1. Offline
    RocMills Active Member
    Start a Conversation
    Aug 2, 2012
    742
    215
    Las Vegas, Nevada
    Your Vehicle Year:
    What is hypermiling?
    HID?
    DWL? (driving with lights?)
    Gliding? Has this word replaced "coasting"?
    ICE? (internal combustion engine?)
    Traction engine? Is the electric motor?
    And I've read others commenting on the vehicle proximity warning sound, but our C doesn't seem to make any noise other than the faint whining/whirring of an electric engine.
    Also, I've had my C2 for almost a month now, and the "battery" indicator on the energy monitor screen has never reached full capacity. At best it is one bar short of full. Does this mean I'm doing something wrong, or is the car still breaking in? I've not hit the 700 mile mark yet.
    Thanks!
  2. Offline
    • Moderator
    Sep 22, 2005
    6,985
    1,744
    N.Y.
    Your Vehicle Year:
    Quickly,
    ICE = Internal Combustion Engine
    Traction Battery is the large battery pack, not the small 12vdc battery.'
    HID are High Intensity Discharge, usually referring to head lights. The 2010 prius liftback has LED headlights now, no more HID. I don't know if even the top of the line Prius c has HID off the top of my head. HUD is Heads Up Display. The Prius Five or Plug-in Prius Advanced has this.
    Gliding and hypermiling can be googled or searched for on here. Theres TONS of info on here about it.
    The sound I think you're talking about is the pedestrian notification system, which is just that, a small whirring sound.
    Don't worry about the battery indicator not reaching full or going low. The computer will manage the battery and if need be run the engine when low etc. Full isn't full and empty isn't empty.
    RocMills likes this.
  3. Offline
    Aug 2, 2012
    742
    215
    Las Vegas, Nevada
    Your Vehicle Year:
    Thank you, Paradox!
    So there *is* a "normal" car battery in this thing along with the special battery? I was wondering the other day if there was any point to keeping jumper cables in the C2 (not for my own needs, but to help other motorists in distress). I think trying to learn hypermiling is going to make my brain explode, and not be very practical or doable in the areas in which I typically drive. In any typical day of driving, I see the battery indicator get quite low, down to one bar, and then quickly fill back up to one short of full, so I wasn't particularly worried, just curious.
    Thank you again for your answers.
  4. Offline
    • Moderator
    Sep 22, 2005
    6,985
    1,744
    N.Y.
    Your Vehicle Year:
    No problem, I always just tell people drive and enjoy the car. Personally, I don't hypermile and such, never have never will. I've driven all 3 of my Prius like I would any other car and still get mileage at what is advertised for the car.
    The Prius 'traction' battery (the NiMH battery) is never charged beyond a certain point, and never discharged below a certain point. It's kept between set points, like 40% and 70%. This is for battery longevity. That's why many of us just tell people ignore the battery indicator, it can be good for certain circumstances but for the average owner, it doesn't matter much, at least IMO.
  5. Online
    Apr 14, 2009
    5,824
    1,612
    Greenwood MS USA
    Your Vehicle Year:
    Yes in the C, they are both under the back seat.
    [IMG]
    Since it is a very small battery in an awkward place, your battery cables should only be for helping someone else jumpstart the dead car.
    If you go down a long enough hill, it will 'fill'. When that happens you can't put any more energy into it until you use some up, so your brakes quit doing regeneration and just heat up, like a 'normal' car.
  6. Offline
    Rob.au Active Member
    Aug 4, 2012
    585
    205
    Sydney, Australia
    Your Vehicle Year:
    Saw the battery "full" today for the first time after about 3.5 miles downhill descending about 800 ft when I already had a relatively high level of charge. I'm entirely happy with it normally having room to use the regen brakes rather than being "full".
  7. Online
    WD0AFQ Active Member
    Jul 6, 2012
    512
    110
    Dexter, Mo.
    Your Vehicle Year:
    Mine has never been over two bars above half, on the meter. Got about 700 miles on the car now. It will run 2 miles, or more, on the battery when at that point. I figure life is good so I am not worried about the meter. I don't make a habit of running two miles on the battery but I have checked it, as I am sure most others have.
    Dan
  8. Offline
    ChinchillaGirl OrcaCar
    Jul 21, 2012
    96
    SJ/SC Commuter
    Your Vehicle Year:
    So, when mine is "full" (twice daily during my commute over the hill), should I be switching to the B gear to prevent that overheating. I assume that brake heat contributes to early brake wear and replacement...
