Taillight replacement
Discussion in 'Prius c Technical Discussion' started by MNBud, May 20, 2014.
  1. MNBud
    MNBud Junior Member
    48
    suberb of Minneapolis MN.
    I did a search and found some aftermarket lenses but found no information on how to replace the taillight on a Prius C. I removed the two bolts inside the hatch but there appeared to be more holding the lens in place. I cracked one of mine, and the dealer wants over a hundred dollars to install. Is there more than just the two bolts?
  2. mertechperformance
    mertechperformance Active Member
    532
    126
    Nor-caL
    two bolts and two push pins comes right off with a nudge/pull from the top
