The two 12 Volt batteries and the one 201.6 Volt Hybrid battery
Discussion in 'Gen 2 Prius Technical Discussion' started by Mike_10, Aug 26, 2010.
  1. Mike_10
    Mike_10 Member
    73
    Boston MA
    I’m the second owner of a 2008 Toyota Prius (Package II) with 23k miles.
    I have a question about the different batteries.
    I understand that there are two 12 Volt batteries (one in the rear and one in the front under the hood) and there is one 201.6 Volt Hybrid battery (also in the back).
    If I ever would need to jump-start the car it is explained that that needs to be done using the front 12 Volt battery (p. 451-452 of the 2008 Owner’s Manual).
    Question: What is the back 12 Volt battery for? Is it connected in the same circuit as the front 12 Volt battery?
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    There is only one 12v battery and it sets in the back. There are "jump" terminals in the front just for convenience.
  3. krg03
    krg03 Not expert, just experienced
    246
    31
    so cal
