tail light replacement - aftermarket or OEM?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mariecee, Jun 23, 2012.
  1. mariecee
    mariecee New Member
    I just cracked my rear passenger tail light. After watching some you tube videos I think I can replace it on my own.
    Now I am debating between purchasing the tail light assembly form a number of different sellers.
    Should I go with the OEM part or is it ok to buy an aftermarket part for this type of thing?
    How much of a quality difference can there be between different tail lights?
    Here are some sample prices -
    OEM (Original Equipment Manufacturer) - genuine part from Toyota
    Toyota dealer = $354
    Toyota Parts Overstock =$266.34
    LENS & BODY, REAR COMBINATION LAMP, RH. REAR COMBINATION LAMP for TOYOTA PRIUS (2010, 2011) (8155147111)
    Aftermarket (a generic part not manufactured by Toyota)
    Ebay seller carpartswholesale = $179.85
    (New Tail Light Passenger Side Clear red lens Prius TO2819146 8155147111 | eBay)
    Ebay seller americanmotorparts = $155.75
    (Passenger Replacement Tail Light 10-11 Toyota Prius 4DR Hatchback 8155147111 | eBay)
    carpartswholesale said that the part doesn't come with bulbs or a wire harness, and in the videos I saw, that was included. So I don't have complete instructions on how to take the wire harness out of the broken part and use it in the new part.
  2. BSWEET
    BSWEET New Member
    52
    Suisun City
    If it was me, I would take this opertunity to switch to full LED taillights. You can buy a pair of them for under $300.00.
  3. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
  4. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    My concern with an aftermarket replacement part is how well it will match the other tail light. Have you tried rockauto.com? They were the cheapest when I bought engine air and cabin air filters.
  5. yeldogt
    yeldogt Active Member
    810
    313
    NE
    First thing: If you go with a genunine Toyota part do some aditional pricing to see what the part actually costs wholesale online and use that price as a starting point. It looks like that $266 price is for an OE part.
    Many of the aftermarket lenses are for people wanting something different -- they don't look the same. Make sure if you order one it will match the OE lens exactly.
    I have used aftermarket replacement lens assemblies in the past without any issues -- but they were simple asemblies ... not as complex as the Prius tail lamp
  6. Salvage09
    Salvage09 Junior Member
    38
    Pasadena CA
    The official Toyota taillight replacement instructions have an additional step that may not be evident:
    1. DISCONNECT CABLE FROM NEGATIVE BATTERY
    TERMINAL
    CAUTION:
    Wait at least 90 seconds after disconnecting the
    cable from the negative (-) battery terminal to
    prevent airbag and seat belt pretensioner activation.
    Obviously, this doesn't happen every time, but just the possibility that it COULD should be enough to take the precaution!
    La documentazione del selidori
    FWIW, the tail light assembly is available on EBay for about $75
    New Tail Light Assembly for Passenger Side | eBay
    These seem to come with bulbs and sockets. If you replace with LEDs be sure to buy red/yellow etc, if you want that color. A white LED with a colored filter will be very dim. Turn signals either need a different relay or parallel resistors to keep the blink rate right.
