrids are expected to have better fuel economy—perhaps 70 or 80 mpg.[/FONT]
    [FONT=Arial, Helvetica, sans-serif]“I think we all need to be more careful," said Tom Turrentine, director of the Plug-In Hybrid Electric Vehicle Research Center, in Davis, Calif., in an interview with the Seattle Times. “When we say we're going to get 100 or 150 miles per gallon [with a plug-in hybrid], then that's setting expectations way too high. It just leads to disappointment. We need to deal in reality."[/FONT]
    [FONT=Arial, Helvetica, sans-serif]Read more:
    http://www.hybridcars.com/news/studies-question-plug-hybrid-mileage-25613.html
    [/FONT]
  2. Offline
    josh2008 Hyundai Tech
    Sep 2, 2008
    Message Count:
    321
    117
    Princeton, WV
    Your Vehicle Year:
    How are they driving these things to get such low mileage? I as well as many others average better then that without even having a PHEV. How dissapointing.
    Josh
  3. Offline
    bwilson4web 03 and 10 Prius
    Message Count:
    7,495
    1,394
    Huntsville AL with 2003 Prius
    Your Vehicle Year:
    Hi Josh,
    I'd recommend reading some of the literature and studies but short range of the PHEV and driver demand are the limiting factors.
    Our Prius has a relatively low maximum EV speed, ~32 mph (not changed in the 2010 near as I can tell.) This means it works best when the driver has a route and the self discipline to stay in the 30 mph range until the plug-in battery is exhausted. Apparently the fine art of tickling the plug-in battery into the traction battery hasn't quite worked out.
    The second problem is demand. If the driver simply floors the accelerator or stomps the brake, there is no car that sustain respectable mileage. Since fleet drivers are really not into fuel savings (they get no benefit from saving fuel,) they tend to drive in ways that often waste fuel.
  4. Offline
    Apr 13, 2004
    Message Count:
    14,718
    519
    South Puget Sound, WA
    Your Vehicle Year:
    well i can agree in principal since i only need a 7 mile EV range to be able to commute back and forth without burning any gas. but i am in a "crowd" that only represents about 11% of the commuters who drive.
    what we really need is laws requiring employers to allow employees to plug in. that would halve the range needed. i am allowed to plug in, but there is only two places where one can plug in. so even my employer would have to upgrade if others decided to plug in (i am the only one so far)
    now, lets cut the EV range in half to 20 miles.... plug in at work and now over 60% of commuters could do that. that would be a significant reduction in battery pack costs.
  5. Offline
    Apr 13, 2004
    Message Count:
    14,718
    519
    Your Vehicle Year:
    the Seattle test is using severe driving and terrain conditions. without plug-ins, the fleet is averaging in the low 40's in summer. high 30's in winter, so although the results seem to be poor, its still a very significant increase in performance.
    also, remember fleet use rarely allows opportunity charging. and should not be used as a direct comparison to what a normal driver could do. for me, i drive in the morning. use about 30% of my available range. plug in at work. charge back up. drive home at night. done.
    fleet vehicles can be driven all day. frequently to areas where its not feasible to plug in. so as soon as you reach your EV range, you are back to regular gas driving at the 40 mpg rate. so to average 50 mpg is actually doing a pretty good job
  6. Offline
    usbseawolf2000 HSD PhD
    Sep 22, 2004
    Message Count:
    9,659
    1,270
    Queens, NY
    Your Vehicle Year:
    Just wait until the results are in for the next generation 2010 plug-in Prius.
    The current plug-in conversions limit the battery usage to 21-25 kW even though the plug-in pack can discharge more and the MG2 is rated at 50 kW. There is definitely a bottleneck in these "conversions" because it is only utilizing half of the electric power and run the gas engine for additional power.
    The next gen plug-in Prius would have more powerful electric motor and the battery pack designed to take full advantage of it, the gas engine will be used much less often. With the new Exhaust Heat Recovery system, it can shut down the gas engine much sooner too! Overall, it will truly lower the gas consumption and emission, especially in the cold weather.
    With the ~$3,000 tax credit, it should be a sweet buy.
  7. Offline
    spwolf New Member
    Sep 16, 2005
    Message Count:
    2,230
    156
    Eastern Europe
    yeah but even then if you drain those 10 miles of electricity right away, you wont have much left for rest of the commute - and fleet customers spend a lot of time in cars.
    i think next gen plugin hybrids might solve the issue by trying to estimate (or by your input) what is your daily commute going to be, and use appropriate blend of ev/hybrid mode...
  8. Offline
    Sep 2, 2008
    Message Count:
    321
    117
    Princeton, WV
    Your Vehicle Year:
    Thanks for replies to my statement, sometimes I think I live in a world where everyone cares about fuel efficiency. As stated thats pretty far from whats going on in these tests, they are doing "them" driving. Atleast their plug-in numbers are better then their "normal" numbers. That atleast proves to the masses that it does make a difference.
    Josh
Share This Page
