1. Offline
    rrolff Prius Surgeon
    Aug 19, 2009
    Message Count:
    1,602
    219
    So Cal
    Your Vehicle Year:
    Blew my Cig fuse for the second time - these things are a *bear* to remove... Anyone done this? It seems simple, but needle nose, tweezers, dental pick - all with no luck... Maybe there's a special Toyota tool ;)
  2. Offline
    banshee08 New Member
    Aug 7, 2009
    Message Count:
    263
    66
    El Monte, CA USA
    Your Vehicle Year:
    I know what you mean. When I was looking for a tap line for my rear view mirror I had pull a couple of fuse and yest the best way is with a plastic nose needle nose.
  3. Offline
    PriusLewis Management Scientist
    Feb 25, 2009
    Message Count:
    1,002
    78
    Denver Metro
    Your Vehicle Year:
    They make a plastic thing that is like a wide tweezer just for this. You might check the fuse and electrical area of your local auto parts store. I'm surprised there isn't one in the fuse block - many manufacturers include one that pulls out for use.
  4. Offline
    mgb4tim Noob
    Jul 8, 2009
    Message Count:
    1,002
    74
    Pittsburgh, PA
    Your Vehicle Year:
    there's a fuse puller in the fuse block under the hood.
    3 people like this.
  5. Offline
    a64pilot New Member
    Aug 3, 2008
    Message Count:
    771
    56
    Albany Ga.
    Your Vehicle Year:
    Yes, but hemostats or needle nose is easier, I think if you have them handy
  6. Offline
    reson8r New Member
    Nov 24, 2009
    Message Count:
    Raleigh
    Your Vehicle Year:
    I have the same issue with my cig fuse. First time to try to replace.
    Can you please tell me WHERE the fuse box is, and which fuse it is?
    Thx
  7. Offline
    Aug 19, 2009
    Message Count:
    1,602
    219
    So Cal
    Your Vehicle Year:
    There are two fuse boxes - both have labels for what each fuse does.
    The fuse box under the hood (drivers side front) has the fuse puller. The fuse box you want is right above where your left knee would be when driving. Unless you are a contortionist with good lighting, it's really hard to get at and see...
    BTW - I'm selling a full set for $5.50 - PM me if interested...
    (2) 5A
    (2) 10A
    (2) 15A
    (2) 20A
    (2) 25A
    (2) 30A
Share This Page
