TIPS, TRICKS, AND OTHER INFORMATION ABOUT YOUR PRIUS.
Discussion in 'Gen 2 Prius Main Forum' started by Arizona Charlie, Oct 19, 2004.
  1. Arizona Charlie
    Arizona Charlie New Member
    55
    San Francisco
    Some of these posts are mine, some aren't. Thanks to all of the people who posted these bits of information. I hope it is of some value to you.
    REPLACING THE CLOTH ON YOUR SEATS WITH LEATHER:
    I had my Prius’ seats done in leather. All of the cloth surfaces were removed and replaced by leather. The center console cover and the front and rear center seating surfaces were done in red. The sides of the seats, the back of the front seat including the map pockets, the armrests and the headrests were done in gray. the rear armrest and armrests on the doors were and done in gray. My Prius is equipped with side air bags and the leather that covers the airbags is stitched with break-away stitching. You will not notice that the stitching is break-away.
    The total cost for the job was $1050.00. I had it done at:
    Kar Products
    401 Bangs Avenue
    Modesto California 95356
    [209] 238-0894
    The company is owned by Jim Karp
    The leather is available in over seventy colors and the quality of the leather is excellent. Kar does not manufacture the covers. The buy them from the largest manufacturer of seat covers in the world. Katzkin Ineriors. 6868 Acco St. Montebello CA. 90640
    You can access the Katzkin web site at
    http://www.autoleathers.com/HTML2/AL.MAIN.FS.html
    Or phone them toll free at 1 [866] 757 3287.
    You can buy the interior leather from Katzkin and do the installation yourself, [not recommended], ask Katzkin for the name of in installer and have the leather you bought installed professionally, or buy the Katzkin leather from an installer and have them do the job.
    YOU’VE GOT A TAX CREDIT COMING YOUR WAY:
    Buyers of hybrid electric vehicles in 2004 and 2005 will receive a bigger tax incentive than expected, thanks to the tax cut bill Congress recently passed. It restored the alternative-fuel and hybrid vehicle tax deduction to $2,000 for vehicles purchased in 2004 and 2005. The deduction was going to be reduced by 25% this year and by 25% in 2005.
    H.R.1308--Working Families Tax Relief Act of 2004 (Enrolled as Agreed to or Passed by Both House and Senate)
    HOW TO PUT THE PRIUS INTO NEUTRAL SO YOU CAN GO THROUGH A CAR WASH :
    The car must be in the ready mode, and instead of just tapping the joystick as one does to put it in reverse or drive, tap and hold it on neutral for a second or so. The car will stay in neutral for the entire time it is being washed. The reason the car has this feature is so you don't accidentally bump the joystick while driving, and throw yourself into neutral. They thought of everything!
    USING LARGER WHEELS ON THE PRIUS. HERE ARE THE SIZES.:
    Tires are 205/45-17 Wheels are 17x7 +42 to +45 offset PCD is 100 5 lug. The wheels were purchased from from www.wheelmax.com the tires are Falken Ziex 512’s. (Consumer Report's top pick for all season tires)
    I also should add that the '04 Prius uses the same wheel and tire combination as an '03 or '04 ToyotaCorolla.
    I do not recommend making this change. It will reduce your MPG by 5 miles per gallon. Remember Toyota picked the wheels and tires that work best on the car and you should not fool with mother nature!!!!!
    A GOOD PLACE FOR PRIUS ACCESSORIES:
    Coastal Electronic Technologies, Inc.
    P.O. Box 33518, Indialantic, FL 32903
    Ph: (800)507-2234
    [email protected]
    OPTIMUM PRIUS TIRE PRESSURE.
    It is more gas efficient [and will help increase tire life] to run the tires closer to their 44 Ft. Lb. max. cold rating rather than what Toyota recommends on the door frame. I recommend either 40 PSI front - 38 PSI rear or 42 PSI front - 40 PSI rear: Check your mileage after running through a couple of tanks of gas and decide which pressure works best for you.
