That uncomfortable NTSA head rest
Discussion in 'Prius v Main Forum' started by Nantz, Nov 18, 2011.
  1. Nantz
    Nantz Prius v5 AT Purchased 11/1/11
    oregon
    Well, altho it's no longer a "head rest", but a safety measure, can't stand them. Have a v5 with the AT and absolutely love it except tor the :mad: head rest. Does not bother husband at all- and looking back at the change in the NTSA required head rests for the last several years- it does not bother men, generally it's women. Hits me in the back of the head and makes me curl forward making a terrible driving position. Ache in the neck and shoulders. I tried to alter my position/the "headrest" in a myriad of ways with no relief. Even turned it backwards.
    For anyone else that it bothers.....have found a solution after trying several methods. I bought a "Scandia" travel down pillow. It measures 16x20 inches. I place it on upper shoulders, upper neck. Ahhhhh....feels great. It may or may not offer the safety in a collision as without, but I could not drive the car long distances otherwise. My previous vehicle, 2006 MBZ SLK 350 had seat/head rest molded perfectly to body shape- heavenly.
    I watch my husband and he slouches when driving. I like perfect posture.
    Oh well. This works.
  2. Mike James
    Mike James Camaros and Prii go figure
    142
    35
    Lincoln, NE
    Safety first! Just like the backup beeper :)
  3. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Can you install them backwards on a v? When I received my new Gen III the front seat headrests were installed backwards and were too far back for me. Might be what you want.
  4. El Dobro
    El Dobro A Member
    6,972
    3,209
    Do your headrests creep up on you?
  5. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Just a thought, but is your seatback possibly too upright? There is some amount of degrees off vertical that is recommended. If it is too upright, it will hit your head. Reclining a little should help. Don't think can install backwards. I think the notches are keyed for them to be forward.
  6. DragonflyDM
    DragonflyDM Junior Member
    53
    Pittsburgh
    I love the headrest. I do keep the seat more upright now and It allows me to remember to sit up straight properly and reduce neck strain.
  7. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    I was going to mention the same thing as a few others have - see if you can flip the headrest around - at least on the 2010 the headrest has a slight tilt forward - when flipped around it becomes a slight tilt backwards.
  8. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
  9. Nantz
    oregon
    Thanks everyone for the kind replies.
    To answer everyone....
    Yes safety is first! But I could not drive it the way the the headrest hits my head.
    Everything I've read says it really is a "woman's" thing, even according to the dealer who sold me the car. Husband is a physical therapist and his coworkers who are occupational
    therapists say they hear the same- from woman lol! It should not make any difference per se, but hubby says it's the way some of us are used to sitting. (But I did read a thread for another brand of vehicle from an male owner who is a machinist and physically altered his headrest. Now THAT would be a safety issue.
    For those who say that I can adjust the seat in a multitude of different positions- lean back, forward, up down, slide back forward etc. I've spent hours at it. Nothing works- and again have had a virtual team of occupational and physical therapists work at it and no one can get me from hitting back of head on head rest.
    And turning the headrests around-not that I'd do anyway, but tried that first off and they aren't installed backwards and doesn't help anyway.
    It's not something that happens gradually, creeps up, as I sit either. I get in and sit- and boom there that pesky thing is and makes my upper back and neck curl forward. The occupational therapists say it is the way women are used to sitting when we drive.
    I track my other car and the instructors laugh at the difference in the way women sit vs. men. Not going to track the Prius, tee-hee, but I'm out again next month-different vehicle. There is usually at least one other woman out there, so I'm going to look! Had the same prob sitting in a new Honda and Lexus so the issue for me is not the Prius. But other car is a 2006 MBZ and husband's is a 2009 S2000, and have no prob with either. Thanks so much for all the suggestions. Putting the little pillow there does the trick for me and according to the experts, because of the placement, it has no effect on the "whiplash injury lessening"headrest's effect. Thanks!
  10. Rochelle Kimall
    Rochelle Kimall New Member
    San Francisco, CA
    2013 Prius v wagon
    I test drove a Prius v on Sunday & will be buying, however also have trouble with the front headrest. It is tilted too far forward & is uncomfortable.
    Has anyone tried modifying this headrest or taking a backseat headrest & mounting its flat headrest pad onto front rods? Can't just switch back to front as rods are spaced differently. And don't want to drive around with a pillow behind my shoulders all the time. I want a permanent solution that matches the interior.
    Does anyone have any suggestions?
  11. mikefocke
    3,642
    1,628
    Sanford, NC
    My last car I had to adjust the seat forward so, in a collision, my head wouldn't snap back and hit the roll bar. Different heights and designs strike people differently.
    How tall are you and are you long or short waisted?
  12. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Take a look at the dummy's head in this NHTSA frontal crash test video, then decide if you want to second-guess Toyota's safety engineers. Skip to about 2:25 in:
    labell likes this.
  13. DavidK44
    DavidK44 Junior Member
    This has been a problem I've heard reported a number of places. One suggestion I've read was to flip the headrest around. It'll tilt slightly back rather than forward, which won't force your head downward all the time. Greater chance of whiplash in a crash, however.
  14. parnami
    parnami Member
    227
    47
    .Lancaster, PA (Amish Country) :)
    I don't understand the problem people have with the headrests. To me, they are the best, most comfortable of any I've ever had. With the seat reclined, they are nicely padded, something I've never been able to claim of any other. Sitting upright in a driving position, they don't touch me head though if I tilt my head back jusf slightly, I come up against the soft padding of the headrest, indicating, I believe, ideal positioning. I wouldn't want to see them changed even slightly. I consider them perfect!
    Corpus Delicti and Chazz8 like this.
  15. Air_Boss
    Air_Boss Senior Member
    3,913
    1,068
    New Yawk
    Ergonomics are 100% personal. Love the headrest. #YMMV
  16. labell
    labell Junior Member
    38
    TN
    2013 Prius v wagon
    Thanks for the footage, ftp. Do you know what the speed was for that test?
    Although I miss the plushness and electric controls of the seats on my former Audis, I have found a comfortable position in my new v. Haven't taken it for a long trip yet, but anticipate no problems. I am 5 ft 7 in female, and utilize the driving posture recommended at the Audi driving course I attended in Austria--which is NOT slouching.
  17. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    labell likes this.
  18. Bonnie Bashor
    Bonnie Bashor New Member
    I am 4'10' tall. The head rest, in it lowest position, forces my head forward so that I cannot sit in a comfortable position. The top of the headrest is way above the top of my head. I am ready to just remove the thing and hope I don't get in a wreck. There must a solution of some sort. I too don't want to sit with a pillow behind my shoulders. I cannot tilt the seat back anymore than it is and still see out adequately or get close enough to the petals while not getting to0 close to the steering wheel.
  19. DavidK44
    At least reverse the headrest, rather than removing it entirely. That way there's still a headrest that will stop your head if there's an accident, even if your head does travel farther than it might with the headrest properly installed.
  20. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    cycledrum and PLSPUSH like this.
