Sunday Night Dash Project
Discussion in 'Gen 3 Prius Accessories and Modifications' started by xenonrider, Mar 21, 2011.
  1. xenonrider
    xenonrider Junior Member
    76
    SoCal
    So... the modding has begun...
    Have some 3m carbon fiber vinyl left over from a previous project so decided to spruce up my dash a little... here are a few pix from tonight's project:D will have to tackle the door panels later this week.
  2. Mark57
    2,945
    2,735
    OK
    Looks nice. I like it. You've done a great and professional looking job.
  3. ePrius
    ePrius Member
    162
    76
    Looks great!
    Question. How hard was it to take out the center console? Thanks!
  4. drunkin master
    drunkin master Contributing Member
    394
    103
    92
    Los Angeles
    Looks good. Good installation.
  5. danvee
    danvee Blizzard Brigadier
    326
    53
    38
    New Jersey
    Great job! Especially aligning the patterns on the 2 pieces.:rockon:
  6. mmcdonal
    mmcdonal Active Member
    666
    98
    16
    Columbia MD
    That is pretty cool. Reminds me of the 2004 Solara SE dash.
  7. xenonrider
    76
    SoCal
    thanks for the kudos:rockon:
    the material is actually a matte finish. i guess the flash made it look shinier than it actually is. will have to take some pictures during the day.
    taking out the dash is pretty easy. There are no screws; just clips. Just lift up from the corners (starting with the bottom piece first). The only tricky part is that the top piece is attached to the trim piece next to it, so you have to remove both pieces together.
    mroadster2k likes this.
  8. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
    Great mod xenon! I tried something similar about a year ago, but unfortunately the material I was wishing ended up being too thick. This caused the buttons to "stick" when depressed. Guess I should've gone with the vinyl material.
  9. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Nice work. I have some 3M DiNoc CA-421 black to do mine when I replace my radio with a Nav unit..
    Did you need to use any adhesive activator?
    How do you deal with the edges where you make the cutouts for switches?
  10. 2011v
    2011v Member
    89
    29
    Manhattan Beach, Ca.
    Wow nice work! Cant wait to see the door panels.
  11. xenonrider
    76
    SoCal
    the smaller buttons are cutouts while the larger button are tucked in on the edges. Also, all the sides are tucked. i didn't use any adhesive activator as i haven't found them to be necessary with the 3M vinyl (in my experience at least). just a good wipe down with some rubbing alcohol and a paper towel.
    anyone know if the panels on the door (where the window switches are) just pulls out? or is it screwed in from behind?
  12. HI MPG
    789
    133
    93
    Orange County, CA
    You have to take off the silver trim panel first and then you could access that panel you are mentioning. The silver trim panel is held in place by some tabs. You'll just need to wedge between the bottom edge of the silver trim (start at the upper corner) and door, create a gap and the pull up. It's about the same effort as removing the center console cover.
    You could reference my album for reference of how it appears:
    http://priuschat.com/forums/members...picture3844t-modified-piece-in-place-door.jpg
    Juzcymru likes this.
  13. xenonrider
    76
    SoCal
    Thanks for the tip HI MPG! Hopefully, I'll have some time to get them done in the next day or two.
  14. ePrius
    ePrius Member
    162
    76
    Great! Thanks man!
  15. HI MPG
    789
    133
    93
    Orange County, CA
    Sorry.. that was a pretty bad picture link. I was attempting to link my album but instead linked that one picture. Here's a better picture of the trim piece removed:
    http://priuschat.com/forums/members...ods-picture3840-silver-trim-piece-removed.jpg
    The black window control panel then lifts off, and you could remove it completely by unscrewing a couple of screws holding it in together.
  16. xenonrider
    76
    SoCal
    that picture was a great help:thumb:
    had some time today to finish up the project. Below are the pix. Now I just have to figure out what to do with the yucky cloth material on the door inserts.
    B. Roberts likes this.
  17. tihsad
    tihsad Junior Member
    93
    So. California
    this is exactly what i was gonna do with the left over vinyl from the roof LOL makes the dash look better than the dull plastic... i was thinking to clear coat them and give a little shine to it... what u guys think
  18. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Katzkin just supplies some vinyl upholstery that matches their seat upholstery and you glue it on right over the stock mouse fur door panel. I haven't done mine yet but saw some pictures of examples on other cars and they looked good.
    Your switch panel DiNoc work looks great!
  19. xenonrider
    76
    SoCal
    Thanks! A sharp knife and steady heads goes a long way:D
    With the door panel, the part I haven't figured out is the revets. I understand that you have to drill them out for the panel to come off. Then, rip off the cloth and glue in the new leather inserts... But how do you put in the new rivets? Or is there another way to get the panel to stay in place?
  20. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Remove the rivet head with a spade bit.
    http://www.professional-power-tool-guide.com/wp-content/uploads/2008/08/drill-bits-spade.jpg
    Just drill deep enough to cit off the head and don't drill into the panel. Leave the plastic column part of the rivet there. The cheapest low grade spade bit is good enough for this job.
    If the rivet column is hollow like it was on the panels beside my rear seat back, you should be able to find sheet metal screws or push in panel fasteners to hold it in place. I haven't had my door panels off yet so am guessing at what's there based on what I saw someplace else in the car. I might get to them next week, if I do I will post some pictures.
