Thread for advice & discussions on using Prius for work/deliveries (usps rural carriers for example)
Discussion in 'Prius c Main Forum' started by Britt Jacobsen, Oct 26, 2014.
  1. Britt Jacobsen
    Britt Jacobsen Junior Member
    48
    Deming NM
    2014 Prius c
    Rural Carriers, USPS, Pizza deliveries, newpaper routes, taxi to name a few.
    48,990
    if your going from mailbox to mailbox, there's no place for pulse and glide. it's more like stop and go on the highway, which is an mpg killer.
    Britt Jacobsen likes this.
  3. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    a prius would still get better gas milage than a regular car doing door to door delivery. the starting phase on a normal car is what really kills the mpg. on a prius, the battery assisted start will save you some gas. i dont see why not to use it for door to door. i would think that a pizza delivery guy would save a few bucks in gas money if driving a prius.
    minkus and Britt Jacobsen like this.
  4. Britt Jacobsen
    48
    Deming NM
    2014 Prius c
    I saved $9.31 on a 119 mile route compared to my Tacoma at 20-25 mpg. But wasn't getting the 53 mpg. More like 30-35 mpg which is still better.
  5. bisco
    48,990
    i wonder what a similar size gasser would get in this type of driving?
    minkus likes this.
  6. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    Were you getting 20-25 in your Tacoma? That's amazing for a Tacoma.
  7. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Well T'HERE is the problem.
    You need to LET GO of that estimated mileage.
    In your situation, you will never get even close.
    You did say that on longer highway trips it does much better.
    ALL of that is perfectly normal.
    I think it is likely that you will not exceed 40 with your "route" driving.......ever.
  8. Britt Jacobsen
    48
    Deming NM
    2014 Prius c
    Yes I calculated that was the mpg for the tacoma. Which is actual the advertised mpg for that year and model.
    ztanos likes this.
  9. kingnba6
    1,018
    242
    NY
    you should use Fuelly. its a much more accurate way to calculate mpg
  10. Britt Jacobsen
    48
    Deming NM
    2014 Prius c
    Thanks... Never seen this website. It can come in handy.
  11. Ashlem
    Ashlem Senior Member
    754
    502
    WI
    2017 Chevy Volt
    Make sure you sign up for gasbuddy as well. You can also log your fuel usage there, and you can earn points for reporting gas prices in your area, as well as find out the price of gas at various stations around your town. The points can be used to enter a contest to win a $100 gas card.
    Fuelly's site seems to neater as far as tracking your mileage though. Gasbuddy's seems to be hidden away by comparison, so you have to look around for their fuel logbook.
  12. bisco
    48,990
    these cars use so little gas, i keep it all in my head.;)
  13. Britt Jacobsen
    48
    Deming NM
    2014 Prius c
    Where and can I get a RHD conversion just for the gas and brake pedals? Or how about pedal extenders? Do they work well when carriers have to sit in the middle?
  14. dixiemailcarrier
    dixiemailcarrier Junior Member
    AL
    postal things in cleveland tn does them. i've had my prius on route since 2009. I never regretted it once.