    FRONT WINDSHIELD HEAT-SHIELD:
    You can get a custom roll-up front windshield heat shield for about US$30 delivered from Canvas Works: http://www.canvasworks.com/main.html
    MAKING THE CENTER CONSOLE COVER INTO A USABLE ARMREST:
    If you would like your armrest to be a little higher and more comfortable here is how to do it. If you are satisfied with the armrest the way it is read this post and do nothing.
    When you open the Prius center console you will find a small black tray which IS used to hold change, a pen, keys, etc. This tray is removable and has an alternative use which I don't think is mentioned in the owners manual.
    Remove the tray and you will notice that there is a slot on the front-inside of the console. Put the tray into the slot allowing it to stand up vertically. The top of the tray should face the rear of the console. Close the armrest and the armrest is now resting at a convenient upward angle and is more convenient as a place to rest your right arm.
    CENTER CONSOLE POWER OUTLET:
    If you look inside the center console on the front left side you will notice that there is a rubber cover. Pull it out and you will find a receptacle that you can plug a cell phone charger into.
    STORAGE DRAWER. DID YOU KNOW YOU HAD ONE?
    Your Prius has a totally handy storage drawer which is located on the lower front of the center console. The drawer handle is located five inches below the top front edge of front cup holder. Pull it out and you have a great place to store all kinds of goodies.
    TO KILL THE BEEPING SOUND:
    Steps:
    1. Power on the car to IG-ON or READY. IG-ON will do for this purpose.
    2. Using the Trip/ODO button, set the Trip/ODO display to ODO (not Trip A or Trip B)
    3. Power off the car.
    4. Now power the car to READY (brake on). This is required so that step 6 works correctly.
    5. Within 6 seconds of powering on, press and hold the Trip/ODO button for 10 seconds or more.
    6. WHILE STILL HOLDING ODO *after* the 10 seconds, shift the "gear" selector from P to R, then back to P. Now release the Trip/ODO button.
    7. If the last step was successful, "b on" or "b off" should be displayed in the location where the Trip Odometer or Odometer is normally displayed. "b on" is beep on, and "b off" is beep off.
    8. Press Trip/ODO to toggle the mode.
    9. Now power the car off to exit the toggle mode.
    10. Power the car on to READY and confirm the reverse beep status by shifting to R. The beep should not be audible if "b off" was selected, and should be audible if "b on" was selected..
    Note: The Repair manual page states that if the 12v battery is disconnected, the beep will reset to the default of on, and this procedure will need to be performed again. The repair manual also isn't clear that Trip/ODO should remain depressed while shifting.
    Additional Note: The driver and passenger seatbelt reminder chime can be disabled or enabled (respectively, defaults appear to be driver on and passenger off) using similar steps. Instead of shifting from P to R to P in step 6, simply buckle then unbuckle the appropriate seatbelt while continuing to depress the Trip/ODO button.
    DO YOU WANT A LARGER REAR WIPER BLADE?
    To improve snow cleaning,replace the rear wiper arm with one from a Mitsubishi Outlander.
    SO YOU CAN’T SEE THE WHERE THE FRONT OF THE CAR IS.
    Arizona Charlie has designed and builds a device which attaches to your front license plate screw and will let you see where the front of your car begins. This device makes it easier to park. It looks like a radio antenna mounted on a bracket. Cost $19.00 including shipping. If you want one, contact him at [email protected]
    FLOOR MATS:
    Costco sells rubber floor mats which fit the Prius like they were made for the car. Price is under $20.00 for both front and rear mats.
    REAR CARGO MAT:
    So you want to put some dirty junk in the rear of the car to take to the dumps. Costco sells rubber mats which fit the rear of the car when the seats are folded down. Cost $15.00. They come in either gray or green and can be cleaned with a garden hose.
    DO YOU HAVE TROUBLE BUCKLING THE SEAT BELT?
