The one and only Prius Plug-in FAQ!
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by lensovet, Nov 24, 2012.
  1. kaiotes
    kaiotes Junior Member
    2013 Prius Plug-in
    really stupid question.
    how do i open the door to plugin my charger?
    I got more questions to follow but right now this is one that i would like to know so i can charge it for the first time
    dealer told me to push the door. it does not work.
  2. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    A little gentle push on the rear facing part of the door should do it.
  3. kaiotes
    2013 Prius Plug-in
    omg
    i'm an idiot
    i been trying to open the GAS DOOR
    just had someone at work show me
    lensovet and markabele like this.
  4. kaiotes
    2013 Prius Plug-in
    i have been driving my car for a few days. I have noticed that the acceleration of the vehicle is VERY lacking.
    I dont even have much charge using mainly gas and well when i try to step my pedal past the half way bar of the hybrid system indicator, it doesn't accelerate much. Even when the meter goes past the EV towards PWR it is pretty weak. I would have to step my pedal all the way down to PWR for it to act more like a normal car. Is there something wrong w the way i'm driving? I"m not expecting this to have much acceleration but something more 'normal'?. When I have to climb up an on ramp with a small incline, it is pretty hard without without having to floor it
  5. retired4999
    2,652
    625
    Eau Claire, Wi.
    Try the normal mode or power mode see if that works better.
    I'm guessing you are in eco mode which is good for gas mileage, for better response try power mode.
  6. john1701a
    john1701a Prius Guru
    12,748
    5,243
    57
    That's what you are suppose to do.
    The smooooth of the cvt combined with the thought the power should be avoided is a common misleader for new owners.
    Go ahead, press hard on the pedal.
  7. markabele
    5,084
    1,782
    Nebraska
    Also, keep in mind it shouldn't feel quite as powerful as a "normal" car. This is a MPG beast, not a race car.
  8. lensovet
    2,614
    495
    Burlington, NJ
    in my experience, driving in HV mode, acceleration from stoplights forces me into the PWR section 95% of the time.
    in EV mode, I can stay away from it but have to watch the bar to avoid unintentional engine startup.
  9. markabele
    5,084
    1,782
    Nebraska
    To be fair, it is only your foot that is forcing you into the PWR section, nothing else.
  10. lensovet
    2,614
    495
    Burlington, NJ
    Well, I'm trying not to be an donkey to other drivers too :)
    But I do think it's a bit weird that the "scale" for the power bar is different between the two modes.
  11. Astolat
    Astolat Member
    229
    73
    Guildford UK
    Sorry, don't check this thread often and forgot I had posted. Yes, even an idiot like me can understand it now, thanks!
  12. pbceng
    pbceng Junior Member
    Hi all. I've recently (end of September) traded in my '06 152k miles gen 2 Prius for a PiP in the UK. I wanted a full EV but apart from the Tesla Model S there isn't one that will cope in any reasonable fashion with my regular trips. I initially discounted the PiP because of it's low EV range, but when I worked the numbers out against an Ampera (Volt) and a BMW i3 REX it came out with the lowest running costs - the i3 worked out lower for my daily commute, but not the regular longer ones and the Ampera also came out cheaper on my regular commute but only with charging at work. Every other trip worked out more expensive. The PiP also came in cheaper due to a friendly dealer.
    I finally have a home charging point but am rarely able to charge away from home. For the first couple of months I used a custom high amp extension cable and a power monitoring plug - full charge with depleted batted came in at a pretty consistent 2.9kW (240V AC supply) using the supplied cable. I'm pretty sure the. At display showed something like 2.3kW charge when I first had the car and was charging via an extension lead, but on the installed charger it's now reading 1.9kW - I can't monitor any data from the charging point (yet) but am guessing it may be due to lower temperatures.
    Indicated EV range has dropped from about 13.5 miles when I first got the car to about 10.5 now, but again I think that's down to the drop in temperature. My EV usage is approx 10% at the moment.
    I've read some of the discussion here with interest and will be experimenting as time permits. If I can find the time I'll try tapping into the CAN bus and see what I can dig out.
    Thanks for all the interesting posts
    markabele likes this.
  13. pbceng
    Slight typo - the bit on charging should have read - "full charge with depleted battery came in at a pretty consistent 2.9kWh (240V AC supply) using the supplied cable"
  14. retired4999
    2,652
    625
    Eau Claire, Wi.
    Perfect! :)
  15. bisco
    48,947
    congrats on your new pip, all the best!(y)
  16. resoh02
    resoh02 Member
    140
    Northern OHIO
    It seems every one is hyped up on a plugin Prius, the question I have if everyone gets a plug in what will it do to our electrical grid which is already strained. The rates for electric will sky rocket. We get off one thing (gas) then electric. I still think that the standard prius hybrid is the best answer. I owned a 2006 and now I have a 2010 and still love it.
  17. DadofHedgehog
    DadofHedgehog Active Member
    681
    281
    northern Virginia
    Plug-in drivers are almost guaranteed to charge every day at night, when general electric power demand is the lowest. IMHO this is a perfect example of helping to "balance the load" on the regional grid, because late night charging uses already built and partly amortized electrical grid components at the times of their least utilization. Now, if we all plugged in to charge at noon every day in August, then yes, I'd agree with you.
    RicCorless and drash like this.
  18. mrbigh
    3,686
    699
    Long Island, NY
    This is a nonsense rant in the completely wrong thread from a closed minded one.
    Lourun likes this.
  19. RicCorless
    RicCorless Junior Member
    Augusta, GA
  20. bisco
    48,947
    do you have a pip?
