TDI clean burning diesel
Discussion in 'Environmental Discussion' started by boosted475, Aug 10, 2009.
  1. boosted475
    boosted475 New Member
    san francisco, CA
    How does everyone feel about the new TDI cars that get more mpg and less emissions?
  2. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    The new TDI's get lower mpg than the old ones.
  3. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
    See new Edmunds.com study for mpg. Emissions aren't even close.
    Or are you saying the new TDI's do better than old TDI's? I assume since you came to a prius site, you meant to compare to Prius...
  4. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Boosted...,
    As people have indicated they aren't. And the main reason is to reduce NOx, the peak combustion temp has to be reduced, and this reduces engine efficiency.
    The urea injection turbo-diesels (not the VW TDI but other luxury brands) might be able tom improve mileage. This is done by improved fuel spray patterns, with higher fuel injection pressures.
  5. Tideland Prius
    16,017
    A step in the right direction but still behind hybrids (even the Escalade methinks). THey're much better than diesels of old but anyone claiming that the new TDIs are as clean as hybrids have breathed in too much diesel soot. Maybe as clean as the Escalade but at Tier 2 Bin 5 they've just met the basic criteria all gasoline vehicles must achieve (this would be ULEV-II for the public). The Prius is Tier 2 Bin 3. The Honda hybrids are both Tier 2 Bin 2.
  6. Flying White Dutchman
    4,374
    313
    i feel the name "clean" is not correct
    its more like "cleaner" then before but never "clean"
    diesels are dirty..
    also the new commen rail injected turbo diesels these "clean" diesels are.
    not clean, just cleaner.
    and i am not talking about co2 but real stuff like NOx
  7. patsparks
    10,664
    567
    Adelaide South Australia
    Numb.
  8. wxman
    wxman Active Member
    619
    224
    Tennessee
    The slightly higher tailpipe emissions of the current generation of T2B5 clean diesel vehicles (mainly in the form of NOx) are at least partially, if not mostly, offset by the much lower evaporative hydrocarbon (HC) emissions in the fuel supply chain (diesel fuel is far less volatile than gasoline).
    HCs are the most problematic pollutants in areas of the U.S. where unacceptably high ambient levels of ozone ("smog") occur (i.e., metropolitan areas in non-attainment with the ozone NAAQS (National Ambient Air Quality Standard)), not NOx.
  9. boosted475
    san francisco, CA
    so i guess the claims on the commercials are not true
  10. wxman
    wxman Active Member
    619
    224
    Tennessee
    Depends on what it's compared to. Compared against the gasoline versions of the same vehicle (VW Jetta)...
    http://www.arb.ca.gov/msprog/onroad/cert/pcldtmdv/2009/volkswagen_pc_a0070279_2d0_u2_diesel.pdf (ULEV II Jetta TDI)
    http://www.arb.ca.gov/msprog/onroad/cert/pcldtmdv/2009/audi_pc_a0300200_2d0_u2.pdf (ULEV II Jetta 2.0T)
    http://www.arb.ca.gov/msprog/onroad/cert/pcldtmdv/2009/audi_pc_a0300203_2d0_pz.pdf (PZEV II Jetta 2.0T)
    (Grams/mile @ UL)​
    Emission.................VW Jetta TDI............Jetta 2.0L U2..........Jetta 2.0L PZ
    NMHC/NMOG.............0.014........................0.027.........................0.004
    CO...........................0.5...........................0.2.............................0.5
    CO @ 20*F................----...........................2.9............................2.4
    NOx..........................0.04.........................0.03...........................0.02
    Highway NOx..............0.03...........................0.01...........................0.01
    PM...........................0.001..........................----..........................----
    US06 HC+NOx............0.13...........................0.03..........................0.01
    US06 CO..................0.02............................4.4............................1.0
    SC03 HC+NOx............0.12...........................0.04..........................0.01
    SC03 CO..................0.02............................1.5............................0.7
    VEH. EVAP..............-----...........................0.0066.......................0.0051
    (not including evaporative emissions in the fuel supply chain)
    Again, lower NOx emissions do not necessarily offset the higher HC (NMOG/NMHC) emissions, in my opinion.
  11. Tideland Prius
    16,017
    Oh they probably are. They are "clean" diesels because they're cleaner than the old diesels.