    Toyota makes seat belt extenders and gives them away free just for the asking. While they were designed to make it easier for a portly driver to connect his seat belt they are very useful even for you skinny folks. If you always seem to be sitting on your seat belt receptacle when you get in your car this part is for you. The extender comes in several sizes but the longest is 12 inches. You plug the extender into the seat belt receptacle and then plug the seat belt into the extender. Ask your parts guy at Toyota to order one for you.
    SCARED TO DEATH THAT A SHOPPING CART OR SOMEONES CAR DOOR WILL GIVE YOU A DOOR DING?
    You can purchase door side moldings for your car from Toyota only Toyota does not make these moldings for the Prius.
    The good news is that can you buy four front door moldings which come as standard equipment on the 2004 or 2005 Toyota Highlander. You will use two of the moldings on the front door and two on the rear doors.
    If you are lucky the Highlander moldings will be available in your car’s color. If not, buy them anyway and have your friendly body shop paint them to match your Prius’ paint color.
    Installation is not a job for an amateur. Have them installed at a body shop. The procedure is to put masking tape on the Prius doors just below the area where the moldings are to be installed. Before installing them make sure that the both doors can be opened after the moldings have been installed. Then peel off the paper cover which covers the glue strip on the back of the molding and stick the molding on the door. Finally, remove the masking tape.
    For SF Bay owners I had my moldings installed at Frank Chavez Auto Body in Redwood City CA. Phone # [650] 759-1116.
    WHEEL COVERS:
    Standard on the Prius are some very good looking Alloy Wheels. For reasons unknown, Toyota decided to cover each wheel with a plastic cover which actually looks like the Alloy. I removed all four of mine by prying them off with a thin bladed screwdriver and put them in storage. I could understand the use of alloy looking plastic covers if the car came with inexpensive ugly steel wheels but it doesn't ??? Very Strange.
    FANTASTIC CAR POLISH:
    First, the disclaimer. I have absolutely no financial or economic interest in the following two products. I have used them and they are the best I have found.
    I was at a flea market and witnessed a demonstration of Maxa Gloss. According to the label on the bottle it is a “Premium wax and cleaner which is non-abrasive and clear coat safe. It is a long lasting carnauba wax formula which repels dust, leaves no powder residue and helps remove swirl marks on the cars finish. It provides long lasting protection from UV sun rays, helps fill in swirls and hairline scratches while creating a smooth as glass finish without excessive buffing or rubbing. It safely removes oxidation, bugs, water spots, tree sap, road tar, and bird droppings.â€
    I bought two bottles and I am amazed that this product is so easy to apply, no heavy rubbing and leaves no powdery residue. It is a terrific product, easier and faster to apply than any wax or cleaner I have ever used. I paid $20.00 for two sixteen ounce bottles. You can contact the man I bought it from at [805] 801-3526 or send a check for $27.00 for two bottles (which includes $7,00 for shipping) to Mitoma Company, PO Box 2087, Nipomo CA 93444. The product is sold as satisfaction guaranteed or money back.
    GREAT CLEANER FOR ALL OF THE PRIUS’ PLASTIC SURFACES:
    The product is called ‘Bumper Black’. I used it on the inside panels and the dashboard of my Prius to clean up finger marks and minor scratches. It also works well on all plastic trim such as bumpers, rubber trim, etc. Unlike Armor-all it does not leave an ugly shiny finish. This is an A+ product.
    To find where it is sold in your area contact the company toll free at 1[800] 323-9192 or 1[805] 397-5274. You can also write to The Wax Shop, PO Box 10226, Bakersfield CA 93389-0226. I don’t remember how much I paid for the product since I have had it for a long time. It probably was around $5.00 but don’t quote me.
    WILL RUNNING THE AC WHILE PARKED DISCHARGE THE BATTERY?
    No it will not! It was 93 degrees outside. I drove my wife to the Mall. She went in; I sat in the car and read Road and Track. The car was in park. The Air Conditioner was on Max cold the entire time. Battery went to two bars and the gas motor went on--battery went to three bars, gas motor went off. I sat in my cool car for over forty five minutes with the battery going up and down between two and three bars. The battery did not discharge.