  9. Offline
    Ryephile The Technophile
    Jul 10, 2012
    419
    141
    Metro Detroit
    Your Vehicle Year:
    Just a quick clarification to expand technically; the generator motor is doing the initial vehicle deceleration in the form of regeneration until the point you request additional deceleration, in which the hydraulic brakes will assist further.
    Just drive the car normally in "D".
    To the OP: The battery is kept between 20% and 80% of its capacity to maximize its lifespan. As such, the battery "gauge" will never read full or empty unless there's a fault in the system.
  10. Online
    Apr 14, 2009
    5,824
    1,612
    Greenwood MS USA
    Your Vehicle Year:
    Any down hill that you KNOW will fill the HV battery, use B from the top. It will keep your brakes cooler. If the brake fluid boils, then pushing on the brake pedal will not make you stop.
  11. Offline
    Jul 10, 2012
    419
    141
    Metro Detroit
    Your Vehicle Year:
    When was the last time you boiled brake fluid on the street? And the car will still stop, just not nearly as well. Most OEM brake pads [read: low-temp street pads] will fade well before any reasonably fresh brake fluid will. None of this is relevant for your average public-road driving. If you're up in the Rockies and like to ride your brakes on the many-mile long steep descents, then it's something to consider.
  12. Online
    Apr 14, 2009
    5,824
    1,612
    Greenwood MS USA
    Your Vehicle Year:
    I absolutely agree you won't encounter any terrain that needs B near Detroit. (or Mississippi where I live now) We do not know where ChinchillaGirl is.
    When I lived in NV and drove home to WA, I drove I-84 through OR and saw vehicles use the runaway ramps and smelled my own brakes enough to dismiss the idea that Toyota added B for no good reason.
    http://cms.oregon.gov/ODOT/MCT/docs/EmigrantHill.pdf?ga=t
  13. Offline
    Jul 21, 2012
    96
    SJ/SC Commuter
    Your Vehicle Year:
    I am in California and go from 400 ft above sealevel over a 2000 ft high grade back down to 300, twice a day. I AM averaging 52 mpg even in this situation, but would love to do better, and I want to save my brakes! I appreciate any advice I can get.
  14. Online
    Apr 14, 2009
    5,824
    1,612
    Greenwood MS USA
    Your Vehicle Year:
    B is never a 'better MPG' solution, it always wastes energy that D mode would not.
    However you can 'fill' your HV Battery with a 600 foot vertical drop, so perhaps 1000 feet of your drop each day consists entirely of wasted energy once the battery fills. By starting to use engine braking in B mode from the top, it should be farther down the hill before the battery fills, so the brakes stayed cooler, longer. Modern brakes will not have serious trouble with overheating when new, as ryephile says, but as your brake fluid ages it's boiling point becomes lower. Boiling fluid means spongy or no brakes.
    If you find that your HV Battery never fills in B mode, then you do not need B mode for that hill. You will get better MPG without it. If you had a Prius PHV, with it's larger battery, it would not fill in 1600 feet.
    One oddity about engine braking, the engine gets faster and louder the more brakes you need, and slower and quieter the less brakes you need. This is not typical behavior in other cars, but is normal in this case.
    (I am often accused of 'hating' B mode, I really only want it used where it will improve safety and not just squander energy)
  15. Offline
    ufourya We the People
    Aug 20, 2008
    1,108
    223
    Your Vehicle Year:
    Type in 'ICE' or whatever here:
    http://www.cleanmpg.com/forums/glossary.php
    It will tell you what it is, then search for that term to find out all (more than, actually) you want to know.
  16. Offline
    Jul 21, 2012
    96
    SJ/SC Commuter
    Your Vehicle Year:
    Thank you VERY much for that clear answer- it has given me options to consider including giving B a try at the top.
  17. Offline
    jsfabb Active Member
    Aug 2, 2010
    597
    142
    Medford, NY
    Your Vehicle Year:
    I don't drive a "c", but as with any Prius, wouldn't it make sense to try and deplete your battery before you crest a hill? This would serve two purposes:
    - improve MPGs on the way up
    - may not need to shift to "B" mode and regen normally on the way down.
    Of course the configuration of the hill makes a difference. If someone is commuting every day, they could figure out the most efficient way to maximize MPGs.
Share This Page