    It's the way that's presented that the public assumes that it's cleaner than a regular gasoline car. This is out of VW's hands as they're just gonna say "well it's up to the people to interpret it and how they interpret it is none of our business"
    They never mention the actual emission numbers cause then that'll give people an idea to look up the numbers and then realise it's similar to a regular gasoline car.
  12. cwerdna
    cwerdna Senior Member
    12,544
    2,122
    SF Bay Area, CA
    The OP should go to Green Vehicle Guide | US EPA, go to Look Up Greenest Vehicles, check both checkboxes, select 2009 and California. Then sort by air pollution score and see where the VW TDIs fall and how many cars receive better air pollution scores.
    The scores are based max emissions allowed per mile for a given value. See http://www.epa.gov/greenvehicles/detailedchart.pdf. Some example emission amounts were listed earlier.
    Based on the "clean diesel" greenwashing, a TON of gasoline powered vehicles ought to receive some sort of "clean" label as well.
  13. quadracer1014
    quadracer1014 New Member
    60
    WI
    So I guess my wifes 2008 jetta tdi that gets 48 mpg stock is a lie. Near 70mpg with the ecm reprogrammed as well.
    Also several of my friends that have them too. Are they all lying?
    Hell I dont even have to burn diesel in her car. I can burn WVO and be completely carbon neutral if I want to.
  14. rjm06590
    rjm06590 New Member
    39
    Middletown, DE
    diesels are very clean they leave less imprint then civics and prius'. Have you seen pictures of nickel mines and he factories in third world countries used to create your batteries? The people are working for pennies and hour and they pollute unbelievably.
  15. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    You have absolutely no idea what you're talking about...zero, none. The mine is in Canada--not a 3rd world country. Wages are...well, whatever they pay in Canada. And the photos you've seen are propaganda posted by CNW in their completely debunked report about the Prius vs Hummer--all news about 5 years old. The mine has been dramatically cleaned up since the photos you've seen from the 1970s. Oh, the nickle/battery is recycleable, and the chrome on you diesel probably uses more nickle than my Prius battery.
    But thanks for the display of ignorance and your ability to deep throat any anti-hybrid propaganda proffered.:rockon:
    4 people like this.
  16. quadracer1014
    60
    WI
  17. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    The motive for patent lawsuit is money. Once negotiation is done and money changed hands, problem solved.
  18. Zythryn
    Zythryn Senior Member
    6,155
    4,146
    Quad, that mileage is truely impressive.
    The EPA rating for the Jette TDI is 42mpg. 15% above the EPA rating is a great job.
    The EPA rating for the TDI's howver is less than the EPA rating for the Prius. So if your wife can beat the EPA rating driving the TDI, I suspect she could beat the EPA rating of a Prius as well (or any other car).
    As for my feelings about the TDI technology, as stated by someone earlier, I applaud the improvement in various technologies to improve the fuel efficiency. Would be nice to see a combining of all the improvements in various models to produce an even better fuel efficient car.
    Just imagine the efficiency in a Jette TDI that used electrical assist and regenerative braking:)
  19. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,795
    Undisclosed Location
    As everyone has pointed out, How do I feel about Clean Burning Diesel? Compared to what?
    Compared to Hybrids the emmisions are not as clean, and you they don't match the MPG of The Prius.
    Compared to a standard ICE, they offer better MPG and comparable emmisions.
    Oddly, the few people (sample size is small) I've met that own diesel trucks or autos LOVE them. There enthusiasm and support of diesel reminds me of....well, Prius Owners really...
    I don't know, depends on what your personal feelings and goals are with auto ownership. If you want improved MPG and don't want the Hybrid complications or different machine feel...than maybe the new Clean TDI's are worth a look. If emmisions are important to you, then Hybrid is your best choice.
    For me, locally Diesel is actually pretty expensive and hard to find. But if I lived in the UK I think I'd at least consider the new diesel technology.
  20. fuzzy1
    10,013
    Old News:
    Patent suit not good for US Prius imports
    100 Million Dollar Patent Troll shakedown?
    Toyota Prius importation under threat due to U.S. patent trade case?
    'Search' finds numerous older threads about previous patent disputes. Prius imports continue.