    FRONT BUMPER GUARDS AND CORNER MOLDINGS:
    The Autosport®. Catalog features two items which I ordered and installed on my Prius.
    First item: Four Designer style strips which mount on the bumpers at each of the four corners of the vehicle. They come in Black or White. dimensions are 21" Long x 1 1/2" wide by 1/2" thick. Item # 3596. Price for a set of four is $24.95.
    Second item: Protector pads. These pads are 5" long x 3 1/2" wide by 5/8" thick. They come in black or silver. They feature heavy duty construction and a versatile shape also suitable for boat or garage and household use. A set of two is $14.95. A set of four which suitable for mounting on the front bumper and rear bumper sell for $29.90. Item # 3597
    Quoting the catalog: "Both of these items can preserve our cars' most easily damaged and expensive to repair areas. Heavy-duty impact resistant PVC protectors adhere permanently in minutes, no drilling necessary. for chrome and painted surfaces. Apply them anywhere. can be trimmed for a custom fit.
    Copy the following address into your browser and go the address. Pictures of both items are there.
    Autosport’s phone # is 1 [800] 726-1199. You can order a catalog from them.
    You can also reach the company at their web site.
    http://www.autosportcatalog.com/index.cfm?...m?fa=p&pid=1901
    MUD AND RAIN GUARDS:
    If you live in a wet climate or go to the snow I recommend that you purchase and have installed mud guards which attach to the car in the wheel wells behind the front and rear wheels. They are standard equipment on Canadian cars. They were at one time only available from the parts department of Toyota Dealers in Canada. They are now available from any US Toyota dealer. Ask your parts guy to order a set for you. About $40.00.
    TIRES WHICH WILL FIT THE PRIUS. AVAILABLE FROM ETIRES.COM. AND MANY OTHER TIRE COMPANIES:
    www.etires.com has a list of tires to fit the Prius..
    P185/65R15 88H Michelin Energy MXV4+ $119.99 ea.
    185/65R15 88S Michelin MX4 Grx (Honda) $97.99 ea.
    P185/65R15 86S Michelin Symmetry $90.99 ea.
    185/65R15 88H Nokian Hakkapeliitta NRW
    P185/65R15 86H Uniroyal Tiger Paw Touring HR $77.99 ea.
    P185/65R15 86H BF Goodrich Touring T/A HR4 $66.99 ea.
    P185/65R15 Primera $57.99 ea.
    P185/65R15 C avalier Accolade Plus $51.99 ea.
    185/65R15 88H Toyo Proxes TPT $81.99 ea.
    P185/65R15 86T Toyo 800 Ultra $67.99 ea.
    185/65R15 86Q Michelin Arctic Alpin $85.99 ea.
    P185/65R15 86S BF Goodrich Winter Slalom $77.99 ea.
    185/65R15 88Q Nokian Hakkapeliitta Q
    185/65R15 88H Nokian WR
    /65R15 88T Nokian Hakkapeliitta 2
    185/65R15 88T Nokian WR
    185/65R15 88T Nokian Hakkapeliitta NRW
    185/65R15 88H Nokian NRH2
    P185/65R15 86H Yokohama Avid H4 $57.99 ea.
    P185/65R15 86T Yokohama Avid T4 $57.99 ea.
    P185/65R15 86H Dunlop SP Sport A2 $65.99 ea.
    P185/65R15 86H Bridgestone Turanza LS-H $80.99 ea.
    185/65HR15 86H Bridgestone Potenza RE950 $73.99 ea.
    P185/65R15 86T Bridgestone Turanza LS-T w/UNI-T AQII
    185/65R15 87H Bridgestone Potenza RE92 $60.99 ea.
    P185/65R15 86T Bridgestone Potenza RE910 $59.99 ea.
