Tesla Adds Titanium Underbody Shield and Aluminum Deflector Plates to Model S
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by kenmce, Mar 28, 2014.
  1. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    From an engineering/cost standpoint, it would be interesting to know the Tesla logic for selecting Titanium. As a ground based vehicle shielding metal it's very expensive for the cost. Steel is strong and low cost for structural purposes. However, as a add-on protection element needing to be retrofitted on a existing car, there was some key constraint needing the very low weight value.
  2. austingreen
    austingreen Senior Member
    13,532
    4,062
    Austin, TX, USA
    The main material is aluminum which should be a better material for this purpose than steel, and given that the body is aluminum, I doubt they even considered the lower cost of steel. One benefit of titanium over aluminum and steel is elongation, it can bend more without braking. This should allow a much thiner plate of titanium that will not let sharp objections penatrate into the battery. Tesla likely threw every trick they knew at this to get rid of any perception of extra fire damage. I would not be suprised if the titanium is not included in next year's model.
    FL_Prius_Driver likes this.
  3. Zythryn
    Zythryn Senior Member
    6,170
    4,162
    Texas is one of the biggest states for Tesla.
    People learn about the car, they find a way even if they have to jump through a few hoops.
    austingreen likes this.
  4. austingreen
    13,532
    4,062
    Austin, TX, USA
    Its not that bad, you simply have to buy it on-line or on the phone, and you need to either pay cash, arrange your own financing, or finance through a tesla store out of state (colorado for now). What it does is makes it hard for the show rooms. Its illegal for them to even tell you how much the thing costs. They can just show you the car and answer questions about the car, not how to buy it.
  5. Fauxknight
    Fauxknight Active Member
    210
    116
    Go Tesla, above and beyond as usual.
    dbcassidy and austingreen like this.
  6. Trollbait
    11,315
    Ahh, I wasn't having much luck finding out where the mines were late last night. South Africa and Australia, yeah, but not the Ukraine. Perhaps some are still conflating Russia with the old USSR in such matters.
    My attempt of being a wise nice person went awry.
    I wouldn't surprised if Tesla tested Kelvar and carbon fiber. In addition to whatever advantages titanium had over other tested solutions, it is likely quicker to get sheets of it to bolt to the front of the battery tray. The aluminum deflectors likely took more time to source.
  7. cproaudio
    cproaudio Speedlock Overrider
    2,401
    758
    CA
  8. dipper
    dipper Senior Member
    1,242
    252
    Looks like even better than any off road 4x4 underbody shield.
  9. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Now there's a PR opportunity; take an S around a off road course - over rocks, water, mud etc. Anywhere where ground clearance is an issue.
  10. Trollbait
    11,315
    They'll end up starting afire with the titanium sparks.:ROFLMAO:
    GrumpyCabbie likes this.
  11. austingreen
    13,532
    4,062
    Austin, TX, USA
    I'm sure they are looking at awd off road possibilities with the X do for volume production a year from now. I'm betting they are looking at an off road package with a aluminum, fabric, aluminum skid plate sandwitch.;)
  12. Zythryn
    6,170
    4,162
    I can just see the ad now: "The road catches fire before the Model S will!"
  13. Air_Boss
    Air_Boss Senior Member
    3,909
    1,065
    New Yawk
    TiFi sparks lighting up dry grass at the roadside? Definite possibility.
  14. hill
    8,067
    That's what I'd be worrying about ... the one car with a titanium blast shield ... not the 500,000 smokers flicking their cig butts out the windows ... or catalytic converters that operate in the 100's of degrees. This just keeps getting better and better.
    Robert Holt and GrumpyCabbie like this.
  15. Air_Boss
    3,909
    1,065
    New Yawk
    Yes it does:
  16. DavidA
    2,325
    1,811
    Chicago western burbs
    The SR-71 has a skin made of titanium. It operates at 800+ degrees at mach 2+. What keeps it from bursting into flames?
  17. fuzzy1
    10,039
    It appears that the solid metal is not a fire hazard. Only the powders and shavings and other tiny pieces are a hazard.
    From a Material Safety Data Sheet for Titanium:
  18. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    But doesn't that apply to lots of things, including stuff we eat?
  19. Air_Boss
    3,909
    1,065
    New Yawk
    Pilots have an incentive not to let it contact the ground at those speeds.
  20. hill
    8,067
    yea ... that's why F1 drivers wear fire suits ... because they're scared of 'sparks'
    Some will see a couple trees & never notice there's a forest - called liquid explosive fuel.