    P185/65R15 86H Bridgestone Eager $55.99 ea.
    185/65R15 88S Bridgestone BT70S With Uni-T. $52.99 ea
    P185 /65R15 86T Firestone Affinity Touring (Saturn Sl2,Sw2) $58.99 ea.
    WEB SITES FOR PRIUS DISCUSSIONS:
    PriusChat.com - http://priuschat.com/forums/portal.php The Online Community for Prius Owners and Enthusiasts.
    PriusOnline.com http://www.priusonline.com/ Prius and other hybrids.
    GreenHybrid.com http://greenhybrid.com Prius and other hybrid vehicles.
    If you have any information relevant to the Prius which has not been included in this list, but should be, please reply here and I will add it to the list. I intend to post this list every month or so to inform new owners about the features of our wonderful car.
    Arizona Charlie
  2. glscheil1
    glscheil1 New Member
    150
    Raytown, MO.
    I have to drive up really close to my basement garage doors. I have attached one of the short antennas to the front. Someone told me of a similar upright that has lights on the top. Yellow for getting close and red for stop. Can anyone tell me where to get one?
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    The Michelin Harmony (P185/65R15 86S) and HydroEdge (P185/65R15 86T) will also fit. I suspect there are others, but that's a pretty comprehensive list.
  4. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(glscheil1\";p=\"45984)</div>
    George,
    I think this is what you are looking for:
    http://www.autosportcatalog.com/index.cfm?fa=c&cid=19
    I have done business with them and have been more than satisfied with their service.
  5. Danny
    Danny Admin/Founder
    7,093
    2,100
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Why don't we break these down into seperate KB articles, then place one post with links to the KB articles as a sticky. That way we can just update the individual articles as needed and not have to repost the same thread every once in a while.
  6. Davack
    Davack New Member
    Philadelphia area
    Overall, an excellent article!
    I think the following is *not* correct:
    "HOW TO PUT THE PRIUS INTO NEUTRAL SO YOU CAN GO THROUGH A CAR WASH :
    The car must be in the ready mode, and instead of just tapping the joystick as one does to put it in reverse or drive, tap and hold it on neutral for a second or so."
    The above states the car MUST be in Ready mode. However, if one presses the Power button twice -- WITHOUT having one's foot on the brake -- one can shift into "N" without the car running (i.e., not in Ready mode).
    David
    Philadelphia area
    04 Driftwood
  7. Varko
    Varko Member
    119
    North of Seattle
    I asked my (U.S.) Toyota parts dept. about mud flaps (guards) and they had no information about them. Do you know the part number?
  8. Frank Hudon
    Frank Hudon Senior Member
    4,147
    Val call Langley Toyota Town Parts and they have them in stock most times and ship to the states no problem. Not sure on the price but in Cdn$ Less in USD Phone # 604-530-9151
  9. Varko
    Varko Member
    119
    North of Seattle
    Thanks Frank
    AZ Charlie mentioned that they were available in the US so I thought I would try to get them locally. Otherwise, I will go north.
  10. aquirius
    aquirius New Member
    LOOKING FOR ALL WEATHER MATS.
    mY DEALER IN S. NEW JERSEY SAYS THEY WILL NOT BE AVAILABLE UNTIL JAN 15,2005 FROM TOYOTA. dO YOU HAVE ANY SUGGESTIONS HOW TO GET?
  11. outoftown
    outoftown Member
    125
    66
    Cary, NC
    <div class='quotetop'>QUOTE(aquirius\";p=\"51702)</div>
    If you are asking how to get the mats earlier, I think it is more than a single dealer problem since I was also told January at the earliest by Metro Toyota in Cleveland.
  12. betshsu
    betshsu Member
    302
    Washington, DC
    There's another thread here where people seemed to have ordered them from Canda. Try searching for "all weather mats." I think the title was "all weather mats installed" or something along those lines.
    I inquired before delivery of my 2005 as well and my salesman could never get any info on them.
